[Geoserver-devel] Build failed in Jenkins: GeoServer-Master #3235
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3235/changes&gt;
Changes:
[tbarsballe] [GEOS-7821] Fixup gs-restconfig services ftl temlates and add minimal HTML tests
[...truncated 74398 lines...]
[JENKINS] Archiving disabled
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 32.308 s]
[INFO] Core Platform Module ............................... SUCCESS [ 18.791 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.469 s]
[INFO] Main Module ........................................ SUCCESS [03:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.374 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 26.344 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 13.066 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.123 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 47.308 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 48.883 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:26 min]
[INFO] Web Feature Service Module ......................... SUCCESS [01:53 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:28 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.768 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:17 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.188 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:24 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.171 s]
[INFO] Core UI Module ..................................... SUCCESS [01:37 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 25.187 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 45.487 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.085 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.007 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.159 s]
[INFO] Security UI Modules ................................ SUCCESS [ 3.915 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:51 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:13 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 15.172 s]
[INFO] REST UI Module ..................................... SUCCESS [ 14.766 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 20.879 s]
[INFO] Community Space .................................... SUCCESS [ 1.076 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 1.529 s]
[INFO] Application Schema Support ......................... SUCCESS [ 2.450 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.159 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.830 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.932 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 5.538 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.234 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.669 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 3.713 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.823 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.199 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 3.057 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.234 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.202 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.416 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.172 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:37 min]
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Release Module ........................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 30:06 min
[INFO] Finished at: 2016-11-02T23:23:15+01:00
[INFO] Final Memory: 134M/524M
Waiting for Jenkins to finish collecting data
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to C:\.jenkins\jobs\GeoServer-Master\workspace\src\extension\wps\wps-core\target\surefire-reports for the individual test results.
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:212)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
  at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
  at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
  at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
  at org.jvnet.hudson.maven3.launcher.Maven32Launcher.main(Maven32Launcher.java:132)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launchStandard(Launcher.java:330)
  at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:238)
  at jenkins.maven3.agent.Maven32Main.launch(Maven32Main.java:181)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:136)
  at hudson.maven.Maven3Builder.call(Maven3Builder.java:71)
  at hudson.remoting.UserRequest.perform(UserRequest.java:121)
  at hudson.remoting.UserRequest.perform(UserRequest.java:49)
  at hudson.remoting.Request$2.run(Request.java:325)
  at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
  at java.util.concurrent.FutureTask.run(FutureTask.java:266)
  at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
  at java.lang.Thread.run(Thread.java:745)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures.
  at org.apache.maven.plugin.surefire.SurefireHelper.reportExecution(SurefireHelper.java:83)
  at org.apache.maven.plugin.surefire.SurefirePlugin.writeSummary(SurefirePlugin.java:177)
  at org.apache.maven.plugin.surefire.SurefirePlugin.handleSummary(SurefirePlugin.java:151)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.executeAfterPreconditionsChecked(AbstractSurefireMojo.java:650)
  at org.apache.maven.plugin.surefire.AbstractSurefireMojo.execute(AbstractSurefireMojo.java:586)
  at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
  at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:207)
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
channel stopped
Started calculate disk usage of build
Finished Calculation of disk usage of build in 0 seconds
Started calculate disk usage of workspace
Finished Calculation of disk usage of workspace in 3 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3236/changes&gt;
Changes:
[Alessio Fabiani] - (GEOS-7825) Implement GitHub OAuth2 Security Plugin
[Alessio Fabiani] - fix web sec core dependencies
[daniele.romagnoli] Fixing TYPO in GeoServer doc. WCS referred as Web Map Service instead of Web Coverage Service
[Alessio Fabiani] - Community OAuth2 improve web app pom deps
[...truncated 74085 lines...]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 54.054 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.638 s]
[INFO] Open Web Service Module ............................ SUCCESS [01:43 min]
[INFO] Main Module ........................................ SUCCESS [10:52 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.484 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 25.805 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 15.968 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.921 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [01:16 min]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 47.917 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:23 min]
[INFO] Web Feature Service Module ......................... SUCCESS [02:09 min]
[INFO] Web Map Service Module ............................. SUCCESS [05:58 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.138 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [03:21 min]
[INFO] REST Support Module ................................ SUCCESS [ 13.908 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:51 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.187 s]
[INFO] Core UI Module ..................................... SUCCESS [01:36 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 33.565 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 48.170 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 10.789 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.741 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 13.956 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.359 s]
[INFO] Security UI Core Module ............................ SUCCESS [01:47 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:14 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 19.181 s]
[INFO] REST UI Module ..................................... SUCCESS [ 16.592 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 18.180 s]
[INFO] Community Space .................................... SUCCESS [ 3.401 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 1.248 s]
[INFO] Application Schema Support ......................... SUCCESS [ 1.139 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:15 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 20.957 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 58.743 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.556 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 6.537 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.219 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 3.479 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 3.463 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.511 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 10.227 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 4.821 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.172 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.234 s]
[INFO] OGR WFS ............................................ SUCCESS [ 8.854 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.171 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:40 min]
[INFO] Total time: 46:52 min
[INFO] Finished at: 2016-11-03T13:43:20+01:00
[INFO] Final Memory: 122M/513M
[ERROR]
[ERROR] -> [Help 1]
  ... 31 more
[ERROR]
[ERROR]
[ERROR]
channel stopped
Finished Calculation of disk usage of workspace in 4 second
See <http://winbuild.geo-solutions.it/jenkins/job/GeoServer-Master/3237/changes&gt;
