Hudson
1
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3747/>
[...truncated 10425 lines...]
Running org.geoserver.importer.web.ImportTaskTableTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.915 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.355 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.374 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 25.407 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.637 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.715 s]
[INFO] Main Module ........................................ SUCCESS [02:33 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.078 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 56.258 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:54 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.584 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.791 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.880 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 50.325 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:25 min]
[INFO] KML support for GeoServer .......................... SUCCESS [01:18 min]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:49 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.979 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:43 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.113 s]
[INFO] Core UI Module ..................................... SUCCESS [01:19 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 32.347 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 13.090 s]
[INFO] Demos Module ....................................... SUCCESS [ 23.316 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.378 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.198 s]
[INFO] Security UI Core Module ............................ SUCCESS [03:28 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [02:35 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:45 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.853 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.071 s]
[INFO] Printing Module .................................... SUCCESS [ 14.088 s]
[INFO] Community Space .................................... SUCCESS [ 0.201 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.093 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:07 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.969 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.205 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.419 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.245 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.843 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.313 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.264 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.628 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.510 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.354 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.047 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.980 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.937 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SUCCESS [02:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 13.621 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.703 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.696 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.273 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.590 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 19.694 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 53.302 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.879 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.085 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.058 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.510 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 11.743 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.087 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 10.223 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.147 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.421 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.117 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.762 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.104 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.648 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.425 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [01:39 min]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.688 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.762 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.677 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.023 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 25.830 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 18.430 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.701 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.314 s]
[INFO] Importer Core Module ............................... SUCCESS [01:01 min]
[INFO] Importer REST Api Module ........................... SUCCESS [ 41.566 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.217 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 30.574 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.669 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.706 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 46.330 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 16.821 s]
[INFO] BUILD FAILURE
[INFO] Total time: 25:01 min (Wall Clock)
[INFO] Finished at: 2016-11-23T13:23:48+00:00
[INFO] Final Memory: 113M/332M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
Hudson
2
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3748/>
[...truncated 10426 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
T E S T S
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.798 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.321 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.035 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.987 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.310 s]
[INFO] Main Module ........................................ SUCCESS [02:28 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.072 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.603 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:49 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.457 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.139 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.004 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.369 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:41 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:16 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.510 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:09 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.319 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:17 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.053 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 30.818 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.767 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.041 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.919 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.039 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:22 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:46 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:16 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.027 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.069 s]
[INFO] Printing Module .................................... SUCCESS [ 14.178 s]
[INFO] Community Space .................................... SUCCESS [ 0.044 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.036 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:50 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.980 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.796 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.573 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.060 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.167 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.241 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.301 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.213 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.551 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.588 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.212 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.791 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:30 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.294 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.595 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.496 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.122 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.476 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.364 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 28.587 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.524 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.988 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 13.988 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.997 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.062 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.501 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.449 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.073 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.720 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.053 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.069 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.212 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.551 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.490 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.035 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.448 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.378 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.034 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.634 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.923 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.935 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.070 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.419 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.052 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.831 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.005 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.653 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.460 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 37.632 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.777 s]
[INFO] Total time: 20:09 min (Wall Clock)
[INFO] Finished at: 2016-11-23T14:49:31+00:00
[INFO] Final Memory: 113M/333M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
3
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3749/changes>
Changes:
[emerkle] Fix GeoGig plugin tests
[...truncated 10292 lines...]
T E S T S
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.809 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.332 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.436 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.671 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.402 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.308 s]
[INFO] Main Module ........................................ SUCCESS [02:38 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.051 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:29 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [06:18 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.144 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 22.064 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 32.636 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.277 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:41 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.533 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:06 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.016 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.711 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.041 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.387 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.570 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.716 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.050 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:24 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:45 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:15 min]
[INFO] REST UI Module ..................................... SUCCESS [ 12.938 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.031 s]
[INFO] Printing Module .................................... SUCCESS [ 15.911 s]
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.416 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.653 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.821 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.080 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.443 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.242 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.238 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.998 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.466 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.295 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.036 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.045 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.553 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.036 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:32 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.930 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.966 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.495 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.581 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.473 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.951 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 28.075 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.739 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.940 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.090 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.259 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.972 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.408 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.549 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.404 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.027 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.259 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.786 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.135 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.051 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.242 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.500 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.031 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.138 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.874 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.142 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.609 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 35.805 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.797 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.440 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.158 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.855 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.502 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.452 s]
[INFO] Total time: 22:36 min (Wall Clock)
[INFO] Finished at: 2016-11-23T16:05:06+00:00
[INFO] Final Memory: 113M/308M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Hudson
4
