[Geoserver-devel] Build failed in Jenkins: geoserver-master #3822
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3822/changes&gt;
Changes:
[andrea.aime] Follow up on [GEOT-5615] changes
[...truncated 6946 lines...]
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
Jan 13, 2017 11:21:34 AM com.hazelcast.initializer
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
Jan 13, 2017 11:21:34 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 13 ms.
Jan 13, 2017 11:21:34 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Jan 13, 2017 11:21:34 AM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
Jan 13, 2017 11:21:34 AM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Jan 13, 2017 11:21:34 AM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
  Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Jan 13, 2017 11:21:34 AM com.hazelcast.cluster.ClusterService
Members [2] {
  Member [127.0.0.1]:5012
Members [2] {
  Member [127.0.0.1]:5012 this
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.883 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT.pom
Jan 13, 2017 11:21:35 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Jan 13, 2017 11:21:35 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Jan 13, 2017 11:21:35 AM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT-test-sources.jar
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Jan 13, 2017 11:21:35 AM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Jan 13, 2017 11:21:35 AM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Jan 13, 2017 11:21:35 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 19 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 15 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.92 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.936 s]
[INFO] Core Platform Module ............................... SUCCESS [ 23.236 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.522 s]
[INFO] Main Module ........................................ SUCCESS [02:34 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.678 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:57 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.768 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.553 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.398 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.550 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:46 min]
[INFO] Web Map Service Module ............................. FAILURE [02:08 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SUCCESS [ 16.469 s]
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.087 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 12.496 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.043 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.031 s]
[INFO] Printing Module .................................... SUCCESS [ 14.797 s]
[INFO] Community Space .................................... SUCCESS [ 0.087 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.922 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.372 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.066 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.102 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.459 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.472 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.443 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.402 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.281 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.069 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.483 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.921 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.030 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:30 min]
[INFO] OGR WPS ............................................ SUCCESS [ 12.469 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.191 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.896 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.090 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.515 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.787 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.614 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.998 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.232 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.449 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.111 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.087 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.281 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.395 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.096 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.076 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.279 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.110 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.043 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 21.443 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.836 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.125 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 12:24 min (Wall Clock)
[INFO] Finished at: 2017-01-13T11:21:35+00:00
[INFO] Final Memory: 103M/360M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3823/&gt;
[...truncated 6977 lines...]
Jan 13, 2017 11:40:12 AM com.hazelcast.initializer
Jan 13, 2017 11:40:12 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 17 ms.
Jan 13, 2017 11:40:12 AM com.hazelcast.core.LifecycleService
Jan 13, 2017 11:40:12 AM com.hazelcast.spi.impl.BasicOperationScheduler
Jan 13, 2017 11:40:12 AM com.hazelcast.system
Jan 13, 2017 11:40:12 AM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
Jan 13, 2017 11:40:12 AM com.hazelcast.cluster.ClusterService
Members [2] {
Members [2] {
Jan 13, 2017 11:40:13 AM com.hazelcast.core.LifecycleService
Jan 13, 2017 11:40:13 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jan 13, 2017 11:40:13 AM com.hazelcast.partition.InternalPartitionService
Jan 13, 2017 11:40:13 AM com.hazelcast.cluster.ClusterService
Members [1] {
Jan 13, 2017 11:40:13 AM com.hazelcast.initializer
Jan 13, 2017 11:40:13 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 14 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.888 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.641 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.981 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.373 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.228 s]
[INFO] Main Module ........................................ SUCCESS [02:30 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.058 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 56.696 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:51 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.064 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.300 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.335 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.306 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. FAILURE [02:11 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.405 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.042 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.341 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.057 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.338 s]
[INFO] Printing Module .................................... SUCCESS [ 14.401 s]
[INFO] Community Space .................................... SUCCESS [ 0.315 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.606 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.706 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.381 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.534 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.447 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.250 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.246 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.894 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.322 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.978 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.041 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.233 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.027 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.481 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.367 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.513 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.674 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.685 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.174 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.047 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.351 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.044 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.384 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.200 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.938 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.671 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.041 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.565 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.814 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.793 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.240 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.956 s]
[INFO] Total time: 11:59 min (Wall Clock)
[INFO] Finished at: 2017-01-13T11:40:17+00:00
[INFO] Final Memory: 102M/366M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3824/changes&gt;
Changes:
[andrea.aime] [GEOS-7929] WMS 1.3.0 GetCapabilities response doesn't validate against
[...truncated 9824 lines...]
