See <http://ares.opengeo.org/jenkins/job/geoserver-master/397/changes>
Changes:
[lago.88] Moved code to geotools and imageio-ext
[...truncated 4020 lines...]
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #524 from n-lagomarsini/wmsfusermod
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 24.03.2014 @ 09:36:33 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 24-Mar-2014 09:37
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 09:41:35 UTC
[INFO] [GitCommitIdMojo] build.branch = e9c80a7163d2884c5d164f89288f17a8851e639f
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e9c80a7
[INFO] [GitCommitIdMojo] build.commit.id = e9c80a7163d2884c5d164f89288f17a8851e639f
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #524 from n-lagomarsini/wmsfusermod
[GEOS-6376] Moved wms quantizer classes from geoserver to geotools and the pngj encoder to imageio-ext
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-rest ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/rest/target/gs-rest-2.6-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-rest ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 09:41:36 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ gs-rest ---
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 29.016 sec
Running org.geoserver.wfs.DescribeFeatureTest
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/rest/target/gs-rest-2.6-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ gs-rest ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/rest/target/gs-rest-2.6-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.6-SNAPSHOT/gs-rest-2.6-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.6-SNAPSHOT/gs-rest-2.6-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/rest/target/gs-rest-2.6-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.6-SNAPSHOT/gs-rest-2.6-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/rest/target/gs-rest-2.6-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.6-SNAPSHOT/gs-rest-2.6-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/rest/target/gs-rest-2.6-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/gs-rest/2.6-SNAPSHOT/gs-rest-2.6-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Core UI Module 2.6-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Core UI Module:
[WARNING] org.apache.maven.plugins:maven-antrun-plugin:1.3
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-web-core ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/core/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-web-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-web-core ---
[INFO] [GitCommitIdMojo] build.build.time = 24.03.2014 @ 09:41:37 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-core ---
[INFO] Copying 12 resources
[INFO] Copying 372 resources
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (process-resources) @ gs-web-core ---
[INFO] Executing tasks
[INFO] Executed tasks
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-core ---
[INFO] Compiling 229 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/core/target/classes>
sf
cdf
cgf
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.906 sec
Running org.geoserver.wfs.ExternalEntitiesTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-core ---
[INFO] Copying 6 resources
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-core ---
[INFO] Compiling 57 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/core/target/test-classes>
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="2.0.0" xsi:schemaLocation="http://www.opengis.net/ows/1.1 http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd">
<ows:Exception exceptionCode="OperationParsingFailed">
<ows:ExceptionText>Request parsing failed
null</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.026 sec
Running org.geoserver.wfs.GeometrylessTest
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-core ---
[INFO] Surefire report directory: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/web/core/target/surefire-reports>
T E S T S
Running org.geoserver.web.CapabilitiesHomePagePanelTest
<wfs:GetFeature service="WFS" xmlns:wfs="http://www.opengis.net/wfs" version="1.0.0" outputFormat="GML2" xmlns:topp="http://www.openplans.org/topp" xmlns:ogc="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-basic.xsd"><wfs:Query typeName="cite:Geometryless" srsName="EPSG:900913"/></wfs:GetFeature>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.591 sec
Running org.geoserver.wfs.GeometrylessWriteTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.268 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.174 sec
Running org.geoserver.wfs.GetFeatureBboxTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.09 sec
Running org.geoserver.wfs.GetFeatureHitsIgnoreMaxFeaturesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.955 sec
Running org.geoserver.wfs.GetFeatureMissingTypesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 16.833 sec
Running org.geoserver.web.ConverterTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.583 sec
Running org.geoserver.wfs.GetFeaturePagingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.305 sec
Running org.geoserver.web.CustomGeoServerNodeIdTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.289 sec
Running org.geoserver.web.GeoServerBasePageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.424 sec
Running org.geoserver.wfs.GetFeatureTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.139 sec
Running org.geoserver.web.GeoServerConsoleFlagTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.178 sec
Running org.geoserver.wfs.GetFeatureWithLockTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.234 sec
Running org.geoserver.wfs.LockFeatureTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.73 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.101 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.877 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.133 sec
Running org.geoserver.wfs.NumDecimalsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.78 sec
Running org.geoserver.web.admin.AdminPrivilegeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.716 sec
Running org.geoserver.wfs.ReprojectionTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.546 sec
Running org.geoserver.wfs.ReprojectionWriteTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.99 sec
Running org.geoserver.web.admin.ContactPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.002 sec
Running org.geoserver.wfs.ResourceAccessManagerWFSTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.896 sec
Running org.geoserver.web.admin.CoverageAccessPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.784 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.059 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.389 sec
Running org.geoserver.wfs.RetypingTransactionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.64 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.376 sec
Running org.geoserver.wfs.SQLViewTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.253 sec
Running org.geoserver.web.data.ConfirmRemovalPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.943 sec
Running org.geoserver.web.data.layer.LayerPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.939 sec
Running org.geoserver.wfs.SecuredGetFeatureTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.12 sec
Running org.geoserver.web.data.layer.NewLayerPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.306 sec
Running org.geoserver.wfs.SrsNameTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.276 sec
Running org.geoserver.wfs.TransactionListenerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.24 sec
Running org.geoserver.web.data.layergroup.LayerGroupEditPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.462 sec
Running org.geoserver.wfs.TransactionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.882 sec
Running org.geoserver.web.data.layergroup.LayerGroupNewPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.359 sec
Running org.geoserver.web.data.layergroup.LayerGroupPageTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.223 sec
Running org.geoserver.wfs.WFSDisabledTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.575 sec
Running org.geoserver.web.data.resource.ResourceConfigurationPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.576 sec
Running org.geoserver.wfs.WFSServiceExceptionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.23 sec
Running org.geoserver.wfs.WFSXStreamLoaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.wfs.json.GeoJSONBuilderTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.geoserver.wfs.json.GeoJSONTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.539 sec
Running org.geoserver.web.data.resource.ResourceNameValidatorTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.web.data.store.CoverageStoreEditPageTest
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.358 sec
Running org.geoserver.wfs.json.GeoJsonDescribeTest
