[Geoserver-devel] Build failed in Jenkins: geoserver-master #3940
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3940/&gt;
[...truncated 171031 lines...]
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Feb 09, 2017 11:10:17 AM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.323 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.006 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.055 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.324 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.421 s]
[INFO] Main Module ........................................ SUCCESS [02:21 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 54.535 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:55 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.057 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.771 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.094 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 45.967 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:12 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.995 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:06 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.791 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:13 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.073 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.048 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.196 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.968 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.915 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.211 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.430 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.046 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:20 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:37 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:15 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.930 s]
[INFO] Printing Module .................................... SUCCESS [ 14.348 s]
[INFO] Community Space .................................... SUCCESS [ 0.172 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.031 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.620 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.289 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.041 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.265 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.691 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.237 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.290 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.822 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.116 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.307 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.026 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.563 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.963 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:29 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.180 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.384 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.461 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.424 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.007 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.303 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.010 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.739 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.184 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.049 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.045 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.590 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.723 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.075 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.811 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.086 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.388 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.506 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.051 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.892 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.280 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 39.732 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.887 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.271 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.380 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.862 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.340 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 12.225 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.303 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.116 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.098 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.858 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.160 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.997 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.949 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.925 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.607 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 20:01 min (Wall Clock)
[INFO] Finished at: 2017-02-09T11:10:19+00:00
[INFO] Final Memory: 115M/420M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3941/&gt;
[...truncated 171226 lines...]
Feb 09, 2017 12:29:42 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.383 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.191 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 6.972 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.730 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.957 s]
[INFO] Main Module ........................................ SUCCESS [02:17 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.056 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.289 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:57 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.129 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.500 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.565 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.970 s]
[INFO] Web Map Service Module ............................. SUCCESS [02:11 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.256 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:04 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.502 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.043 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.039 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.268 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.827 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.869 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.410 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.200 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.041 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:17 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:40 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:13 min]
[INFO] REST UI Module ..................................... SUCCESS [ 12.856 s]
[INFO] Printing Module .................................... SUCCESS [ 13.620 s]
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.489 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.422 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.121 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.093 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.438 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.278 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.244 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.131 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.526 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.290 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.132 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.646 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.035 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:28 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.271 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.109 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.519 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.034 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.492 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.974 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.932 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.417 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.676 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.883 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.047 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.208 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.836 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.110 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.348 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.379 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.172 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.530 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.593 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.295 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.315 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.452 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.261 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.000 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.581 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.236 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.075 s]
[INFO] Importer Core Module ............................... SUCCESS [ 39.441 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.131 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 17.548 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.084 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.677 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 22.601 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.932 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.309 s]
[INFO] Total time: 19:45 min (Wall Clock)
[INFO] Finished at: 2017-02-09T12:29:45+00:00
[INFO] Final Memory: 115M/314M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3942/changes&gt;
Changes:
[tbarsballe] Make applicable OWS Dispatcher utility methods accessible
[...truncated 171119 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Feb 09, 2017 6:44:29 PM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.801 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.322 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.345 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.060 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 56.958 s]
[INFO] Main Module ........................................ SUCCESS [02:57 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 52.516 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:52 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.127 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.290 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.121 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.463 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:44 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:16 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.458 s]
[INFO] REST Support Module ................................ SUCCESS [ 16.728 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:14 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.051 s]
[INFO] Core UI Module ..................................... SUCCESS [01:18 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.060 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.064 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.825 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.611 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.631 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.663 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.148 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:21 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:14 min]
[INFO] REST UI Module ..................................... SUCCESS [ 12.984 s]
[INFO] Printing Module .................................... SUCCESS [ 13.203 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.700 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.181 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.952 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.143 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 5.178 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.419 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 1.093 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.900 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 29.879 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.435 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.564 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.047 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.352 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:30 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.345 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.257 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.315 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.099 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.672 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.618 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.539 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.848 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.848 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.980 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.114 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.870 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.949 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.055 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.797 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.071 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.420 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.586 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.110 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.288 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.970 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.571 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.314 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.030 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.815 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.523 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.056 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.060 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.512 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.930 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.050 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.948 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 37.013 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.303 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.243 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.642 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 19.798 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 37.272 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.222 s]
[INFO] Total time: 21:23 min (Wall Clock)
[INFO] Finished at: 2017-02-09T18:44:32+00:00
[INFO] Final Memory: 114M/343M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
This failure looks to be caused by https://github.com/geotools/geotools/pull/1455 or https://github.com/geotools/geotools/pull/1453 ; All geoserver-master builds run after http://ares.boundlessgeo.com/jenkins/view/geotools/job/geotools-master/2006/ have failed.
