[Geoserver-devel] Build failed in Jenkins: geoserver-master #4047
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4047/&gt;
[...truncated 102563 lines...]
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTTING_DOWN
Results :
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-tests.jar&gt;
Mar 06, 2017 7:51:30 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Destroying node initializer.
Mar 06, 2017 7:51:30 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Hazelcast Shutdown is completed in 14 ms.
Mar 06, 2017 7:51:30 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5010 [dev] [3.3.1] Address[127.0.0.1]:5010 is SHUTDOWN
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-dxf-wps ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-test-sources.jar&gt;
Mar 06, 2017 7:51:30 PM com.hazelcast.spi.impl.BasicOperationScheduler
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-dxf-wps ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT-tests.jar
Mar 06, 2017 7:51:30 PM com.hazelcast.system
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5011
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT-sources.jar
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTING
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/dxf/wps/target/gs-dxf-wps-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-dxf-wps/2.11-SNAPSHOT/gs-dxf-wps-2.11-SNAPSHOT-test-sources.jar
Mar 06, 2017 7:51:30 PM com.hazelcast.test.TestNodeRegistry$MockNodeContext$MockJoiner
Members [1] {
  Member [127.0.0.1]:5011 this
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is STARTED
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Starting with 16 generic operation threads and 16 partition operation threads.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast 3.3.1 (20140929 - a1b45ef) starting at Address[127.0.0.1]:5012
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Copyright (C) 2008-2014 Hazelcast.com
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTING
Mar 06, 2017 7:51:30 PM com.hazelcast.cluster.ClusterService
Members [2] {
  Member [127.0.0.1]:5012
Members [2] {
  Member [127.0.0.1]:5012 this
Mar 06, 2017 7:51:31 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is STARTED
Mar 06, 2017 7:51:31 PM org.geoserver.wps.hz.HazelcastLoader validateConfiguration
WARNING: The WPS status map wpsExecutionStatusMap has a max size set, it should be unbounded so that no status is lost before the configured timeout
Mar 06, 2017 7:51:31 PM com.hazelcast.partition.InternalPartitionService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Initializing cluster partition table first arrangement...
Mar 06, 2017 7:51:36 PM com.hazelcast.core.LifecycleService
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTTING_DOWN
Mar 06, 2017 7:51:36 PM com.hazelcast.cluster.ClusterService
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Master Address[127.0.0.1]:5011 left the cluster. Assigning new master Member [127.0.0.1]:5012 this
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Removing Member [127.0.0.1]:5011
Members [1] {
Mar 06, 2017 7:51:36 PM com.hazelcast.initializer
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Destroying node initializer.
Mar 06, 2017 7:51:36 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Hazelcast Shutdown is completed in 17 ms.
INFO: [127.0.0.1]:5011 [dev] [3.3.1] Address[127.0.0.1]:5011 is SHUTDOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTTING_DOWN
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Destroying node initializer.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 15 ms.
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Address[127.0.0.1]:5012 is SHUTDOWN
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 19.959 sec
Results :
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-wps-cluster-hazelcast ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-wps-cluster-hazelcast ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-cluster-hazelcast/target/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-wps-cluster-hazelcast/2.11-SNAPSHOT/gs-wps-cluster-hazelcast-2.11-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.037 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.088 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.141 s]
[INFO] Main Module ........................................ SUCCESS [02:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.048 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 53.461 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:56 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.283 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.232 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.673 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 45.699 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:41 min]
[INFO] Web Map Service Module ............................. FAILURE [02:11 min]
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] REST Support Module ................................ SUCCESS [ 15.664 s]
[INFO] REST Configuration Service Module .................. SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.041 s]
[INFO] Core UI Module ..................................... SUCCESS [01:20 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.735 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SUCCESS [ 11.784 s]
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.040 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 13.875 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.519 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.143 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 8.963 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.410 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.478 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.277 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.257 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.536 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.273 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.423 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.878 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.488 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.099 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.521 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.458 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.517 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.097 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 27.854 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.039 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.892 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.050 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.801 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.907 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.956 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.978 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.020 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.629 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.082 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.019 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.777 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.691 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.959 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 12:10 min (Wall Clock)
[INFO] Finished at: 2017-03-06T19:51:36+00:00
[INFO] Final Memory: 104M/334M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wms: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wms
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4048/&gt;
[...truncated 102522 lines...]
Mar 06, 2017 8:40:10 PM org.geoserver.config.util.XStreamPersister log
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
INFO: Loaded feature type 'Lakes', enabled
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded feature type 'Deletes', enabled
INFO: Loaded feature type 'Seven', enabled
INFO: Loaded feature type 'Updates', enabled
INFO: Loaded feature type 'Inserts', enabled
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.796 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Mar 06, 2017 8:40:14 PM com.hazelcast.core.LifecycleService
Mar 06, 2017 8:40:14 PM com.hazelcast.cluster.ClusterService
Members [1] {
Mar 06, 2017 8:40:14 PM com.hazelcast.initializer
Mar 06, 2017 8:40:14 PM com.hazelcast.instance.Node
INFO: [127.0.0.1]:5012 [dev] [3.3.1] Hazelcast Shutdown is completed in 13 ms.
