[Geoserver-devel] Build failed in Jenkins: geoserver-master #4098
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4098/&gt;
[...truncated 156607 lines...]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-bdb ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-bdb ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.12-SNAPSHOT/gs-importer-bdb-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.12-SNAPSHOT/gs-importer-bdb-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.12-SNAPSHOT/gs-importer-bdb-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.12-SNAPSHOT/gs-importer-bdb-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/bdb/target/gs-importer-bdb-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-bdb/2.12-SNAPSHOT/gs-importer-bdb-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Mar 17, 2017 1:01:09 AM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.813 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.344 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 11.359 s]
[INFO] Core Platform Module ............................... SUCCESS [ 17.104 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.716 s]
[INFO] Main Module ........................................ SUCCESS [02:24 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.074 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 52.848 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:17 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.400 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.383 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.521 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.294 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:46 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:15 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 32.708 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:12 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.750 s]
[INFO] REST Configuration Service Module .................. FAILURE [01:13 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.075 s]
[INFO] Core UI Module ..................................... SUCCESS [01:16 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.041 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.085 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.964 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.533 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.636 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.185 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.555 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.049 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:03 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:32 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:19 min]
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 14.579 s]
[INFO] Community Space .................................... SUCCESS [ 0.051 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.040 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.774 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.053 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 9.172 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.430 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.473 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.275 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.259 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.604 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.566 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.292 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.056 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.996 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.114 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:31 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.947 s]
[INFO] Excel Output Format ................................ SUCCESS [ 16.213 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.621 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.083 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.509 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.936 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 19.197 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.194 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.945 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.067 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.063 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 14.769 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.708 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.055 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.150 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.087 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.483 s]
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.686 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.048 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.659 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.410 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.561 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.349 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.038 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.425 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.650 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.689 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.124 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.228 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.343 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.935 s]
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.571 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.472 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.852 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.717 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.018 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.903 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.058 s]
[INFO] BUILD FAILURE
[INFO] Total time: 19:29 min (Wall Clock)
[INFO] Finished at: 2017-03-17T01:01:12+00:00
[INFO] Final Memory: 126M/648M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4099/&gt;
