See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3512/>
[...truncated 22446 lines...]
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (818 B at 14.5 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20160924.185550-991.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20160924.185550-991.pom (2 KB at 15.7 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml (425 B at 7.7 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (839 B at 10.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/maven-metadata.xml (379 B at 4.5 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20160924.185550-991-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/gs-jms-cluster-container-2.10-20160924.185550-991-tests.jar (3 KB at 23.7 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-jms-cluster-container/2.10-SNAPSHOT/maven-metadata.xml (839 B at 10.5 KB/sec)
[INFO]
[INFO] Building ActiveMQ 2.10-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ activemqBroker ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ activemqBroker ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/src/main/java>
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ activemqBroker ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ activemqBroker ---
[INFO] Copying 0 resource
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ activemqBroker ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ activemqBroker ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-war-plugin:2.2:war (default-war) @ activemqBroker ---
[INFO] Packaging webapp
[INFO] Assembling webapp [activemqBroker] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/src/main/webapp\]>
[INFO] Webapp assembled in [303 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT.war>
[INFO] WEB-INF/web.xml already added, skipping
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ activemqBroker ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ activemqBroker ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ activemqBroker ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ activemqBroker ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT.war> to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT.war
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/activemqBroker/target/activemqBroker-2.10-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ activemqBroker ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/maven-metadata.xml (2 KB at 25.2 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20160924.185600-991.war
Sep 24, 2016 6:58:04 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
INFO: I/O exception (java.net.SocketException) caught when processing request to {s}->https://repo.boundlessgeo.com:443: Broken pipe
INFO: Retrying request to {s}->https://repo.boundlessgeo.com:443
Sep 24, 2016 7:00:12 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
Sep 24, 2016 7:02:58 PM org.apache.maven.wagon.providers.http.httpclient.impl.execchain.RetryExec execute
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20160924.185600-991.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/activemqBroker/2.10-SNAPSHOT/activemqBroker-2.10-20160924.185600-991.pom (8 KB at 30.4 KB/sec)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.960 s]
[INFO] Core Platform Module ............................... SUCCESS [ 1.789 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 5.256 s]
[INFO] Main Module ........................................ SUCCESS [ 22.036 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.888 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.171 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.249 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 0.981 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.759 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.615 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.751 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 2.358 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 4.141 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.751 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 5.950 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.114 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 3.300 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.614 s]
[INFO] Core UI Module ..................................... SUCCESS [ 4.358 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.508 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.607 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.091 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.643 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.698 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.575 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.842 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 1.853 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.420 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.065 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 37.062 s]
[INFO] Community Space .................................... SUCCESS [ 0.648 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 5.886 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.577 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 4.962 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.464 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.876 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.553 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.546 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.375 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.648 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.614 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.551 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 6.447 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 22.451 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.069 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 12.136 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.722 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.678 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.380 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.540 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.619 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.103 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.194 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.206 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.738 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.224 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.106 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.557 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 6.457 s]
[INFO] ActiveMQ ........................................... FAILURE [12:33 min]
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 17:24 min
[INFO] Finished at: 2016-09-24T19:08:24+00:00
[INFO] Final Memory: 146M/409M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project activemqBroker: Failed to deploy artifacts: Could not transfer artifact org.geoserver.community:activemqBroker:war:2.10-20160924.185600-991 from/to boundless (https://repo.boundlessgeo.com/snapshot/): Broken pipe -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :activemqBroker