Torben
On Thu, Feb 9, 2017 at 10:44 AM, <monitor@anonymised.com> wrote:
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3942/changes>
Changes:
[…truncated 171119 lines…]
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-importer-web —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec —
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target>
[INFO]
[INFO] — cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec —
[INFO] Skipping cobertura mojo for project with packaging type ‘pom’
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec —
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec —
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-sec —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas —
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes>
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas —
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
Results :
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-sec-cas —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec-cas —
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] — cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas —
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-web-sec-cas —
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-sec-cas —
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-cas —
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-sec-cas —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer … SUCCESS [ 14.345 s]
[INFO] Core Platform Module … SUCCESS [ 13.060 s]
[INFO] Open Web Service Module … SUCCESS [ 56.958 s]
[INFO] Main Module … SUCCESS [02:57 min]
[INFO] GeoServer Security Modules … SUCCESS [ 0.056 s]
[INFO] GeoServer JDBC Security Module … SUCCESS [ 52.516 s]
[INFO] GeoServer LDAP Security Module … SUCCESS [02:52 min]
[INFO] Web Coverage Service Module … SUCCESS [ 3.127 s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [ 25.290 s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [ 29.121 s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [ 47.463 s]
[INFO] Web Feature Service Module … SUCCESS [01:44 min]
[INFO] Web Map Service Module … SUCCESS [02:16 min]
[INFO] KML support for GeoServer … SUCCESS [ 33.458 s]
[INFO] GeoWebCache (GWC) Module … FAILURE [01:06 min]
[INFO] REST Support Module … SUCCESS [ 16.728 s]
[INFO] REST Configuration Service Module … SUCCESS [01:14 min]
[INFO] GeoServer Web Modules … SUCCESS [ 0.051 s]
[INFO] Core UI Module … SUCCESS [01:18 min]
[INFO] GeoServer Extensions … SUCCESS [ 0.060 s]
[INFO] GeoServer CSS Styling … SUCCESS [ 10.064 s]
[INFO] WMS UI Module … SUCCESS [ 34.825 s]
[INFO] GWC UI Module … SKIPPED
[INFO] WFS UI Module … SUCCESS [ 11.611 s]
[INFO] Demos Module … SUCCESS [ 21.631 s]
[INFO] WCS UI Module … SUCCESS [ 14.663 s]
[INFO] Security UI Modules … SUCCESS [ 0.148 s]
[INFO] Security UI Core Module … SUCCESS [02:21 min]
[INFO] Security UI JDBC Module … SUCCESS [01:37 min]
[INFO] Security UI LDAP Module … SUCCESS [01:14 min]
[INFO] REST UI Module … SUCCESS [ 12.984 s]
[INFO] Printing Module … SUCCESS [ 13.203 s]
[INFO] GeoServer Web Application … SKIPPED
[INFO] Community Space … SUCCESS [ 0.027 s]
[INFO] Application Schema Support … SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test … SUCCESS [01:49 min]
[INFO] Sample DataAccess Integration Test … SUCCESS [ 12.700 s]
[INFO] ArcSDE DataStore Extension … SUCCESS [ 12.181 s]
[INFO] H2 DataStore Extension … SUCCESS [ 9.952 s]
[INFO] SQL Server DataStore Extension … SUCCESS [ 1.143 s]
[INFO] Oracle DataStore Extension … SUCCESS [ 5.178 s]
[INFO] MySQL DataStore Extension … SUCCESS [ 0.419 s]
[INFO] DB2 DataStore Extension … SUCCESS [ 1.093 s]
[INFO] ImageMap Output Format … SUCCESS [ 8.900 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [ 29.879 s]
[INFO] JP2K Coverage Extension … SUCCESS [ 1.435 s]
[INFO] OGR parent … SUCCESS [ 0.564 s]
[INFO] OGR CORE … SUCCESS [ 2.047 s]
[INFO] OGR WFS … SUCCESS [ 10.352 s]
[INFO] Web Processing Service parent … SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module … SUCCESS [01:30 min]
[INFO] OGR WPS … SUCCESS [ 11.345 s]
[INFO] Excel Output Format … SUCCESS [ 15.257 s]
[INFO] Chart external graphics support … SUCCESS [ 1.315 s]
[INFO] Feature Generalization Extension … SUCCESS [ 2.099 s]
[INFO] Image Mosaic JDBC Extension … SUCCESS [ 0.672 s]
[INFO] OWS request flow controller … SUCCESS [ 9.618 s]
[INFO] Web process status sharing with Hazelcast … SUCCESS [ 23.539 s]
[INFO] Web Processing Service GUI … SUCCESS [ 29.848 s]
[INFO] GeoServer Layer Querying filter functions … SUCCESS [ 16.848 s]
[INFO] Teradata DataStore Extension … SUCCESS [ 1.980 s]
[INFO] GeoServer Monitor Extensions … SUCCESS [ 0.114 s]
[INFO] Core Monitor Extension … SUCCESS [ 15.870 s]
[INFO] Monitor Hibernate Extension … SUCCESS [ 8.949 s]
[INFO] GeoServer Security Extension Modules … SUCCESS [ 0.055 s]
[INFO] GeoServer CAS Security Module … SUCCESS [ 6.797 s]
[INFO] GeoServer Security Extension Web Modules … SUCCESS [ 0.071 s]
[INFO] GeoServer CAS Security Web Module … SUCCESS [ 2.420 s]
[INFO] XLST based WFS output format … SUCCESS [ 19.586 s]
[INFO] GeoServer INSPIRE Extensions … SKIPPED
[INFO] Catalog Services for the Web parent … SUCCESS [ 0.110 s]
[INFO] Catalog Services for the Web interfaces … SUCCESS [ 10.288 s]
[INFO] Catalog Services for the Web core module … SUCCESS [ 41.571 s]
[INFO] CSW UI Module … SUCCESS [ 11.314 s]
[INFO] DXF WFS output format and WPS PPIO … SUCCESS [ 0.030 s]
[INFO] DXF WFS output format … SUCCESS [ 14.815 s]
[INFO] DXF WPS PPIO … SUCCESS [ 10.523 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [ 0.056 s]
[INFO] GeoServer libjpeg-turbo Module … SUCCESS [ 9.930 s]
[INFO] GeoServer Data Importer … SUCCESS [ 0.050 s]
[INFO] Importer Core Module … SUCCESS [ 40.948 s]
[INFO] Importer REST Api Module … SUCCESS [ 37.013 s]
[INFO] Importer Berkley DB Persistence Module … SUCCESS [ 19.303 s]
[INFO] Importer Web UI Module … SUCCESS [ 15.243 s]
[INFO] GRIB Coverage Format … SUCCESS [ 18.642 s]
[INFO] NetCDF Coverage format … SUCCESS [ 19.798 s]