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.819 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.921 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT.jar&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.328 sec
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-sources.jar&gt;
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.844 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.458 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.167 s]
[INFO] Main Module ........................................ SUCCESS [02:39 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.047 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.272 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:10 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.582 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.881 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.326 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.153 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:41 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:18 min]
[INFO] KML support for GeoServer .......................... FAILURE [ 8.496 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 15.354 s]
[INFO] REST Support Module ................................ SUCCESS [ 16.396 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:11 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.040 s]
[INFO] Core UI Module ..................................... SUCCESS [01:22 min]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.290 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.859 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.439 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.201 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.051 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:23 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:44 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:13 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.231 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] Printing Module .................................... SUCCESS [ 13.433 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.884 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.413 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.162 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.228 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.517 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.490 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.242 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.097 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.619 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.302 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.022 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.290 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.804 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] OGR WPS ............................................ SUCCESS [ 11.570 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.720 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.495 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.235 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.467 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.655 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.708 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.532 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.958 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.048 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 14.493 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.146 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.090 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.434 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.374 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.342 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.724 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.037 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.573 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.086 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.981 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.325 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.022 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.304 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.651 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.030 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.882 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.528 s]
[INFO] GeoServer libjpeg-turbo Module ..................... FAILURE [ 4.458 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.131 s]
[INFO] Importer Core Module ............................... SUCCESS [ 43.780 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.350 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.855 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.698 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.591 s]
[INFO] NetCDF Coverage format ............................. FAILURE [ 4.681 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 14.483 s]
[INFO] Total time: 19:27 min (Wall Clock)
[INFO] Finished at: 2017-01-13T13:27:45+00:00
[INFO] Final Memory: 113M/294M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-kml: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-libjpeg-turbo: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-netcdf: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-kml
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3825/&gt;
[...truncated 9732 lines...]
[INFO]
T E S T S
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.131 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.792 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.322 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.591 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.002 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.437 s]
[INFO] Main Module ........................................ SUCCESS [02:31 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.054 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 59.563 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:56 min]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.729 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.336 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.533 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:45 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:13 min]
[INFO] KML support for GeoServer .......................... FAILURE [ 8.005 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 15.192 s]
[INFO] REST Support Module ................................ SUCCESS [ 16.415 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:15 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.055 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 30.557 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.867 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.201 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.300 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.046 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:22 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:12 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.529 s]
[INFO] Printing Module .................................... SUCCESS [ 13.330 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:50 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.081 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.173 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.319 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.061 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.445 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.240 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.261 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.179 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.996 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.251 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.952 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.905 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:27 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.337 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.242 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.452 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.977 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.459 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 13.011 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 31.462 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.312 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.004 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 14.892 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.903 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.926 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.283 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.727 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.085 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.956 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.545 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.437 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.409 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.030 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.363 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.809 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.481 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.624 s]
[INFO] GeoServer libjpeg-turbo Module ..................... FAILURE [ 4.290 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.052 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.205 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 35.452 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.998 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.472 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.759 s]
[INFO] NetCDF Coverage format ............................. FAILURE [ 4.990 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.068 s]
[INFO] Total time: 19:00 min (Wall Clock)
[INFO] Finished at: 2017-01-13T14:36:36+00:00
[INFO] Final Memory: 113M/422M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3826/&gt;
[...truncated 156410 lines...]
