See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4068/>
[...truncated 127495 lines...]
at org.geoserver.test.GeoServerSystemTestSupport.putAsServletResponse(GeoServerSystemTestSupport.java:1056)
at org.geoserver.importer.ImporterTestSupport.setSRSRequest(ImporterTestSupport.java:226)
at org.geoserver.importer.rest.TaskResourceTest.testPutItemSRS(TaskResourceTest.java:444)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
09 Mar 16:57:06 ERROR [geoserver.rest] - {"errors":["Invalid SRS EPSG:9838275"]}
org.geoserver.rest.RestletException
at org.geoserver.importer.rest.ImportJSONWriter.badRequest(ImportJSONWriter.java:757)
at org.geoserver.importer.rest.LayerResource.updateLayer(LayerResource.java:121)
at org.geoserver.importer.rest.TaskResource.handleTaskPut(TaskResource.java:251)
at org.geoserver.importer.rest.TaskResource.handlePut(TaskResource.java:191)
at org.restlet.Finder.handle(Finder.java:298)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:881)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:691)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:770)
at org.geoserver.test.GeoServerSystemTestSupport$1.service(GeoServerSystemTestSupport.java:1478)
at org.springframework.mock.web.MockFilterChain$ServletFilterProxy.doFilter(MockFilterChain.java:167)
at org.springframework.mock.web.MockFilterChain.doFilter(MockFilterChain.java:134)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1505)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1436)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1424)
at org.geoserver.test.GeoServerSystemTestSupport.putAsServletResponse(GeoServerSystemTestSupport.java:1068)
at org.geoserver.importer.rest.TaskResourceTest.testPutItemSRS(TaskResourceTest.java:446)
Mar 09, 2017 4:57:07 PM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'foo', disabled
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.667 sec
Results :
Tests run: 61, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.11-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.11-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.11-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.11-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.11-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.11-SNAPSHOT/gs-importer-rest-2.11-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.11-SNAPSHOT/gs-importer-rest-2.11-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.11-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.11-SNAPSHOT/gs-importer-rest-2.11-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.11-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.11-SNAPSHOT/gs-importer-rest-2.11-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.11-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.11-SNAPSHOT/gs-importer-rest-2.11-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 16.496 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.424 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.724 s]
[INFO] Main Module ........................................ SUCCESS [02:24 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.083 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 58.621 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:30 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.535 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.694 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.587 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.348 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:22 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.061 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 19.066 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:13 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.098 s]
[INFO] Core UI Module ..................................... FAILURE [01:19 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.718 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.110 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] Community Space .................................... SUCCESS [ 0.067 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 40.258 s]
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.394 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.445 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.275 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.239 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.074 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.764 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.255 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.046 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.304 s]
[INFO] OGR WFS ............................................ SUCCESS [ 11.441 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.029 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.238 s]
[INFO] Excel Output Format ................................ SUCCESS [ 27.701 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.513 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.086 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.563 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.111 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 32.306 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 44.814 s]
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.043 s]
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.862 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.038 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.153 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.153 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.758 s]
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.028 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 24.315 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.683 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.514 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.522 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.879 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.311 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 35.426 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.856 s]
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SUCCESS [ 8.398 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.970 s]
[INFO] BUILD FAILURE
[INFO] Total time: 15:52 min (Wall Clock)
[INFO] Finished at: 2017-03-09T16:57:07+00:00
[INFO] Final Memory: 106M/393M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-web-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-core
