[Geoserver-devel] Build failed in Jenkins: geoserver-master #3874
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3874/changes&gt;
Changes:
[bradh] [GEOS-7914] Provide WFS 2.0.0 exceptions in JSON if requested.
[andrea.aime] [GEOS-7953] GSIP 155 - Core improvements for catalogs with many layers
[...truncated 175012 lines...]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Jan 28, 2017 11:36:43 AM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.804 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.345 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 15.805 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.214 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.845 s]
[INFO] Main Module ........................................ SUCCESS [02:34 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.075 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.906 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:57 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.584 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.749 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.061 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.051 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:44 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:14 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.965 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.011 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:16 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.043 s]
[INFO] Core UI Module ..................................... SUCCESS [01:24 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.034 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.506 s]
[INFO] WMS UI Module ...................................... FAILURE [ 33.544 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.162 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.635 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.983 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.178 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.069 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:24 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:44 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:13 min]
[INFO] REST UI Module ..................................... SUCCESS [ 12.871 s]
[INFO] Printing Module .................................... SUCCESS [ 13.643 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:51 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.442 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.117 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.972 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.071 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.442 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.242 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.267 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.824 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.606 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.319 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.030 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.144 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.937 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:32 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.020 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.503 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.468 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.458 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.517 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 14.991 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.915 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.184 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.994 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.110 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.144 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.928 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.163 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.059 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.283 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.124 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.169 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.062 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.343 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.194 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.968 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.134 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.723 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.600 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.791 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.110 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.185 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.053 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.577 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 35.413 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.457 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.939 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.421 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.047 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.834 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 12.192 s]
[INFO] BUILD FAILURE
[INFO] Total time: 21:18 min (Wall Clock)
[INFO] Finished at: 2017-01-28T11:36:46+00:00
[INFO] Final Memory: 115M/329M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-wms
Looking into it, it’s weird, StyleEditPageTest.testLayerAttributesUnreachableLayer fails
because it does not find the expected error message.
And debugging, the error message is generated and set, but somehow it’s not reaching the feedback panel.
On Sat, Jan 28, 2017 at 12:36 PM, <monitor@anonymised.com> wrote:
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3874/changes>
Changes:
[…truncated 175012 lines…]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-importer-web —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec —
