[Geoserver-devel] Build failed in Jenkins: geoserver-master #357
See <http://ares.opengeo.org/jenkins/job/geoserver-master/357/&gt;
[...truncated 31309 lines...]
53248/?
57344/?
61440/?
65536/?
69632/?
73728/?
77824/?
81920/?
86016/?
90112/?
94208/?
98304/?
102400/?
106496/?
110592/?
114688/?
118784/?
122880/?
126976/?
131072/?
135168/?
139264/?
143360/?
147456/?
151552/?
155648/?
159744/?
163840/?
166935/?
[INFO] Retrieving previous build number from opengeo
Uploading: http://repo.opengeo.org/org/geoserver/gs-ows/2.6-SNAPSHOT/gs-ows-2.6-SNAPSHOT-test-sources.jar
4096/?
8192/?
12288/?
16384/?
20480/?
23989/?
[INFO] Building Main Module
[INFO] task-segment: [deploy]
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-6387] VectorRenderingLayerIdentifier will return the same feature multiple times, if there are multiple rules in the SLD matching it
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 09.03.2014 @ 17:22:47 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-Mar-2014 05:51
[INFO] [GitCommitIdMojo] build.build.time = 10.03.2014 @ 05:55:15 UTC
[INFO] [GitCommitIdMojo] build.branch = f47be5268005090e8e7fd149624ea15492df0fb3
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = f47be52
[INFO] [GitCommitIdMojo] build.commit.id = f47be5268005090e8e7fd149624ea15492df0fb3
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-6387] VectorRenderingLayerIdentifier will return the same feature multiple times, if there are multiple rules in the SLD matching it
[INFO] Copying 32 resources
[INFO] Copying 163 resources
[INFO] snapshot org.geotools:gt-cql:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:12-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-cql/12-SNAPSHOT/gt-cql-12-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-validation:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:12-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/12-SNAPSHOT/gt-wms-12-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-xml:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-xml:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-render:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-transform:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-transform:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-transform:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-transform:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-wfs:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.ogc:net.opengis.fes:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.fes:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.fes:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:12-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:12-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:12-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:12-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:12-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-core/12-SNAPSHOT/gt-xsd-core-12-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-cql/12-SNAPSHOT/gt-cql-12-SNAPSHOT.jar
3/189K
6/189K
9/189K
12/189K
15/189K
19/189K
20/189K
24/189K
26/189K
30/189K
32/189K
36/189K
39/189K
42/189K
44/189K
47/189K
50/189K
53/189K
56/189K
59/189K
61/189K
64/189K
67/189K
70/189K
73/189K
76/189K
78/189K
81/189K
84/189K
87/189K
90/189K
93/189K
95/189K
98/189K
101/189K
104/189K
107/189K
110/189K
114/189K
114/189K
115/189K
118/189K
121/189K
124/189K
128/189K
128/189K
129/189K
132/189K
136/189K
136/189K
139/189K
142/189K
145/189K
148/189K
151/189K
153/189K
155/189K
156/189K
159/189K
162/189K
165/189K
166/189K
167/189K
170/189K
174/189K
178/189K
182/189K
186/189K
187/189K
189/189K
189K downloaded (gt-cql-12-SNAPSHOT.jar)
Downloading: http://repo.opengeo.org//org/geotools/gt-wms/12-SNAPSHOT/gt-wms-12-SNAPSHOT.jar
[INFO] Compiling 2 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/classes&gt;
[INFO] Copying 101 resources
[INFO] Copying 36 resources
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Error transferring file: Server returned HTTP response code: 408 for URL: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-core/12-SNAPSHOT/gt-xsd-core-12-SNAPSHOT.jar
  org.geotools.xsd:gt-xsd-core:jar:12-SNAPSHOT
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
  opengeo (http://repo.opengeo.org/)
Path to dependency:
  1) org.geoserver:gs-main:jar:2.6-SNAPSHOT
  2) org.geoserver:gs-ows:jar:2.6-SNAPSHOT
  3) org.geotools.xsd:gt-xsd-core:jar:12-SNAPSHOT
[INFO] Total time: 5 minutes 28 seconds
[INFO] Finished at: Mon Mar 10 05:56:57 UTC 2014
[INFO] Final Memory: 63M/226M
See <http://ares.opengeo.org/jenkins/job/geoserver-master/358/changes&gt;
