[Geoserver-devel] Build failed in Jenkins: geoserver-master #3242
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3242/&gt;
[...truncated 16508 lines...]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.10-SNAPSHOT/gs-sec-cas-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.10-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-app ---
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configClean) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
   [delete] Deleting directory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-app ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-app ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/resources&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/java&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-app ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-app ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/test-classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.10-SNAPSHOT/gs-web-sec-cas-2.10-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.27 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [3464 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.10-SNAPSHOT/gs-web-app-2.10-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 16.225 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.650 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 18.367 s]
[INFO] Main Module ........................................ SUCCESS [02:50 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.150 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 56.665 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [04:21 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.295 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 27.108 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 34.025 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 51.393 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:51 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:19 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.435 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:19 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.193 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:21 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.215 s]
[INFO] Core UI Module ..................................... SUCCESS [01:26 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.464 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 45.457 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.440 s]
[INFO] Demos Module ....................................... SUCCESS [ 23.375 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.631 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.291 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:30 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:46 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [02:53 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.401 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.151 s]
[INFO] Printing Module .................................... SUCCESS [ 17.422 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 31.814 s]
[INFO] Community Space .................................... SUCCESS [ 0.153 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.103 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:54 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.931 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.230 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.894 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 3.332 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.823 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.437 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.400 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.430 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.553 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.462 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.084 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.227 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.146 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.083 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:40 min]
[INFO] Excel Output Format ................................ SUCCESS [ 17.202 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.859 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.457 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.928 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.745 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.854 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.810 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.153 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.730 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 11.376 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.554 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 8.662 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.134 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.168 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.678 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.411 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 13.478 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.106 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.460 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.565 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.966 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.837 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.172 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.552 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.102 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 21.504 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 16.018 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 12.247 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.440 s]
[INFO] Importer Core Module ............................... SUCCESS [ 54.107 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 48.238 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 26.844 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 17.701 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 24.545 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 15.277 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 38.594 s]
[INFO] BUILD FAILURE
[INFO] Total time: 24:06 min (Wall Clock)
[INFO] Finished at: 2016-09-08T07:20:12+00:00
[INFO] Final Memory: 114M/290M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3243/&gt;