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Jan 13, 2017 6:30:55 PM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.807 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.317 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.494 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.117 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.970 s]
[INFO] Main Module ........................................ SUCCESS [02:35 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.086 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 56.829 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.238 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.323 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.664 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 50.423 s]
[INFO] Web Map Service Module ............................. SUCCESS [02:15 min]
[INFO] KML support for GeoServer .......................... FAILURE [ 8.514 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [ 13.944 s]
[INFO] REST Support Module ................................ SUCCESS [ 16.045 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 1.497 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 30.981 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.580 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.203 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.559 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.186 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:24 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:47 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:11 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.309 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] Printing Module .................................... SUCCESS [ 13.104 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.554 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.449 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.525 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.083 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.457 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.239 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.243 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.432 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.519 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.266 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.027 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.930 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.260 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:36 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.190 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.667 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.519 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.540 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.498 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.817 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 31.606 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.085 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.291 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.506 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.226 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.047 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.676 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.433 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.185 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.533 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.184 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.855 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.280 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.431 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.052 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.698 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.090 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.039 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.563 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.354 s]
[INFO] GeoServer libjpeg-turbo Module ..................... FAILURE [ 4.386 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.051 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.389 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 35.054 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.353 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.668 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.291 s]
[INFO] NetCDF Coverage format ............................. FAILURE [ 4.594 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.946 s]
[INFO] Total time: 19:15 min (Wall Clock)
[INFO] Finished at: 2017-01-13T18:30:58+00:00
[INFO] Final Memory: 113M/293M
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3827/changes&gt;
Changes:
[andrea.aime] GEOS-7929 using reflection to load the wms 1.3 configuration to avoid
[...truncated 95647 lines...]
Jan 14, 2017 10:45:42 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jan 14, 2017 10:45:42 AM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Jan 14, 2017 10:45:42 AM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTTING_DOWN
Jan 14, 2017 10:45:42 AM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Master Address[127.0.0.1]:5009 left the cluster. Assigning new master Member [127.0.0.1]:5010 this
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Removing Member [127.0.0.1]:5009
Members [1] {
Jan 14, 2017 10:45:42 AM com.hazelcast.initializer
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Destroying node initializer.
Jan 14, 2017 10:45:42 AM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Hazelcast Shutdown is completed in 23 ms.
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Address[127.0.0.1]:5009 is SHUTDOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 14 ms.
Jan 14, 2017 10:45:42 AM com.hazelcast.spi.impl.BasicOperationScheduler
Jan 14, 2017 10:45:42 AM com.hazelcast.system
Jan 14, 2017 10:45:42 AM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
Members [2] {
Members [2] {
Jan 14, 2017 10:45:43 AM com.hazelcast.core.LifecycleService
Jan 14, 2017 10:45:43 AM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
Jan 14, 2017 10:45:43 AM com.hazelcast.partition.InternalPartitionService
Jan 14, 2017 10:45:48 AM com.hazelcast.core.LifecycleService
Jan 14, 2017 10:45:48 AM com.hazelcast.cluster.ClusterService
Members [1] {
Jan 14, 2017 10:45:48 AM com.hazelcast.initializer
Jan 14, 2017 10:45:48 AM com.hazelcast.instance.Node
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.854 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 21.174 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.139 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.032 s]
[INFO] Main Module ........................................ SUCCESS [02:53 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.060 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.279 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:50 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.014 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.116 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.065 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.684 s]
[INFO] Web Map Service Module ............................. FAILURE [02:14 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.740 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.066 s]
[INFO] Core UI Module ..................................... SUCCESS [01:19 min]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.994 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.029 s]
[INFO] Printing Module .................................... SUCCESS [ 14.730 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.327 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.736 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.968 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.075 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.458 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.247 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.636 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.842 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.038 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.037 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.026 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:32 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.258 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.201 s]
[INFO] Chart external graphics support .................... SUCCESS [ 2.203 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.243 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 27.222 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.869 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.284 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.185 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.564 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.863 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.320 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.740 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.055 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.837 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.758 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.316 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.153 s]
[INFO] Total time: 12:48 min (Wall Clock)
[INFO] Finished at: 2017-01-14T10:45:48+00:00
[INFO] Final Memory: 103M/366M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3828/changes&gt;
Changes:
[andrea.aime] More logging to investigate the concurrent cache issue
[...truncated 94899 lines...]
