[Geoserver-devel] Build failed in Jenkins: geoserver-master #3987
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3987/&gt;
[...truncated 9064 lines...]
[INFO]
[INFO] Skipping GWC UI Module
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Ysld GeoServer Plugin
[INFO]
[INFO] Skipping REST UI Module
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Application Schema Integration Test
[INFO]
[INFO] Skipping Importer Core Module
[INFO]
[INFO] Skipping WCS NetCDF output Module
[INFO]
[INFO] Skipping Security UI JDBC Module
[INFO]
[INFO]
[INFO] Skipping Security UI LDAP Module
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO] Skipping OGR WPS
[INFO]
[INFO] Skipping Web process status sharing with Hazelcast
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO]
[INFO] Skipping DXF WPS PPIO
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] Skipping Importer REST Api Module
[INFO]
[INFO]
[INFO] Skipping Importer Berkley DB Persistence Module
[INFO] Skipping Importer Web UI Module
[INFO]
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO] Skipping GeoServer CAS Security Module
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO]
[INFO] Skipping CSW UI Module
[INFO]
[INFO] Skipping GeoServer CAS Security Web Module
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.377 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.468 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.702 s]
[INFO] Main Module ........................................ FAILURE [02:16 min]
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SKIPPED
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.049 s]
[INFO] Core UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.034 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.369 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.453 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.283 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.237 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.735 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.350 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.020 s]
[INFO] OGR CORE ........................................... SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.505 s]
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.514 s]
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.028 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.023 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 02:53 min (Wall Clock)
[INFO] Finished at: 2017-02-18T03:26:05+00:00
[INFO] Final Memory: 102M/412M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3988/&gt;
[...truncated 165867 lines...]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.11-SNAPSHOT/gs-web-app-2.11-SNAPSHOT.war
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Feb 18, 2017 3:58:36 AM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.792 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.317 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.010 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.790 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.677 s]
[INFO] Main Module ........................................ SUCCESS [02:21 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.128 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 54.170 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:48 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.630 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.449 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.129 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.395 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:44 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:25 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.376 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:08 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.150 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:14 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.044 s]
[INFO] Core UI Module ..................................... SUCCESS [01:24 min]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.687 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.166 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 44.650 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.746 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.736 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.977 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.043 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:20 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:37 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:33 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.183 s]
[INFO] Printing Module .................................... SUCCESS [ 13.888 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 7.349 s]
[INFO] Community Space .................................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:53 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.764 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.761 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.157 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.062 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.442 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.276 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.243 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.321 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.584 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.259 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.026 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.223 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.569 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:29 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.710 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.853 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.469 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.181 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.495 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.751 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.608 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 31.744 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.221 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.065 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.048 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.042 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.208 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.076 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.501 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.080 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.340 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.068 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.281 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.046 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.247 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.272 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.097 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.455 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.889 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.449 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.201 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.004 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.422 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.056 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.709 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 35.404 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.816 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.787 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.936 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.662 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 6.768 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.820 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.846 s]
[INFO] Total time: 21:21 min (Wall Clock)
[INFO] Finished at: 2017-02-18T03:58:39+00:00
[INFO] Final Memory: 119M/353M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-netcdf-out: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[19,24\] error: cannot find symbol
[ERROR] package org.geotools.data
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[20,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[69,39\] error: cannot find symbol
[ERROR] class AbstractDataStore
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStoreFactory.java&gt;:\[20,15\] error: incompatible types: MultiDimDataStore cannot be converted to DataStore
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[140,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[145,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[168,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[348,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[388,17\] error: cannot find symbol
[ERROR] class MultiDimDataStore
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[413,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[415,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[415,34\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf-out
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3989/changes&gt;
Changes:
[andrea.aime] DefaultTileLayerCatalog to mimick the GS own default catalog and keep
[...truncated 165810 lines...]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.075 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.187 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [525 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.521 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.736 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.457 s]
[INFO] Main Module ........................................ SUCCESS [02:38 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.052 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:02 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:25 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.280 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.926 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.508 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.859 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:47 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:16 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.588 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:07 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.466 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:15 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.054 s]
[INFO] Core UI Module ..................................... SUCCESS [01:26 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.334 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.074 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.972 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.550 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.633 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.372 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:17 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:40 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:13 min]
[INFO] REST UI Module ..................................... SUCCESS [ 12.708 s]
[INFO] Printing Module .................................... SUCCESS [ 13.821 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.410 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.741 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:49 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.621 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.133 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.968 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 5.835 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.531 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.281 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.244 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.183 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.587 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.288 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.028 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.114 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.833 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.033 s]
[INFO] OGR WPS ............................................ SUCCESS [ 11.007 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.944 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.480 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.418 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.469 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.119 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.762 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 32.545 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.078 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.917 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.041 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 14.933 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.697 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.075 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.766 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.019 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.718 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.421 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.044 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.886 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.325 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.610 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.277 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.172 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.197 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.020 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.046 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.441 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 9.742 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.073 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.400 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 37.440 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 20.322 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.927 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.740 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.496 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 6.748 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.038 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.300 s]