[INFO] WCS NetCDF output Module … SUCCESS [ 37.272 s]
[INFO] Vector Tiles … SUCCESS [ 8.222 s]
[INFO] Ysld GeoServer Plugin … SKIPPED
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/gwc/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-gwc
Build step ‘Invoke top-level Maven targets’ marked build as failure
Hi Torben,
yep, Ugo is working on a fix for the GeoServer side, and I think a GWC pull request is also incoming (tomorrow I’m afraid, it’s past 8PM around here).
Torben
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Changes:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Good to know someone is aware of it, thanks.
Torben
On Thu, Feb 9, 2017 at 11:13 AM, Andrea Aime <andrea.aime@anonymised.com268…> wrote:
Hi Torben,
On Thu, Feb 9, 2017 at 7:57 PM, Torben Barsballe <tbarsballe@anonymised.com> wrote:
Torben
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Changes:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[ERROR]
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3943/changes&gt;
Changes:
[andrea.aime] Parallelize loading GWC tile layer config files by using parallel
[...truncated 171153 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Feb 09, 2017 7:28:03 PM org.geoserver.security.cas.LiveCasData disableTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 1.03 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.338 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.006 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.223 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.535 s]
[INFO] Main Module ........................................ SUCCESS [02:53 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.060 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 51.688 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:56 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.710 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.367 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 27.757 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.222 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:52 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:08 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.517 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:05 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.041 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.041 s]
[INFO] Core UI Module ..................................... SUCCESS [01:25 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.035 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.067 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.849 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.796 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.414 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.718 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.043 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:19 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:38 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.532 s]
[INFO] Printing Module .................................... SUCCESS [ 13.260 s]
[INFO] Community Space .................................... SUCCESS [ 0.029 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.212 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.298 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.984 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.058 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.439 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.232 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.148 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 8.228 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.280 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.031 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.062 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.767 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.031 s]
[INFO] OGR WPS ............................................ SUCCESS [ 10.525 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.770 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.452 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.127 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.448 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 28.719 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.493 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.673 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.950 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.041 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 14.923 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.200 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.091 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.265 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.647 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.858 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.077 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.136 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.967 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.007 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.910 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.831 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.460 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.108 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.053 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.292 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 37.891 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.694 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.457 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.380 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.959 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.004 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.567 s]
[INFO] Total time: 20:38 min (Wall Clock)
[INFO] Finished at: 2017-02-09T19:28:06+00:00
[INFO] Final Memory: 114M/324M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3944/&gt;
[...truncated 171286 lines...]
