See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4241/>
[...truncated 179296 lines...]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.089 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.199 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
[INFO] Webapp assembled in [391 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war>
Running org.geoserver.security.cas.CasAuthenticationTest
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
Mar 28, 2017 4:18:55 PM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.868 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.339 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.880 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.511 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.516 s]
[INFO] Main Module ........................................ SUCCESS [02:24 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.050 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 51.733 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:07 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.102 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.967 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.838 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 47.998 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:19 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.300 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.641 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:18 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.057 s]
[INFO] Core UI Module ..................................... SUCCESS [01:10 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.037 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 9.843 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 33.767 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 39.880 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.243 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.886 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.875 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.048 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:08 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:33 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:19 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.345 s]
[INFO] Printing Module .................................... SUCCESS [ 13.999 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.347 s]
[INFO] Community Space .................................... SUCCESS [ 0.026 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.070 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.693 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.463 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.796 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.065 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.846 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.274 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.245 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.503 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.621 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.294 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.043 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.500 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.895 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.041 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:31 min]
[INFO] Excel Output Format ................................ SUCCESS [ 16.385 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.488 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.307 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.462 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.356 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.537 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.049 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.082 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.511 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.064 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.899 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.051 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.481 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.502 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 32.335 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.061 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.426 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.704 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.084 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.414 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.025 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.581 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.028 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.278 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.461 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.655 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.068 s]
[INFO] Importer Core Module ............................... SUCCESS [ 44.380 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.322 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 20.217 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.723 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.639 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.874 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 37.122 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.178 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.327 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:14 min (Wall Clock)
[INFO] Finished at: 2017-03-28T16:18:59+00:00
[INFO] Final Memory: 132M/626M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