[INFO] Total time: 21:14 min (Wall Clock)
[INFO] Finished at: 2017-02-19T09:43:45+00:00
[INFO] Final Memory: 119M/297M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3990/&gt;
[...truncated 165847 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Feb 19, 2017 10:45:16 AM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
main:
[INFO]
[INFO] Webapp assembled in [351 msecs]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.72 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.751 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.588 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.706 s]
[INFO] Main Module ........................................ SUCCESS [02:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.055 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 56.190 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:55 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.307 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.073 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 27.941 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.798 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:15 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.828 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:06 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.948 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:12 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.069 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.031 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.395 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.859 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.765 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.552 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.824 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.072 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.045 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:14 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.115 s]
[INFO] Printing Module .................................... SUCCESS [ 14.607 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.480 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.026 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:47 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.469 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.701 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.243 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.135 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.471 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.242 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.268 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.611 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.525 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.293 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.027 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.289 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.809 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.027 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:30 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.837 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.140 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.490 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.153 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.483 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.933 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 12.581 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.280 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.144 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.003 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.082 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.247 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.046 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.138 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.040 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.561 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.805 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 29.573 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.037 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.589 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.663 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.375 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.335 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.035 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.330 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.360 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.032 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.069 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.028 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.495 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.052 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.922 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.196 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.523 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.863 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.140 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.192 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 6.191 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.104 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.957 s]
[INFO] Total time: 20:24 min (Wall Clock)
[INFO] Finished at: 2017-02-19T10:45:20+00:00
[INFO] Final Memory: 121M/341M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3991/&gt;
[...truncated 165802 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
Feb 19, 2017 11:11:07 AM org.geoserver.security.cas.LiveCasData disableTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.826 sec
[INFO] Webapp assembled in [400 msecs]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.334 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.152 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.602 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.950 s]
[INFO] Main Module ........................................ SUCCESS [02:18 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 51.509 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:52 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.397 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.592 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 27.961 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 45.946 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:08 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.513 s]
[INFO] REST Support Module ................................ SUCCESS [ 15.322 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:10 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.042 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.038 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.330 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.057 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.110 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.590 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.392 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.153 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:12 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.462 s]
[INFO] Printing Module .................................... SUCCESS [ 13.230 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.065 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.845 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.039 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.064 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.057 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.441 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.238 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.233 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.082 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.030 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.263 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.788 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.646 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:28 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.963 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.095 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.453 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.073 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.906 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 27.555 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.521 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.942 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.912 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.042 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.488 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.909 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.444 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.058 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.389 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.683 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.832 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.721 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.638 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.217 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.820 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.042 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.104 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.246 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.658 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.631 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.056 s]
[INFO] Importer Core Module ............................... SUCCESS [ 43.274 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.505 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 17.534 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.684 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.130 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.672 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 6.677 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.151 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.550 s]
[INFO] Total time: 20:14 min (Wall Clock)
[INFO] Finished at: 2017-02-19T11:11:10+00:00
[INFO] Final Memory: 119M/319M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3992/changes&gt;
Changes:
[andrea.aime] [GEOS-7915] Can not display table based pages in Turkish locale
[...truncated 165901 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
T E S T S
Feb 20, 2017 10:46:43 AM org.geoserver.security.cas.LiveCasData disableTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.79 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.337 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.583 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.118 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.700 s]
[INFO] Main Module ........................................ SUCCESS [02:22 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.048 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 56.168 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:20 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.286 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.131 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.742 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 45.972 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:40 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:20 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.853 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.818 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.991 s]
[INFO] Core UI Module ..................................... SUCCESS [01:23 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.032 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.845 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.995 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 45.418 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.447 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.219 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.257 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.041 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:38 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.830 s]
[INFO] Printing Module .................................... SUCCESS [ 14.069 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.505 s]
[INFO] Community Space .................................... SUCCESS [ 0.030 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.738 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.889 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.725 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.146 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.444 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.241 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.296 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.727 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.863 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.334 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.151 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.943 s]
