[Geoserver-devel] Build failed in Jenkins: geoserver-master #3855
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3855/changes&gt;
Changes:
[jody.garnett] Revert "Adding default CORS support"
[jody.garnett] Adding CORS support by default
Started by user Hudson
Started by an SCM change
Building in workspace <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/&gt;
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url git://github.com/geoserver/geoserver.git # timeout=10
Fetching upstream changes from git://github.com/geoserver/geoserver.git
> git --version # timeout=10
> git -c core.askpass=true fetch --tags --progress git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision cafc00612568c959bd53c33201202cc9ff52bbb7 (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f cafc00612568c959bd53c33201202cc9ff52bbb7
> git rev-list fda2d4d82e6435bca9eb0a6b4a41f5c7f10666dd # timeout=10
[geoserver-master] $ /opt/apache-maven-3.3.9/bin/mvn -f src/pom.xml -B -U -P allExtensions,printing,secJdbcJndiTest clean install -DconfigDirectory=../../../data -T2 -fae -DquietTests=false
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
[INFO] Scanning for projects...
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[ERROR] 'dependencies.dependency.version' for org.eclipse.jetty:jetty-servlets:jar is missing. @ line 180, column 17
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: org.geoserver.extension:gs-ogr-wfs:jar:tests -> duplicate declaration of version ${gs.version} @ org.geoserver.extension:gs-ogr-wps:[unknown-version], <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/ogr/ogr-wps/pom.xml,&gt; line 62, column 21
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-wps-core:${gs.version}, <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/pom.xml,&gt; line 21, column 14
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-wps-cluster-hazelcast:${gs.version}, <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml,&gt; line 19, column 12
[WARNING] 'version' contains an expression but should be a constant. @ org.geoserver.extension:gs-web-wps:${gs.version}, <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/web-wps/pom.xml,&gt; line 21, column 14
[WARNING] 'dependencies.dependency.(groupId:artifactId:type:classifier)' must be unique: org.springframework:spring-test:jar -> version ${spring.version} vs (?) @ org.geoserver.extension:gs-monitor:[unknown-version], <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/monitor/pom.xml,&gt; line 67, column 15
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project org.geoserver.web:gs-web-app:2.11-SNAPSHOT (<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml)> has 1 error
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3856/changes&gt;