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target>
[INFO]
[INFO] — cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec —
[INFO] Skipping cobertura mojo for project with packaging type ‘pom’
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec —
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec —
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-sec —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas —
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes>
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas —
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
Results :
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-sec-cas —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec-cas —
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] — cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas —
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-web-sec-cas —
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-sec-cas —
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-cas —
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-sec-cas —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer … SUCCESS [ 15.805 s]
[INFO] Core Platform Module … SUCCESS [ 13.214 s]
[INFO] Open Web Service Module … SUCCESS [ 11.845 s]
[INFO] Main Module … SUCCESS [02:34 min]
[INFO] GeoServer Security Modules … SUCCESS [ 0.075 s]
[INFO] GeoServer JDBC Security Module … SUCCESS [ 57.906 s]
[INFO] GeoServer LDAP Security Module … SUCCESS [02:57 min]
[INFO] Web Coverage Service Module … SUCCESS [ 3.584 s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [ 25.749 s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [ 30.061 s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [ 48.051 s]
[INFO] Web Feature Service Module … SUCCESS [01:44 min]
[INFO] Web Map Service Module … SUCCESS [02:14 min]
[INFO] KML support for GeoServer … SUCCESS [ 32.965 s]
[INFO] GeoWebCache (GWC) Module … SUCCESS [01:10 min]
[INFO] REST Support Module … SUCCESS [ 16.011 s]
[INFO] REST Configuration Service Module … SUCCESS [01:16 min]
[INFO] GeoServer Web Modules … SUCCESS [ 0.043 s]
[INFO] Core UI Module … SUCCESS [01:24 min]
[INFO] GeoServer Extensions … SUCCESS [ 0.034 s]
[INFO] GeoServer CSS Styling … SUCCESS [ 10.506 s]
[INFO] WMS UI Module … FAILURE [ 33.544 s]
[INFO] GWC UI Module … SUCCESS [ 42.162 s]
[INFO] WFS UI Module … SUCCESS [ 13.635 s]
[INFO] Demos Module … SUCCESS [ 20.983 s]
[INFO] WCS UI Module … SUCCESS [ 15.178 s]
[INFO] Security UI Modules … SUCCESS [ 0.069 s]
[INFO] Security UI Core Module … SUCCESS [02:24 min]
[INFO] Security UI JDBC Module … SUCCESS [01:44 min]
[INFO] Security UI LDAP Module … SUCCESS [01:13 min]
[INFO] REST UI Module … SUCCESS [ 12.871 s]
[INFO] Printing Module … SUCCESS [ 13.643 s]
[INFO] GeoServer Web Application … SKIPPED
[INFO] Community Space … SUCCESS [ 0.028 s]
[INFO] Application Schema Support … SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test … SUCCESS [01:51 min]
[INFO] Sample DataAccess Integration Test … SUCCESS [ 12.442 s]
[INFO] ArcSDE DataStore Extension … SUCCESS [ 13.117 s]
[INFO] H2 DataStore Extension … SUCCESS [ 8.972 s]
[INFO] SQL Server DataStore Extension … SUCCESS [ 1.071 s]
[INFO] Oracle DataStore Extension … SUCCESS [ 0.442 s]
[INFO] MySQL DataStore Extension … SUCCESS [ 0.242 s]
[INFO] DB2 DataStore Extension … SUCCESS [ 0.267 s]
[INFO] ImageMap Output Format … SUCCESS [ 8.824 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [ 3.606 s]
[INFO] JP2K Coverage Extension … SUCCESS [ 0.319 s]
[INFO] OGR parent … SUCCESS [ 0.030 s]
[INFO] OGR CORE … SUCCESS [ 2.144 s]
[INFO] OGR WFS … SUCCESS [ 9.937 s]
[INFO] Web Processing Service parent … SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module … SUCCESS [01:32 min]
[INFO] OGR WPS … SUCCESS [ 11.020 s]
[INFO] Excel Output Format … SUCCESS [ 15.503 s]
[INFO] Chart external graphics support … SUCCESS [ 0.468 s]
[INFO] Feature Generalization Extension … SUCCESS [ 2.458 s]
[INFO] Image Mosaic JDBC Extension … SUCCESS [ 0.517 s]
[INFO] OWS request flow controller … SUCCESS [ 14.991 s]
[INFO] Web process status sharing with Hazelcast … SUCCESS [ 22.915 s]
[INFO] Web Processing Service GUI … SUCCESS [ 30.184 s]
[INFO] GeoServer Layer Querying filter functions … SUCCESS [ 16.994 s]
[INFO] Teradata DataStore Extension … SUCCESS [ 2.110 s]
[INFO] GeoServer Monitor Extensions … SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension … SUCCESS [ 15.144 s]
[INFO] Monitor Hibernate Extension … SUCCESS [ 8.928 s]
[INFO] GeoServer Security Extension Modules … SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Module … SUCCESS [ 7.163 s]
[INFO] GeoServer Security Extension Web Modules … SUCCESS [ 0.059 s]
[INFO] GeoServer CAS Security Web Module … SUCCESS [ 2.283 s]
[INFO] XLST based WFS output format … SUCCESS [ 21.124 s]
[INFO] GeoServer INSPIRE Extensions … SUCCESS [ 30.169 s]
[INFO] Catalog Services for the Web parent … SUCCESS [ 0.062 s]
[INFO] Catalog Services for the Web interfaces … SUCCESS [ 10.343 s]
[INFO] Catalog Services for the Web core module … SUCCESS [ 41.968 s]
[INFO] CSW UI Module … SUCCESS [ 12.134 s]
[INFO] DXF WFS output format and WPS PPIO … SUCCESS [ 0.021 s]
[INFO] DXF WFS output format … SUCCESS [ 14.723 s]
[INFO] DXF WPS PPIO … SUCCESS [ 10.600 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [ 0.022 s]
[INFO] GeoServer libjpeg-turbo Module … SUCCESS [ 10.185 s]
[INFO] GeoServer Data Importer … SUCCESS [ 0.053 s]
[INFO] Importer Core Module … SUCCESS [ 41.577 s]
[INFO] Importer REST Api Module … SUCCESS [ 35.413 s]
[INFO] Importer Berkley DB Persistence Module … SUCCESS [ 18.457 s]
[INFO] Importer Web UI Module … SUCCESS [ 15.939 s]
[INFO] GRIB Coverage Format … SUCCESS [ 19.421 s]
[INFO] NetCDF Coverage format … SUCCESS [ 20.047 s]
[INFO] WCS NetCDF output Module … SUCCESS [ 36.834 s]
[INFO] Vector Tiles … SUCCESS [ 12.192 s]
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/wms/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-web-wms
Build step ‘Invoke top-level Maven targets’ marked build as failure
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3875/changes&gt;