[INFO] OGR WPS ............................................ SUCCESS [ 11.601 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.897 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.477 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.948 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.900 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.206 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.170 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.727 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.204 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.045 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.254 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.062 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.593 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.070 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.435 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.537 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 32.207 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.041 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.200 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.247 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.838 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.375 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.353 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.124 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.027 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.723 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.617 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.834 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.003 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 37.024 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.141 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.678 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.239 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.524 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 7.034 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.981 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.126 s]
[INFO] Total time: 21:01 min (Wall Clock)
[INFO] Finished at: 2017-02-20T10:46:46+00:00
[INFO] Final Memory: 119M/295M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3993/changes&gt;
Changes:
[andrea.aime] Adding EO metadata templates
[...truncated 165995 lines...]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.081 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.194 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Webapp assembled in [380 msecs]
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.541 s]
[INFO] Core Platform Module ............................... SUCCESS [ 14.242 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.004 s]
[INFO] Main Module ........................................ SUCCESS [02:56 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.054 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:00 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:04 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.093 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.375 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.970 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 48.694 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 30.952 s]
[INFO] REST Support Module ................................ SUCCESS [ 17.130 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:13 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.041 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.109 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.775 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.702 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.880 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.944 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.284 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.945 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:39 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:17 min]
[INFO] REST UI Module ..................................... SUCCESS [ 12.916 s]
[INFO] Printing Module .................................... SUCCESS [ 13.571 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.878 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.079 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.433 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.533 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 10.036 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.788 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.563 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.245 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.249 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.741 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.019 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.252 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.022 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.276 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.649 s]
[INFO] OGR WPS ............................................ SUCCESS [ 11.472 s]
[INFO] Excel Output Format ................................ SUCCESS [ 14.884 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.492 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.393 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.491 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.158 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 23.209 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.222 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.282 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.996 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.159 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.332 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.763 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.841 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.723 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.933 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.357 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.443 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.065 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.410 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.032 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 13.929 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.112 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.030 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.962 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.475 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.010 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.417 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 35.635 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.818 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.110 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.338 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.756 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 6.903 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.301 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.706 s]
[INFO] BUILD FAILURE
[INFO] Total time: 21:11 min (Wall Clock)
[INFO] Finished at: 2017-02-20T14:23:43+00:00
[INFO] Final Memory: 121M/356M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3994/changes&gt;
Changes:
[andrea.aime] GSIP-155 follow up: parallelizing catalog loading on the IO side
[...truncated 142286 lines...]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.11-SNAPSHOT/gs-web-csw-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Feb 20, 2017 3:16:38 PM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.828 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.338 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.768 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.991 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.580 s]
[INFO] Main Module ........................................ SUCCESS [02:28 min]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 54.108 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:17 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.291 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.006 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.140 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 45.767 s]
[INFO] Web Map Service Module ............................. SUCCESS [02:21 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.558 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:09 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.121 s]
[INFO] REST Configuration Service Module .................. FAILURE [01:14 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.068 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.598 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.374 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.870 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.581 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.928 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.491 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.040 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:19 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:36 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:16 min]
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 14.259 s]
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.405 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.980 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.695 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 5.098 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.482 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.247 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.239 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.456 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.808 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.255 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.863 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.848 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.051 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:25 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.744 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.111 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.462 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.622 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.452 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.035 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 28.004 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.982 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.480 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.087 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 17.465 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.321 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.060 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.822 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.341 s]
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.597 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.511 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.750 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.094 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.090 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.025 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.179 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.392 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.478 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.364 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.209 s]
[INFO] Importer Core Module ............................... SUCCESS [ 39.962 s]
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 17.933 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.829 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.835 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.847 s]
[INFO] WCS NetCDF output Module ........................... FAILURE [ 5.867 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.641 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.781 s]
[INFO] Total time: 19:16 min (Wall Clock)
[INFO] Finished at: 2017-02-20T15:16:41+00:00
[INFO] Final Memory: 115M/410M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-netcdf-out: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[19,24\] error: cannot find symbol
[ERROR] package org.geotools.data
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[20,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[69,39\] error: cannot find symbol
[ERROR] class AbstractDataStore
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStoreFactory.java&gt;:\[20,15\] error: incompatible types: MultiDimDataStore cannot be converted to DataStore
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[140,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[145,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[168,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[348,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[388,17\] error: cannot find symbol
[ERROR] class MultiDimDataStore
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[413,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[415,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf-out/src/test/java/org/geoserver/wcs2_0/MultiDimDataStore.java&gt;:\[415,34\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/3995/changes&gt;