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Feb 10, 2017 12:25:40 AM org.geoserver.security.cas.LiveCasData disableTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.795 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.32 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 17.857 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.798 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.527 s]
[INFO] Main Module ........................................ SUCCESS [02:20 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.057 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 49.497 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:24 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.723 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.864 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.368 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.385 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:20 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.093 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:03 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.645 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.057 s]
[INFO] Core UI Module ..................................... SUCCESS [01:23 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.784 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 36.083 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.195 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.405 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 17.198 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.039 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:18 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:39 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:37 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.321 s]
[INFO] Printing Module .................................... SUCCESS [ 13.611 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.396 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.579 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.411 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.078 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.447 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.243 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.103 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.459 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.296 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.049 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.107 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.205 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.028 s]
[INFO] OGR WPS ............................................ SUCCESS [ 10.765 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.514 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.462 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.677 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.473 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.265 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.031 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 31.077 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.370 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.090 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.048 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.637 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.125 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.181 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.331 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.941 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.041 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.801 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.983 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.261 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.487 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.464 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.470 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.015 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.126 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.971 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.065 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.350 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 37.069 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.280 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.931 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.383 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.893 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 38.651 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.569 s]
[INFO] Total time: 20:40 min (Wall Clock)
[INFO] Finished at: 2017-02-10T00:25:43+00:00
[INFO] Final Memory: 115M/338M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3945/&gt;
[...truncated 171152 lines...]
Feb 10, 2017 2:18:33 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
Feb 10, 2017 2:18:34 AM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'sf', enabled
INFO: Loaded feature type 'GenericEntity', enabled
INFO: Loaded feature type 'PrimitiveGeoFeature', enabled
INFO: Loaded feature type 'AggregateGeoFeature', enabled
INFO: Loaded store 'cite', enabled
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
INFO: Loaded feature type 'Lakes', enabled
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Inserts', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded feature type 'Deletes', enabled
INFO: Loaded feature type 'Updates', enabled
INFO: Loaded feature type 'Seven', enabled
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
Feb 10, 2017 2:18:36 AM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Feb 10, 2017 2:18:39 AM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.412 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.502 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.865 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.919 s]
[INFO] Main Module ........................................ SUCCESS [02:22 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.052 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.240 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:54 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.226 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.967 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.225 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.993 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:09 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.771 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:02 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.306 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.042 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.042 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.702 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.639 s]
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.955 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.691 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.321 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.046 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:18 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.256 s]
[INFO] Printing Module .................................... SUCCESS [ 13.788 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.570 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.087 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.135 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.485 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.242 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.277 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.665 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.172 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.327 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.025 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.199 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.118 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.123 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.790 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.468 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.433 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.504 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.010 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.607 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 31.894 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.973 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.986 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.042 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.029 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.417 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.215 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.571 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 19.595 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.302 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.604 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.843 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.408 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.029 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.281 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.078 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.029 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.123 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.381 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.008 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.856 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.848 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 20.706 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.759 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.190 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.610 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 35.807 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.127 s]
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 19:54 min (Wall Clock)
[INFO] Finished at: 2017-02-10T02:18:40+00:00
[INFO] Final Memory: 115M/305M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-gwc: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/gwc/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-gwc
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3946/&gt;
[...truncated 171112 lines...]
[INFO]
[INFO]
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Feb 10, 2017 2:45:29 AM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.79 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.841 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.237 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.984 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.291 s]
[INFO] Main Module ........................................ SUCCESS [02:28 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.080 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.190 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [04:00 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.284 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.490 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.649 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.711 s]
[INFO] Web Map Service Module ............................. SUCCESS [02:14 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.970 s]
[INFO] GeoWebCache (GWC) Module ........................... FAILURE [01:12 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.747 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:16 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.073 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.031 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.769 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 37.030 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.990 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.579 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.615 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.045 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:27 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:35 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.506 s]
[INFO] Printing Module .................................... SUCCESS [ 13.689 s]
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:52 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.512 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.097 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.134 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.075 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.626 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.247 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.248 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.856 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.984 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.265 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.269 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.303 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:33 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.628 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.175 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.527 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.548 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.462 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.331 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.019 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 31.100 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.502 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.010 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.357 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.184 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.061 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.143 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.388 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.359 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.093 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.388 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 45.670 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.740 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.817 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.220 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.061 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.766 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.243 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.052 s]
[INFO] Importer Core Module ............................... SUCCESS [ 43.366 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 39.189 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 27.710 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.789 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.275 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.716 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 38.606 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.821 s]
[INFO] Total time: 21:24 min (Wall Clock)
[INFO] Finished at: 2017-02-10T02:45:32+00:00
[INFO] Final Memory: 114M/307M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3947/&gt;
