[Geoserver-devel] Build failed in Jenkins: geoserver-master #4212
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4212/&gt;
[...truncated 157100 lines...]
Mar 27, 2017 12:30:53 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
Mar 27, 2017 12:30:55 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
Mar 27, 2017 12:30:55 PM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'sf', enabled
INFO: Loaded feature type 'GenericEntity', enabled
INFO: Loaded feature type 'PrimitiveGeoFeature', enabled
INFO: Loaded feature type 'AggregateGeoFeature', enabled
INFO: Loaded store 'cite', enabled
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
INFO: Loaded feature type 'Lakes', enabled
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Inserts', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded feature type 'Seven', enabled
INFO: Loaded feature type 'Updates', enabled
INFO: Loaded feature type 'Deletes', enabled
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.482 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 21.731 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.855 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.595 s]
[INFO] Main Module ........................................ SUCCESS [02:22 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.054 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 54.697 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:04 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.011 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.141 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 27.279 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 49.291 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:41 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:15 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.475 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [03:34 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.958 s]
[INFO] REST Configuration Service Module .................. FAILURE [01:26 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.039 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.033 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.185 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 31.296 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 39.905 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.374 s]
[INFO] Demos Module ....................................... SUCCESS [ 19.476 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 16.150 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:04 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:32 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:15 min]
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 13.169 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 14.857 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.306 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.267 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.868 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.437 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.354 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.724 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.566 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.257 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.127 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.319 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:58 min]
[INFO] OGR WPS ............................................ SUCCESS [ 11.102 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.578 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.476 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.400 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.465 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.022 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.640 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 28.287 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.345 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.170 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.041 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.337 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.915 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.070 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.891 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.532 s]
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.154 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 29.482 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.992 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.260 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.480 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.154 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.478 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.021 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 17.998 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.613 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.455 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.057 s]
[INFO] Importer Core Module ............................... SUCCESS [ 46.918 s]
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.619 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.614 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.403 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.101 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 40.560 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.366 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 11.482 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:52 min (Wall Clock)
[INFO] Finished at: 2017-03-27T12:30:57+00:00
[INFO] Final Memory: 126M/541M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4213/&gt;
