[Geoserver-devel] Build failed in Jenkins: geoserver-master #390
See <http://ares.opengeo.org/jenkins/job/geoserver-master/390/changes&gt;
Changes:
[jody.garnett] Port LockProvider from GWC
[jody.garnett] Integration of LockProvider with Resource API
[jody.garnett] UI integration of Lock Provider (includes docs)
[...truncated 351 lines...]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-platform ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-platform ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge branch 'refs/heads/resource_lock'
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 20.03.2014 @ 22:59:45 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Mar-2014 23:34
[INFO] [GitCommitIdMojo] build.build.time = 20.03.2014 @ 23:34:23 UTC
[INFO] [GitCommitIdMojo] build.branch = 729b8399cc8f9142b27bd626d5ff0aebc9993098
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 729b839
[INFO] [GitCommitIdMojo] build.commit.id = 729b8399cc8f9142b27bd626d5ff0aebc9993098
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge branch 'refs/heads/resource_lock'
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-platform ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/target/web-2.6-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ web >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web ---
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.6-SNAPSHOT/web-2.6-SNAPSHOT.pom
[INFO] [INFO] Using 'UTF-8' encoding to copy filtered resources.
Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/target/web-2.6-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.6-SNAPSHOT/web-2.6-SNAPSHOT-tests.jar
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-platform ---
[INFO] Compiling 36 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/target/classes&gt;
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/FileLockProvider.java&gt;:\[20,38\] package org.apache.commons.codec.digest does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/FileLockProvider.java&gt;:\[21,28\] package org.apache.commons.io does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/MemoryLockProvider.java&gt;:\[13,38\] package org.apache.commons.codec.digest does not exist
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/FileLockProvider.java&gt;:\[76,24\] cannot find symbol
symbol : variable IOUtils
location: class org.geoserver.platform.resource.FileLockProvider
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/FileLockProvider.java&gt;:\[84,24\] cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/FileLockProvider.java&gt;:\[135,32\] cannot find symbol
symbol: variable IOUtils
                                IOUtils.closeQuietly(fos);
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/FileLockProvider.java&gt;:\[160,16\] cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/FileLockProvider.java&gt;:\[171,22\] cannot find symbol
symbol : variable DigestUtils
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/platform/src/main/java/org/geoserver/platform/resource/MemoryLockProvider.java&gt;:\[59,27\] cannot find symbol
location: class org.geoserver.platform.resource.MemoryLockProvider
[INFO] 9 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.172s]
[INFO] Core Platform Module .............................. FAILURE [1.540s]
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.426s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SKIPPED
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 11.531s (Wall Clock)
[INFO] Finished at: Thu Mar 20 23:34:24 UTC 2014
[INFO] Final Memory: 28M/171M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-platform: Compilation failure: Compilation failure:
[ERROR] symbol : variable IOUtils
[ERROR] location: class org.geoserver.platform.resource.FileLockProvider
[ERROR] symbol: variable IOUtils
[ERROR] IOUtils.closeQuietly(fos);
[ERROR] symbol : variable DigestUtils
[ERROR] location: class org.geoserver.platform.resource.MemoryLockProvider
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-platform
See <http://ares.opengeo.org/jenkins/job/geoserver-master/391/changes&gt;
Changes:
[niels] GeoPackage & MbTiles: Plugin Configurations
[niels] GeoPackage & MBTiles: documentation
[niels] App-schema docs: Fix formatting errors (trivial)
[...truncated 370 lines...]
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ web ---
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #528 from NielsCharlier/geopkgdoc
[INFO] [GitCommitIdMojo] build.commit.time = 21.03.2014 @ 12:13:38 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 21-Mar-2014 17:46
[INFO] [GitCommitIdMojo] build.build.time = 21.03.2014 @ 17:46:10 UTC
[INFO] [GitCommitIdMojo] build.branch = 88b01b5a1dc8eca6d2a40fbc1c0e3667ef6ac99b
[INFO] [GitCommitIdMojo] build.commit.user.email = niels@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = NielsCharlier
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 88b01b5
[INFO] [GitCommitIdMojo] build.commit.id = 88b01b5a1dc8eca6d2a40fbc1c0e3667ef6ac99b
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #528 from NielsCharlier/geopkgdoc
Geopackage: plugin configuration + documentation
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 21.03.2014 @ 17:46:11 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/target/web-2.6-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/2.6-SNAPSHOT/web-2.6-SNAPSHOT-tests.jar
[INFO] 9 errors
[INFO]
[INFO] GeoServer ......................................... SUCCESS [4.140s]
[INFO] Core Platform Module .............................. FAILURE [1.974s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.056s]
[INFO] Total time: 9.963s (Wall Clock)
[INFO] Finished at: Fri Mar 21 17:46:12 UTC 2014
[INFO] Final Memory: 27M/168M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/392/&gt;
[...truncated 364 lines...]
[INFO]
[INFO] [GitCommitIdMojo] build.timestamp = 21-Mar-2014 19:37
[INFO] [GitCommitIdMojo] build.build.time = 21.03.2014 @ 19:38:02 UTC
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] 9 errors
[INFO]
[INFO] GeoServer ......................................... SUCCESS [3.887s]
[INFO] Core Platform Module .............................. FAILURE [1.458s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.539s]
[INFO] Total time: 9.587s (Wall Clock)
[INFO] Finished at: Fri Mar 21 19:38:03 UTC 2014
[INFO] Final Memory: 27M/181M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
