See <http://ares.opengeo.org/jenkins/job/geoserver-master/373/changes>
Changes:
[jody.garnett] Introduce ResourceStore API with initial FileSystemResourceStore and DataDirectoryResourceStore implementations.
[jody.garnett] Ensure ResourceStore does not return null and pull request feedback
[...truncated 330 lines...]
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #531 from boundlessgeo/resource_store1
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 17.03.2014 @ 06:52:30 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Mar-2014 06:53
[INFO] [GitCommitIdMojo] build.build.time = 17.03.2014 @ 06:53:55 UTC
[INFO] [GitCommitIdMojo] build.branch = 8fa613cb557d46c78f8e3b3106cb41731615c788
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 8fa613c
[INFO] [GitCommitIdMojo] build.commit.id = 8fa613cb557d46c78f8e3b3106cb41731615c788
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #531 from boundlessgeo/resource_store1
ResourceStore API and file integration (GEOS-6311)
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ web ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/target/web-2.6-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.6-SNAPSHOT/web-2.6-SNAPSHOT.pom
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-platform ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/target>
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/target/web-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.6-SNAPSHOT/web-2.6-SNAPSHOT-tests.jar
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-platform ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-platform ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-platform ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-platform ---
[INFO] Compiling 31 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-platform ---
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-platform ---
[INFO] Compiling 14 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/target/test-classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/test/java/org/geoserver/platform/GeoServerExtensionsTest.java>:\[203,41\] LOGGER has private access in org.geoserver.platform.GeoServerExtensions
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/test/java/org/geoserver/platform/GeoServerExtensionsTest.java>:\[205,31\] LOGGER has private access in org.geoserver.platform.GeoServerExtensions
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/test/java/org/geoserver/platform/GeoServerExtensionsTest.java>:\[209,31\] LOGGER has private access in org.geoserver.platform.GeoServerExtensions
[INFO] 3 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.866s]
[INFO] Core Platform Module .............................. FAILURE [4.174s]
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.441s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 17.618s (Wall Clock)
[INFO] Finished at: Mon Mar 17 06:53:59 UTC 2014
[INFO] Final Memory: 27M/134M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-platform: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
