See <http://ares.opengeo.org/jenkins/job/geoserver-master/359/changes>
Changes:
[andrea.aime] Addig a profile to include colormap extension in the build
[...truncated 9996 lines...]
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Addig a profile to include colormap extension in the build
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 11.03.2014 @ 15:57:33 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 11-Mar-2014 16:06
[INFO] [GitCommitIdMojo] build.build.time = 11.03.2014 @ 16:17:57 UTC
[INFO] [GitCommitIdMojo] build.branch = e17ce23cb62b69a744cf41a1a3ce379ad882522b
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e17ce23
[INFO] [GitCommitIdMojo] build.commit.id = e17ce23cb62b69a744cf41a1a3ce379ad882522b
[INFO] [GitCommitIdMojo] build.commit.message.full = Addig a profile to include colormap extension in the build
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-excel ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-excel ---
[INFO] Compiling 4 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/classes>
Query:
feature type: Bridges
filter: [ the_geom intersects POLYGON ((0.0001968 0.0006942, 0.0002032 0.0006942, 0.0002032 0.0007006, 0.0001968 0.0007006, 0.0001968 0.0006942)) ]
[properties: ALL ]
Query:
filter: [ the_geom intersects POLYGON ((0.00019872 0.0006976, 0.00020112 0.0006976, 0.00020112 0.0007, 0.00019872 0.0007, 0.00019872 0.0006976)) ]
[properties: ALL ]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.686 sec
Running org.geoserver.wms.georss.AtomGeoRSSTransformerTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-excel ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-excel ---
[INFO] Compiling 1 source file to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-excel ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/surefire-reports>
T E S T S
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.268 sec
Running org.geoserver.wms.georss.RSSGeoRSSTransformerTest
Running org.geoserver.wfs.response.ExcelOutputFormatTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.6 sec
Running org.geoserver.wms.legendgraphic.AbstractLegendGraphicOutputFormatTest
Tests run: 18, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.302 sec
Running org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReaderTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.047 sec
Running org.geoserver.wms.map.GIFMapResponseTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.42 sec
Running org.geoserver.wms.map.GetMapIntegrationTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.515 sec
Running org.geoserver.wms.map.GetMapKvpRequestReaderTest
Tests run: 22, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.069 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.973 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.189 sec
Running org.geoserver.wms.map.RawMapTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.196 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.928 sec
Running org.geoserver.wms.map.png.BufferedImageChildTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.wms.map.png.BufferedImageTypesTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 27.58 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-excel ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/gs-excel-2.6-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-excel ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/gs-excel-2.6-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-excel >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-excel ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] build.build.time = 11.03.2014 @ 16:18:29 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-excel <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-excel ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/gs-excel-2.6-SNAPSHOT-sources.jar>
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.391 sec
Running org.geoserver.wms.map.png.CustomByteIndexImageTypesTest
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-excel >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 11.03.2014 @ 16:18:30 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-excel <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-excel ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/gs-excel-2.6-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-excel ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/gs-excel-2.6-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-excel/2.6-SNAPSHOT/gs-excel-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-excel/2.6-SNAPSHOT/gs-excel-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/gs-excel-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-excel/2.6-SNAPSHOT/gs-excel-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/gs-excel-2.6-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-excel/2.6-SNAPSHOT/gs-excel-2.6-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/excel/target/gs-excel-2.6-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-excel/2.6-SNAPSHOT/gs-excel-2.6-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Layer Querying filter functions 2.6-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer Layer Querying filter functions:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-querylayer ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-querylayer ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-querylayer ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-querylayer ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-querylayer ---
[INFO] Compiling 4 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target/classes>
Tests run: 520, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.249 sec
Running org.geoserver.wms.map.png.CustomUShortImageTypesTest
Tests run: 160, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.387 sec
Running org.geoserver.wms.map.png.GetMapIntegrationTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-querylayer ---
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-querylayer ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-querylayer ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/querylayer/target/surefire-reports>
T E S T S
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.273 sec
Running org.geoserver.wms.map.png.PngSuiteImagesTest
Tests run: 30, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.235 sec
Running org.geoserver.wms.map.quantize.ColorIndexerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.105 sec
Running org.geoserver.wms.map.quantize.ColorMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.wms.map.quantize.QuantizerTest
Running org.geoserver.filter.function.GeometryCollectorFunctionTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.572 sec
Running org.geoserver.wms.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.439 sec
Running org.geoserver.wms.svg.SVGTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.281 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesAuthorityURLAndIdentifierTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.324 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesBBOXForEachCRSTest
