[Geoserver-devel] Build failed in Jenkins: geoserver-master #3552
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3552/changes&gt;
Changes:
[afabiani] - Fix for JIRA [GEOS-7776] GEOS-7753 fix that makes it impossible to
[andrea.aime] [GEOS-7698] Raster legend border colour now set by configuration Added
[andrea.aime] [GEOS-7698] Raster legend border colour now set by configuration. Do
[...truncated 13368 lines...]
Sep 30, 2016 3:17:16 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
Sep 30, 2016 3:17:16 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
Sep 30, 2016 3:17:16 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 13 ms.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Sep 30, 2016 3:17:16 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
Sep 30, 2016 3:17:16 PM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Sep 30, 2016 3:17:16 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
  Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Sep 30, 2016 3:17:16 PM com.hazelcast.cluster.ClusterService
Members [2] {
  Member [127.0.0.1]:5012 this
Members [2] {
Sep 30, 2016 3:17:17 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Sep 30, 2016 3:17:17 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Sep 30, 2016 3:17:17 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.531 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.10-SNAPSHOT/gs-dxf-wps-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.10-SNAPSHOT/gs-dxf-wps-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.10-SNAPSHOT/gs-dxf-wps-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.10-SNAPSHOT/gs-dxf-wps-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.10-SNAPSHOT/gs-dxf-wps-2.10-SNAPSHOT-test-sources.jar
Sep 30, 2016 3:17:22 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Sep 30, 2016 3:17:22 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Sep 30, 2016 3:17:22 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Sep 30, 2016 3:17:22 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 17 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 12 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.902 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.10-SNAPSHOT/gs-wps-cluster-hazelcast-2.10-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.739 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.260 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.778 s]
[INFO] Main Module ........................................ SUCCESS [02:36 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 2.128 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 43.318 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:44 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 12.212 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.868 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.789 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.646 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:46 min]
[INFO] Web Map Service Module ............................. FAILURE [02:21 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SUCCESS [ 14.586 s]
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.068 s]
[INFO] Core UI Module ..................................... SUCCESS [01:48 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 12.128 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.391 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 13.518 s]
[INFO] Community Space .................................... SKIPPED
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.872 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.473 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.649 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.227 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.442 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.239 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.239 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.854 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.286 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.031 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.937 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.163 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:33 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.937 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.994 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.582 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.665 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.475 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.010 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.106 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.144 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.043 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.520 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.625 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.568 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.326 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.666 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.752 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.949 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.627 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.494 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.278 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 12:40 min (Wall Clock)
[INFO] Finished at: 2016-09-30T15:17:22+00:00
[INFO] Final Memory: 100M/358M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3553/changes&gt;
Changes:
[nuno.oliveira] [GEOS-7744] Makes layers data by default only editable by admin users
[...truncated 13457 lines...]
Sep 30, 2016 4:12:39 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Sep 30, 2016 4:12:39 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Sep 30, 2016 4:12:44 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTTING_DOWN
Sep 30, 2016 4:12:44 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Master Address[127.0.0.1]:5009 left the cluster. Assigning new master Member [127.0.0.1]:5010 this
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Removing Member [127.0.0.1]:5009
Members [1] {
Sep 30, 2016 4:12:44 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Destroying node initializer.
Sep 30, 2016 4:12:44 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Hazelcast Shutdown is completed in 25 ms.
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTDOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 16 ms.
Sep 30, 2016 4:12:44 PM com.hazelcast.spi.impl.BasicOperationScheduler
Sep 30, 2016 4:12:44 PM com.hazelcast.system
Sep 30, 2016 4:12:44 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
Members [2] {
Members [2] {
Sep 30, 2016 4:12:45 PM com.hazelcast.core.LifecycleService
Sep 30, 2016 4:12:45 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Sep 30, 2016 4:12:45 PM com.hazelcast.partition.InternalPartitionService
Sep 30, 2016 4:12:50 PM com.hazelcast.core.LifecycleService
Sep 30, 2016 4:12:50 PM com.hazelcast.cluster.ClusterService
Members [1] {
Sep 30, 2016 4:12:50 PM com.hazelcast.initializer
Sep 30, 2016 4:12:50 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 18 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 24.866 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.655 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.870 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.214 s]
[INFO] Main Module ........................................ SUCCESS [02:33 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.062 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.629 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:50 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.015 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.332 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.847 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.318 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. FAILURE [02:14 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.525 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.098 s]
[INFO] Core UI Module ..................................... SUCCESS [01:18 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.437 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.065 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.034 s]
[INFO] Printing Module .................................... SUCCESS [ 13.433 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 11.887 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.794 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.947 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.091 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.458 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.243 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.238 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.841 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.281 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.022 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.114 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.724 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:37 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.175 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.820 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.484 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.187 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.490 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 33.280 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.727 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.952 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.048 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.491 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.043 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.243 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.977 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.651 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.986 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.029 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.609 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.366 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.025 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.605 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.429 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.794 s]
[INFO] Total time: 12:15 min (Wall Clock)
[INFO] Finished at: 2016-09-30T16:12:50+00:00
[INFO] Final Memory: 101M/331M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3554/changes&gt;
