[Geoserver-devel] Build failed in Jenkins: geoserver-master #3786
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3786/changes&gt;
Changes:
[gabriel.roldan] Update geogig plugin with latest functional test changes.
[...truncated 14948 lines...]
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-rest ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-rest ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-gdal-wps ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-gdal-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-gdal-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-gdal-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-gdal-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-gdal-wps ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.11-SNAPSHOT/gs-gdal-wps-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.11-SNAPSHOT/gs-gdal-wps-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.11-SNAPSHOT/gs-gdal-wps-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.11-SNAPSHOT/gs-gdal-wps-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/gdal/gdal-wps/target/gs-gdal-wps-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-gdal-wps/2.11-SNAPSHOT/gs-gdal-wps-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Extensions 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-extension ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-extension ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.11-SNAPSHOT/gs-backup-restore-extension-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.11-SNAPSHOT/gs-backup-restore-rest-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.11-SNAPSHOT/gs-backup-restore-rest-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.11-SNAPSHOT/gs-backup-restore-rest-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.11-SNAPSHOT/gs-backup-restore-rest-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.11-SNAPSHOT/gs-backup-restore-rest-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.11-SNAPSHOT/gs-backup-restore-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.11-SNAPSHOT/gs-backup-restore-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.11-SNAPSHOT/gs-backup-restore-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.11-SNAPSHOT/gs-backup-restore-web-2.11-SNAPSHOT-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 7.221 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 12.712 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 5.706 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.779 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.298 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 5.814 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 4.026 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.867 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.788 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.330 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 27.950 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 8.540 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 5.599 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.902 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.674 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.426 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 9.732 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.543 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.420 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.047 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.915 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.970 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.134 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.042 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.781 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 5.875 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 3.003 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 11.521 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.732 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.300 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 6.180 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.337 s]
[INFO] GeoFence Server .................................... SUCCESS [ 7.190 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.887 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.010 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.000 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.183 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.384 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.529 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.419 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.045 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 6.660 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 6.271 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 5.272 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 5.526 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 4.907 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 12.997 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.088 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 6.894 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 4.947 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.563 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.220 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 6.665 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 19.532 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.259 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.041 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.070 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 5.872 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 5.614 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:10 min (Wall Clock)
[INFO] Finished at: 2016-12-15T19:32:13+00:00
[INFO] Final Memory: 135M/350M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geogig: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java&gt;:\[406,1\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java&gt;:\[411,1\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/test/java/org/geogig/geoserver/functional/GeoServerFunctionalTestContext.java&gt;:\[421,1\] error: method does not override or implement a method from a supertype
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3787/changes&gt;
Changes:
[jody.garnett] Fix the NPE message when requesting the WPS GetCapabilities
[jody.garnett] Remove unneccessary imports & give appropriate test name
[...truncated 14928 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-jms-geoserver ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-jms-geoserver ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-jms-geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.11-SNAPSHOT/gs-jms-geoserver-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/jms-geoserver/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.11-SNAPSHOT/gs-jms-geoserver-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.11-SNAPSHOT/gs-jms-geoserver-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.11-SNAPSHOT/gs-jms-geoserver-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/jms-cluster/jms-geoserver/target/gs-jms-geoserver-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-jms-geoserver/2.11-SNAPSHOT/gs-jms-geoserver-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Community Space .................................... SUCCESS [ 9.528 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 10.522 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 6.614 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 5.664 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 11.335 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.263 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 5.747 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.375 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.733 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 27.644 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.037 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.159 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 3.864 s]
[INFO] WMS-EO ............................................. SUCCESS [ 6.670 s]
[INFO] ColorMap ........................................... SUCCESS [ 5.178 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 9.913 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 5.599 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.246 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 6.128 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.833 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.536 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.206 s]
[INFO] DownloadProcess .................................... SUCCESS [ 5.834 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.027 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.813 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.669 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 12.425 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.708 s]
[INFO] Solr Module ........................................ SUCCESS [ 7.193 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.109 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.590 s]
[INFO] GeoFence Server .................................... SUCCESS [ 7.592 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.771 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.904 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.348 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.605 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.174 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.482 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.045 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.019 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.454 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.153 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 4.954 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 5.165 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [01:04 min]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 11.016 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.044 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 6.757 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.432 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.473 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.172 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 5.425 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 18.964 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 4.461 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 4.357 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 4.435 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 4.543 s]
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 4.712 s]
[INFO] Total time: 03:35 min (Wall Clock)
[INFO] Finished at: 2016-12-16T01:57:11+00:00
[INFO] Final Memory: 135M/425M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3788/changes&gt;
