[Geoserver-devel] Build failed in Jenkins: geoserver-master #4096
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4096/changes&gt;
Changes:
[emerkle] Log errors creating GeoGig index
[...truncated 184577 lines...]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-rest ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/classes&gt;
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO web UI 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-oseo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 14.169 s]
[INFO] Authentication by unique url key ................... SUCCESS [ 12.032 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 7.972 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 6.412 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 8.043 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.533 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.623 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.169 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.484 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.240 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 24.823 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.802 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 6.380 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.896 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.028 s]
[INFO] ColorMap ........................................... SUCCESS [ 6.374 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 11.763 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.243 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.294 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 5.595 s]
[INFO] REST plugin community module ....................... SUCCESS [ 4.704 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 4.833 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 5.005 s]
[INFO] DownloadProcess .................................... SUCCESS [ 8.058 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.842 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 3.910 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 5.890 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 11.987 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 6.210 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.603 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 5.463 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 7.867 s]
[INFO] GeoFence Server .................................... SUCCESS [ 11.872 s]
[INFO] REST SLD service ................................... SUCCESS [ 6.600 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 5.943 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 8.511 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.036 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.693 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 2.455 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 5.389 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.030 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 7.080 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 3.983 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 7.767 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 5.747 s]
[INFO] GeoGig GeoServer integration ....................... FAILURE [ 34.409 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.057 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 6.407 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 6.013 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 4.386 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.679 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 6.030 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 25.536 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.134 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.442 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.201 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 4.669 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.271 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.536 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.256 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 4.031 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.543 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.119 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 7.013 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 4.705 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 5.435 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:47 min (Wall Clock)
[INFO] Finished at: 2017-03-16T18:56:07+00:00
[INFO] Final Memory: 141M/694M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-geogig: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/geogig/src/test/java/org/geogig/geoserver/GeoGigTestData.java&gt;:\[394,45\] error: incompatible types: SimpleFeatureType cannot be converted to RevFeatureType
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-geogig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4097/changes&gt;