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 14.803 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.210 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.266 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.238 s]
[INFO] Main Module ........................................ SUCCESS [02:21 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.058 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 53.800 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:11 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.181 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.629 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.151 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.059 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:40 min]
[INFO] Web Map Service Module ............................. FAILURE [02:17 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.337 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.040 s]
[INFO] Core UI Module ..................................... SUCCESS [01:21 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.248 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.105 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.678 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.051 s]
[INFO] Printing Module .................................... SUCCESS [ 14.105 s]
[INFO] Community Space .................................... SUCCESS [ 0.033 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.033 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.010 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.074 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.821 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.193 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.476 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.254 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.272 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.125 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.293 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.947 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.253 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:29 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.094 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.759 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.538 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.072 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.520 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.504 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.968 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.094 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.325 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.456 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.577 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 44.016 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.646 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.028 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.449 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.050 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.540 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.738 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.331 s]
[INFO] Total time: 12:21 min (Wall Clock)
[INFO] Finished at: 2017-03-06T20:40:14+00:00
[INFO] Final Memory: 104M/338M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Andrea,
this gs-wms build failure is fixed by reverting 261fc592eda8419746eb8bade0453cc9a196837e on GeoTools master:
Follow up to GEOT-5663, hardening the reading code in case something goes pear shaped in the query envelopes computation
https://github.com/geotools/geotools/commit/261fc592eda8419746eb8bade0453cc9a196837e
Kind regards,
Ben.
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Feel free to revert, I won’t be able to check before 10-12 hours from now
Il 06 Mar 2017 22:08, “Ben Caradoc-Davies” <ben@anonymised.com> ha scritto:
Andrea,
Kind regards,
Ben.
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4047/>
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wms/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-wms
Build step ‘Invoke top-level Maven targets’ marked build as failure
Director
Transient Software Limited <http://transient.nz/>
New Zealand
Thanks, Andrea. Reverted on GeoTools master:
https://github.com/geotools/geotools/commit/a2da30e81c033baeed30574e1dbee82d0c67d735
Good night!
Kind regards,
Ben.
On 07/03/17 11:03, Andrea Aime wrote:
Feel free to revert, I won't be able to check before 10-12 hours from now
Il 06 Mar 2017 22:08, "Ben Caradoc-Davies" <ben@anonymised.com> ha scritto:
Andrea,
Kind regards,
Ben.
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
-e switch.
[ERROR]
[ERROR]
command
Director
New Zealand
Director
New Zealand
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4049/&gt;
[...truncated 156935 lines...]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.11-SNAPSHOT/gs-sec-cas-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.11-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.11-SNAPSHOT/gs-web-sec-2.11-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.11-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Mar 06, 2017 11:37:28 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Mar 06, 2017 11:37:30 PM org.geoserver.catalog.ResourcePool getFeatureType
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.11-SNAPSHOT/gs-web-sec-cas-2.11-SNAPSHOT-sources.jar
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.438 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.11-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.11-SNAPSHOT/gs-importer-web-2.11-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.764 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.893 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.117 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 50.358 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:53 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.135 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.068 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.391 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.143 s]
[INFO] Web Map Service Module ............................. SUCCESS [02:11 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.567 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:11 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.392 s]
[INFO] REST Configuration Service Module .................. FAILURE [01:14 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.049 s]
[INFO] Core UI Module ..................................... SUCCESS [01:19 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.036 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.486 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.775 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.886 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.589 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.906 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.028 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.045 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:19 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:35 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:14 min]
[INFO] Printing Module .................................... SUCCESS [ 13.526 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.550 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.554 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.285 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.068 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.441 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.250 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.252 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.452 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.352 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.258 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.216 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.911 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] OGR WPS ............................................ SUCCESS [ 11.363 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.634 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.458 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.063 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.482 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.663 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.227 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.192 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.374 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.463 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.300 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.195 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.082 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.071 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.088 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.542 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.920 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.046 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.634 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.680 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 40.645 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.909 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.089 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.236 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.505 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.035 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.304 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.546 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.749 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.113 s]
[INFO] Importer Core Module ............................... SUCCESS [ 38.155 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.300 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.823 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.567 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.996 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.588 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.434 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.122 s]
[INFO] Total time: 18:59 min (Wall Clock)
[INFO] Finished at: 2017-03-06T23:37:31+00:00
[INFO] Final Memory: 114M/297M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4050/&gt;
