See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3923/changes>
Changes:
[afabiani] - Notification Community Plugin Module
[...truncated 150011 lines...]
[INFO] Building GeoServer Security Extension Web Modules 2.11-SNAPSHOT
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-sec-cas ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-sec-cas ---
[INFO] Copying 1 resource
[INFO] Copying 14 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-sec-cas ---
[INFO] Compiling 10 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/classes>
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Feb 06, 2017 1:26:44 PM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.782 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.334 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.466 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.961 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.546 s]
[INFO] Main Module ........................................ SUCCESS [02:28 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.070 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 54.605 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:01 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.486 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.178 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.905 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 45.781 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:44 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:08 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.535 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:09 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.406 s]
[INFO] REST Configuration Service Module .................. FAILURE [01:12 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.085 s]
[INFO] Core UI Module ..................................... SUCCESS [01:22 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.118 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.565 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.550 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.452 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.606 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.687 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.247 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:18 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:38 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:13 min]
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 13.473 s]
[INFO] Community Space .................................... SUCCESS [ 0.550 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.029 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.123 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.628 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.323 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.125 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 2.504 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.244 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 2.638 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.443 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.825 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.248 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.204 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.802 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:27 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.553 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.874 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.837 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.358 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.477 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.274 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.746 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.798 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.219 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.088 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.910 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.655 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.599 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.051 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.468 s]
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.550 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.058 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.752 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.533 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 39.881 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.101 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.020 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.039 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.541 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.442 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.870 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.724 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.053 s]
[INFO] Importer Core Module ............................... SUCCESS [ 38.447 s]
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.357 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.610 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 20.242 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.399 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.010 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.193 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.533 s]
[INFO] BUILD FAILURE
[INFO] Total time: 19:19 min (Wall Clock)
[INFO] Finished at: 2017-02-06T13:26:47+00:00
[INFO] Final Memory: 115M/355M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