Jan 14, 2017 11:19:51 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Jan 14, 2017 11:19:51 AM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'sf', enabled
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.365 sec
INFO: Loaded feature type 'GenericEntity', enabled
INFO: Loaded feature type 'PrimitiveGeoFeature', enabled
INFO: Loaded feature type 'AggregateGeoFeature', enabled
INFO: Loaded store 'cite', enabled
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
Results :
Failed tests: testAsyncExecutionLimit(org.geoserver.wps.InputLimitsTest): Expecting to find matches for Xpath //ows:ExceptionText[contains(., 'maxExecutionTime 2 seconds, maxTotalTime 3 seconds')]
Tests run: 247, Failures: 1, Errors: 0, Skipped: 2
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO]
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
INFO: Loaded feature type 'Lakes', enabled
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping DXF WPS PPIO
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Inserts', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded feature type 'Deletes', enabled
INFO: Loaded feature type 'Updates', enabled
INFO: Loaded feature type 'Seven', enabled
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.44 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.690 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.475 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.517 s]
[INFO] Main Module ........................................ SUCCESS [03:05 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.056 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.564 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.398 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.978 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.716 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.055 s]
[INFO] Web Map Service Module ............................. FAILURE [02:15 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.904 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.045 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.425 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 4.271 s]
[INFO] Printing Module .................................... SUCCESS [ 13.963 s]
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.492 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.656 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.291 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.696 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.269 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.257 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.497 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.294 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.029 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.958 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.788 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:39 min]
[INFO] Excel Output Format ................................ SUCCESS [ 14.676 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.472 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.993 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 2.526 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.530 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.899 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.129 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.063 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.008 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 13.161 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 45.693 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.715 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.026 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.459 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.019 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.050 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.680 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.173 s]
[INFO] Total time: 12:27 min (Wall Clock)
[INFO] Finished at: 2017-01-14T11:19:54+00:00
[INFO] Final Memory: 102M/343M
[ERROR]
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3829/&gt;
[...truncated 95743 lines...]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT-test-sources.jar
Jan 14, 2017 12:00:06 PM com.hazelcast.core.LifecycleService
Jan 14, 2017 12:00:06 PM com.hazelcast.cluster.ClusterService
Members [1] {
Jan 14, 2017 12:00:06 PM com.hazelcast.initializer
Jan 14, 2017 12:00:06 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5009 [dev] [3.3.1] Hazelcast Shutdown is completed in 22 ms.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
Jan 14, 2017 12:00:06 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
Jan 14, 2017 12:00:06 PM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
Jan 14, 2017 12:00:06 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
  Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Members [2] {
  Member [127.0.0.1]:5012
Members [2] {
  Member [127.0.0.1]:5012 this
Jan 14, 2017 12:00:07 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Jan 14, 2017 12:00:07 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Jan 14, 2017 12:00:07 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Jan 14, 2017 12:00:07 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Jan 14, 2017 12:00:07 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Jan 14, 2017 12:00:07 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 17 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.865 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.620 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.108 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.340 s]
[INFO] Main Module ........................................ SUCCESS [02:33 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.051 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:01 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:01 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.245 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.599 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.864 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.191 s]
[INFO] Web Map Service Module ............................. FAILURE [02:11 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SUCCESS [ 16.230 s]
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.054 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 12.952 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.256 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.036 s]
[INFO] Printing Module .................................... SUCCESS [ 13.780 s]
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.482 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.893 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.390 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.181 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 2.251 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.265 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.238 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.342 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.317 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.025 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.070 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.096 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.032 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.705 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.348 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.470 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.164 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.486 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.773 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.709 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.421 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.569 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.085 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.838 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.736 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.374 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.028 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.660 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 9.859 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.025 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.404 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.436 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.949 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 12:17 min (Wall Clock)
[INFO] Finished at: 2017-01-14T12:00:07+00:00
[INFO] Final Memory: 102M/358M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3830/&gt;
