[Geoserver-devel] Build failed in Jenkins: geoserver-master #385
See <http://ares.opengeo.org/jenkins/job/geoserver-master/385/changes&gt;
Changes:
[andrea.aime] [GEOS-5511] Help icons on various GWC pages do nothing (icons removed, they have been confusing users long enough)
[...truncated 25774 lines...]
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
Running org.geoserver.gwc.web.layer.LayerEditCacheOptionsTabPanelInfoTest
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-wps ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-web-wps ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-wps ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5511] Help icons on various GWC pages do nothing (icons removed, they have been confusing users long enough)
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.03.2014 @ 16:52:27 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Mar-2014 16:59
[INFO] [GitCommitIdMojo] build.build.time = 19.03.2014 @ 17:25:50 UTC
[INFO] [GitCommitIdMojo] build.branch = 48d9ff7828f954dfaca6749b2f373231c6aeb83e
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 48d9ff7
[INFO] [GitCommitIdMojo] build.commit.id = 48d9ff7828f954dfaca6749b2f373231c6aeb83e
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5511] Help icons on various GWC pages do nothing (icons removed, they have been confusing users long enough)
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-wps ---
[INFO] Copying 10 resources
[INFO] Copying 9 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-wps ---
[INFO] Compiling 17 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/classes&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.358 sec
Running org.geoserver.gwc.web.layer.NewCachedLayerPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.976 sec
Results :
Failed tests: testPageLoad(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest)
Tests in error:
  testSaveExisting(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): path: 'form:panel' does not exist for page: GeoServerErrorPage
  testRemoveExisting(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): path: 'form:panel' does not exist for page: GeoServerErrorPage
  testSaveNew(org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest): path: 'form:panel' does not exist for page: GeoServerErrorPage
Tests run: 27, Failures: 1, Errors: 3, Skipped: 0
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-wps ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-wps ---
[INFO] Compiling 3 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-wps ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wps.web.WPSAdminPageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.450s]
[INFO] Core Platform Module .............................. SUCCESS [5.414s]
[INFO] Open Web Service Module ........................... SUCCESS [12.677s]
[INFO] Main Module ....................................... SUCCESS [2:30.158s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.091s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:06.613s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [43.017s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.527s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:06.448s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.440s]
[INFO] Web Coverage Service 2.0 Module ................... SUCCESS [1:46.148s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:44.214s]
[INFO] Web Map Service Module ............................ SUCCESS [4:27.066s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:11.927s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:36.064s]
[INFO] REST Support Module ............................... SUCCESS [39.558s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:51.694s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.415s]
[INFO] Core UI Module .................................... SUCCESS [2:07.144s]
[INFO] WMS UI Module ..................................... SUCCESS [1:01.317s]
[INFO] GWC UI Module ..................................... FAILURE [1:12.630s]
[INFO] WFS UI Module ..................................... SUCCESS [36.674s]
[INFO] Demoes Module ..................................... SUCCESS [54.016s]
[INFO] WCS UI Module ..................................... SUCCESS [47.564s]
[INFO] Security UI Modules ............................... SUCCESS [0.621s]
[INFO] Security UI Core Module ........................... SUCCESS [3:32.039s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.309s]
[INFO] Printing Module ................................... SUCCESS [20.763s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.036s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.240s]
[INFO] Application Schema Support ........................ SUCCESS [0.307s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.640s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [24.160s]
[INFO] GeoSearch Index Module ............................ SUCCESS [42.548s]
[INFO] H2 DataStore Extension ............................ SUCCESS [19.410s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.296s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.861s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.605s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.531s]
[INFO] ImageMap Output Format ............................ SUCCESS [15.194s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.519s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.797s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [31.054s]
[INFO] Excel Output Format ............................... SUCCESS [35.891s]
[INFO] Validation Module ................................. SUCCESS [2.482s]
[INFO] Chart external graphics support ................... SUCCESS [2.096s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.228s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.091s]
[INFO] OWS request flow controller ....................... SUCCESS [21.320s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.473s]
[INFO] Web Processing Service Module ..................... SUCCESS [4:03.773s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [42.352s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.711s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.244s]
[INFO] Core Monitor Extension ............................ SUCCESS [21.017s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [47.741s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [34.292s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.414s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.874s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [21.357s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:44.848s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.420s]
[INFO] DXF output format ................................. SUCCESS [34.079s]
[INFO] DXF WPS PPIO ...................................... SUCCESS [35.079s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.242s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [41.726s]
[INFO] GeoServer libjpeg-turbo Module .................... SUCCESS [31.088s]
[INFO] GeoServer Data Importer ........................... SUCCESS [0.374s]
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 26:11.543s (Wall Clock)
[INFO] Finished at: Wed Mar 19 17:25:59 UTC 2014
[INFO] Final Memory: 62M/227M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-gwc
See <http://ares.opengeo.org/jenkins/job/geoserver-master/386/changes&gt;
