[Geoserver-devel] Build failed in Jenkins: geoserver-master #3623
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3623/&gt;
[...truncated 21764 lines...]
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-mbtiles ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-mbtiles ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-mbtiles ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-mbtiles ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/mbtiles/target/gs-mbtiles-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-mbtiles ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/maven-metadata.xml (2 KB at 25.0 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28.jar (24 KB at 196.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28.pom (4 KB at 40.0 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/maven-metadata.xml (451 B at 6.8 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/maven-metadata.xml (2 KB at 17.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/maven-metadata.xml (404 B at 4.7 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28-tests.jar (11 KB at 113.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28-sources.jar (12 KB at 123.2 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28-test-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.084159-28-test-sources.jar (6 KB at 54.9 KB/sec)
[INFO]
[INFO] Building GeoServer GeoPackage Extension 2.11-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-geopkg ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-geopkg ---
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geopkg/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-geopkg ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-geopkg ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geopkg/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-geopkg ---
[INFO] Compiling 1 source file to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geopkg/target/test-classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geopkg/src/test/java/org/geoserver/geopkg/GeoPackageGetMapOutputFormatTest.java&gt;:\[64,25\] error: cannot find symbol
[INFO] 1 error
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.103 s]
[INFO] Core Platform Module ............................... SUCCESS [ 9.120 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 6.942 s]
[INFO] Main Module ........................................ SUCCESS [ 14.125 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.894 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.235 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.322 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.344 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.758 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.676 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.991 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 1.931 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 3.671 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.733 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 6.461 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.239 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 2.828 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 3.086 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.346 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.961 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.586 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.109 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.889 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.501 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.653 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.788 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 1.726 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.359 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.099 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 43.410 s]
[INFO] Community Space .................................... SUCCESS [ 2.545 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 5.944 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.374 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.248 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.766 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.756 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.585 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.588 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.399 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 1.837 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.672 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.839 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.202 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 22.814 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.124 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.098 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.551 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.936 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.590 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.056 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.386 s]
[INFO] GeoServer GeoPackage Extension ..................... FAILURE [ 1.938 s]
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] REST plugin community module ....................... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] Resumable REST Upload module ....................... SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] REST SLD service ................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] GeoGig GeoServer integration ....................... SKIPPED
[INFO] GeoServer Config Backup And Restore ................ SKIPPED
[INFO] GeoServer Config Backup And Restore Core Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore REST Module .... SKIPPED
[INFO] GeoServer Config Backup And Restore Extensions ..... SKIPPED
[INFO] GeoServer Config Backup And Restore Web UI Module .. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 04:24 min
[INFO] Finished at: 2016-10-21T08:42:02+00:00
[INFO] Final Memory: 166M/488M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geopkg: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geopkg
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3624/&gt;
[...truncated 21805 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29.jar (24 KB at 194.8 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29.pom (4 KB at 38.3 KB/sec)
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/maven-metadata.xml (451 B at 8.3 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/maven-metadata.xml (2 KB at 18.1 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/maven-metadata.xml (404 B at 4.8 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29-tests.jar (11 KB at 109.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29-sources.jar (12 KB at 120.6 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29-test-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/community/gs-mbtiles/2.11-SNAPSHOT/gs-mbtiles-2.11-20161021.091153-29-test-sources.jar (6 KB at 57.8 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] 1 error
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.232 s]
[INFO] Core Platform Module ............................... SUCCESS [ 1.758 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 4.058 s]
[INFO] Main Module ........................................ SUCCESS [ 12.585 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.797 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 4.800 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.261 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.524 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 2.539 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 2.532 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 2.897 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 1.908 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 3.390 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 2.188 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 5.662 s]
[INFO] REST Support Module ................................ SUCCESS [ 1.150 s]
[INFO] REST Configuration Service Module .................. SUCCESS [ 3.017 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.596 s]
[INFO] Core UI Module ..................................... SUCCESS [ 3.331 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 4.667 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.713 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.130 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.599 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.776 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.595 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 1.802 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 3.367 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.321 s]
[INFO] REST UI Module ..................................... SUCCESS [ 1.051 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 35.151 s]
[INFO] Community Space .................................... SUCCESS [ 2.135 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 6.397 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.207 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.021 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.339 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.918 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.550 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.553 s]
[INFO] Web Processing Service Module ...................... SUCCESS [ 4.496 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 0.640 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 6.900 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.735 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.787 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 21.633 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 1.076 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 10.454 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.483 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.732 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.339 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.419 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 6.026 s]
[INFO] GeoServer GeoPackage Extension ..................... FAILURE [ 1.963 s]
[INFO] Total time: 04:02 min
[INFO] Finished at: 2016-10-21T09:11:56+00:00
[INFO] Final Memory: 165M/414M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3625/changes&gt;
