[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #3230
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3230/changes&gt;
Changes:
[tbarsballe] [GEOS-7822] Support unset primitive fields on REST PUT against ServiceInfo
[tbarsballe] XStreamPersistor: Use Callback for determining CatalogInfo class
[mike] Fixing link to license in docs
[...truncated 73422 lines...]
[JENKINS] Archiving disabled
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.154 s]
[INFO] Core Platform Module ............................... SUCCESS [ 17.340 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 9.946 s]
[INFO] Main Module ........................................ SUCCESS [03:02 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.390 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 22.771 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 11.881 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.802 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 46.139 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 54.203 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:22 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:54 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:18 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.078 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:08 min]
[INFO] REST Support Module ................................ SUCCESS [ 14.814 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:26 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.187 s]
[INFO] Core UI Module ..................................... SUCCESS [01:45 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 26.873 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.333 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.337 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.757 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.158 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.374 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:54 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:11 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.358 s]
[INFO] REST UI Module ..................................... SUCCESS [ 13.363 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 15.544 s]
[INFO] Community Space .................................... SUCCESS [ 1.029 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 1.030 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.530 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:56 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 10.193 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 11.147 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.700 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.452 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.218 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.249 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.265 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.851 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.035 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.406 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.171 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.984 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.806 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.187 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:32 min]
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 28:40 min
[INFO] Finished at: 2016-10-29T03:53:44+02:00
[INFO] Final Memory: 136M/750M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
  at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
  at org.jvnet.hudson.maven3.launcher.Maven32Launcher.main(Maven32Launcher.java:132)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238)
  at jenkins.maven3.agent.Maven32Main.launch(Maven32Main.java:181)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
  at hudson.remoting.UserRequest.perform(UserRequest.java:121)
  at hudson.remoting.UserRequest.perform(UserRequest.java:49)
  at hudson.remoting.Request$2.run(Request.java:325)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
  at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
  at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
  at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 1 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3231/changes&gt;
Changes:
[dblasby] Move Vector Tiles from Community to Extension (GSIP-138)
[...truncated 73420 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 32.012 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.300 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.701 s]
[INFO] Main Module ........................................ SUCCESS [03:13 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.437 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 22.940 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.300 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.904 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 46.949 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 54.360 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:26 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:56 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:23 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.343 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:12 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.653 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:28 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.203 s]
[INFO] Core UI Module ..................................... SUCCESS [01:37 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.134 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 45.627 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.896 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.943 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.425 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.343 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:53 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.687 s]
[INFO] REST UI Module ..................................... SUCCESS [ 10.664 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 18.086 s]
[INFO] Community Space .................................... SUCCESS [ 0.936 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 1.108 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.780 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:47 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.195 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.695 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.012 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.421 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.515 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.327 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.137 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.332 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.217 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.375 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.109 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.761 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.171 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:35 min]
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Total time: 30:21 min
[INFO] Finished at: 2016-10-29T11:24:05+02:00
[INFO] Final Memory: 137M/744M
[ERROR]
[ERROR] -> [Help 1]
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
Finished Calculation of disk usage of workspace in 3 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3232/changes&gt;
Changes:
[Alessio Fabiani] - Bunch of improvements for OAuth2 Community Module and Documentation: allow GeoServer to use multiple OAuth2 Providers at the same time
[...truncated 74460 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 41.012 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.611 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 39.633 s]
[INFO] Main Module ........................................ SUCCESS [03:59 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.374 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 24.269 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.519 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.795 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 56.325 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 53.221 s]
[INFO] Web Feature Service Module ......................... SUCCESS [02:00 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:59 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.515 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:27 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.815 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:21 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.234 s]
[INFO] Core UI Module ..................................... SUCCESS [01:35 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 26.389 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 49.808 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.225 s]
[INFO] Demos Module ....................................... SUCCESS [ 23.159 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.125 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:49 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 16.514 s]
[INFO] REST UI Module ..................................... SUCCESS [ 12.738 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 20.863 s]
[INFO] Community Space .................................... SUCCESS [ 2.231 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 3.136 s]
[INFO] Application Schema Support ......................... SUCCESS [ 2.106 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.687 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.956 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 7.981 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 5.272 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.468 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.295 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.467 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 7.949 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 7.466 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.839 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.515 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.714 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.203 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:37 min]
[INFO] Total time: 32:25 min
[INFO] Finished at: 2016-10-31T15:25:46+01:00
[INFO] Final Memory: 137M/683M
[ERROR]
[ERROR] -> [Help 1]
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
Finished Calculation of disk usage of workspace in 7 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3233/changes&gt;
Changes:
[tbarsballe] [GEOS-7828] Show style page error messages after clicking submit
[Alessio Fabiani] - Fix vectortiles pom release artifact reference
[...truncated 73186 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.060 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.005 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 10.414 s]
[INFO] Main Module ........................................ SUCCESS [03:08 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.359 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 21.633 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 11.538 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.092 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 44.968 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 47.090 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:36 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:34 min]
[INFO] Web Map Service Module ............................. SUCCESS [04:01 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 35.190 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:29 min]
[INFO] REST Support Module ................................ SUCCESS [ 19.728 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:52 min]
[INFO] Core UI Module ..................................... SUCCESS [01:42 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.945 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 45.596 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.335 s]
[INFO] Demos Module ....................................... SUCCESS [ 24.439 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 17.793 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.375 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:09 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 18.198 s]
[INFO] REST UI Module ..................................... SUCCESS [ 14.470 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 19.101 s]
[INFO] Community Space .................................... SUCCESS [ 2.590 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 1.857 s]
[INFO] Application Schema Support ......................... SUCCESS [ 2.246 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 9.273 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 10.945 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.387 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 0.484 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.187 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.265 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 4.461 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.058 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.144 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.421 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.171 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.867 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.156 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:36 min]
[INFO] Total time: 31:54 min
[INFO] Finished at: 2016-10-31T18:25:15+01:00
[INFO] Final Memory: 131M/501M
[ERROR]
[ERROR] -> [Help 1]
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3234/changes&gt;
