[Geoserver-devel] Build failed in Jenkins: geoserver-master #3634
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3634/&gt;
[...truncated 16456 lines...]
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/test-classes&gt;
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.849 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.332 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.083 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.183 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Webapp assembled in [349 msecs]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 35.340 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.446 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.048 s]
[INFO] Main Module ........................................ SUCCESS [02:59 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.067 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 53.875 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:41 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.260 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 41.589 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.699 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.698 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:43 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.614 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [04:03 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.204 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:29 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.039 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 28.417 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.733 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.511 s]
[INFO] Demos Module ....................................... SUCCESS [ 19.751 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.390 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.071 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:20 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:43 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:11 min]
[INFO] REST UI Module ..................................... SUCCESS [ 14.385 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 13.373 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.623 s]
[INFO] Community Space .................................... SUCCESS [ 0.052 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.234 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:46 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 41.661 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 49.871 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.822 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.666 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.445 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.244 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.246 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.671 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.842 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 2.023 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.149 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.611 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... FAILURE [02:23 min]
[INFO] Excel Output Format ................................ SUCCESS [ 14.994 s]
[INFO] Chart external graphics support .................... SUCCESS [ 4.831 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 6.524 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.047 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.936 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.451 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 14.887 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.050 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 14.790 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.016 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.653 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.698 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.643 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 29.990 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 39.744 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.037 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 30.145 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.127 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.894 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.944 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.027 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.309 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.020 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.576 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.753 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.828 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.051 s]
[INFO] Importer Core Module ............................... SUCCESS [01:50 min]
[INFO] Importer REST Api Module ........................... SUCCESS [ 42.404 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 22.565 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.913 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [01:25 min]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.420 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 59.233 s]
[INFO] BUILD FAILURE
[INFO] Total time: 26:18 min (Wall Clock)
[INFO] Finished at: 2016-10-24T12:16:29+00:00
[INFO] Final Memory: 115M/337M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3635/&gt;
[...truncated 16677 lines...]
[INFO] Copying 1 resource
[INFO]
[INFO]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.077 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.18 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO] Webapp assembled in [372 msecs]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.976 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [01:38 min]
[INFO] Core Platform Module ............................... SUCCESS [ 13.621 s]
[INFO] Open Web Service Module ............................ SUCCESS [02:22 min]
[INFO] Main Module ........................................ SUCCESS [04:52 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.106 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.439 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:51 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.018 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 32.291 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.627 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.902 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:17 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.285 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:14 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.556 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:20 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.087 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 29.958 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.540 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.785 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.037 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.632 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.121 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:19 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:46 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:13 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.309 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.078 s]
[INFO] Printing Module .................................... SUCCESS [ 13.831 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.544 s]
[INFO] Community Space .................................... SUCCESS [ 0.045 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 15.881 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 22.405 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.429 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [01:02 min]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 18.819 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 10.831 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 10.993 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.598 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 21.964 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 11.136 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.040 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.035 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.280 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:34 min]
[INFO] Excel Output Format ................................ SUCCESS [ 14.656 s]
[INFO] Chart external graphics support .................... SUCCESS [ 17.340 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 5.646 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 18.923 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 15.466 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.988 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.202 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.037 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.503 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.569 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.052 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.926 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.063 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.270 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.480 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.706 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.053 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 22.798 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.598 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.308 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.909 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.024 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.021 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.019 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.766 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.823 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.194 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.099 s]
[INFO] Importer Core Module ............................... SUCCESS [ 47.577 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 42.011 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 25.198 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 18.182 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 24.828 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.516 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 37.342 s]
[INFO] Total time: 27:04 min (Wall Clock)
[INFO] Finished at: 2016-10-24T14:34:28+00:00
[INFO] Final Memory: 114M/392M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3636/&gt;
