See <http://ares.opengeo.org/jenkins/job/geoserver-master/425/changes>
Changes:
[maurobartolomeoli] Promoted printing module from community to extension and updated mapfish print-lib version to 2.0.0
[...truncated 10219 lines...]
Results :
Tests in error:
testServiceExists(org.geoserver.printing.SmokeTest): Invalid JSON String
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0
[INFO]
[INFO] Skipping Catalog Services for the Web interfaces
[INFO]
[INFO] Skipping Web Map Service Module
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO] Skipping Sample DataAccess Integration Test
[INFO]
[INFO] Skipping ogr2ogr Output Format
[INFO]
[INFO] Skipping Excel Output Format
[INFO]
[INFO] Skipping GeoServer Layer Querying filter functions
[INFO]
[INFO] Skipping DXF output format
[INFO]
[INFO] Skipping Web Coverage Service 2.0 Module
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 13.568 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-css ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/css/target/gs-css-2.6-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-css ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/css/target/gs-css-2.6-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ gs-css >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-css ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #557 from mbarto/printing_extension
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 14.04.2014 @ 07:26:14 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 14-Apr-2014 07:29
[INFO] [GitCommitIdMojo] build.build.time = 14.04.2014 @ 07:39:07 UTC
[INFO] [GitCommitIdMojo] build.branch = 5ff52504c7a63d4093ba97534c9dcbcd9c2b2986
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 5ff5250
[INFO] [GitCommitIdMojo] build.commit.id = 5ff52504c7a63d4093ba97534c9dcbcd9c2b2986
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #557 from mbarto/printing_extension
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ gs-css <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ gs-css ---
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.307s]
[INFO] Core Platform Module .............................. SUCCESS [7.080s]
[INFO] Open Web Service Module ........................... SUCCESS [14.977s]
[INFO] Main Module ....................................... SUCCESS [2:37.358s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.973s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:07.620s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [47.692s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.139s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:05.315s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:06.126s]
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SUCCESS [3:43.694s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [38.053s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.493s]
[INFO] Core UI Module .................................... SUCCESS [2:07.446s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SUCCESS [0.829s]
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.311s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.473s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.274s]
[INFO] Printing Module ................................... FAILURE [1:07.308s]
[INFO] Application Schema Support ........................ SUCCESS [0.365s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [26.856s]
[INFO] H2 DataStore Extension ............................ SUCCESS [17.331s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.463s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.168s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.731s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.873s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.696s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.926s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [2.394s]
[INFO] Chart external graphics support ................... SUCCESS [1.965s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.438s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.968s]
[INFO] OWS request flow controller ....................... SUCCESS [20.881s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.331s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.280s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.579s]
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.352s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.580s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:00.451s (Wall Clock)
[INFO] Finished at: Mon Apr 14 07:39:07 UTC 2014
[INFO] Final Memory: 52M/311M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-printing: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/printing/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-printing
