[Geoserver-devel] Build failed in Jenkins: geoserver-master #4256
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4256/&gt;
[...truncated 172969 lines...]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Mar 29, 2017 9:54:18 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
Mar 29, 2017 9:54:19 AM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'sf', enabled
INFO: Loaded feature type 'GenericEntity', enabled
INFO: Loaded feature type 'PrimitiveGeoFeature', enabled
INFO: Loaded feature type 'AggregateGeoFeature', enabled
INFO: Loaded store 'cite', enabled
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'Lakes', enabled
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Inserts', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded feature type 'Updates', enabled
INFO: Loaded feature type 'Deletes', enabled
INFO: Loaded feature type 'Seven', enabled
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.577 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.818 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.977 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.578 s]
[INFO] Main Module ........................................ SUCCESS [02:23 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.058 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 53.734 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:04 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.148 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.690 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.981 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.377 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:32 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 31.543 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [09:58 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.522 s]
[INFO] REST Configuration Service Module .................. SUCCESS [03:13 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.097 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.037 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.330 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 32.130 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 39.646 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.383 s]
[INFO] Demos Module ....................................... SUCCESS [ 19.600 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.524 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.046 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:02 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [02:30 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:11 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.172 s]
[INFO] Printing Module .................................... SUCCESS [ 13.388 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.814 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.033 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:52 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 24.258 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.668 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.572 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.283 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 1.527 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 1.060 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.278 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.604 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.347 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.289 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.017 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.007 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.021 s]
[INFO] Web Processing Service Module ...................... SUCCESS [03:25 min]
[INFO] OGR WPS ............................................ SUCCESS [ 12.087 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.617 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.461 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.710 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.528 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.683 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.401 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.460 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.490 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.160 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.041 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.079 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.732 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.623 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.664 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.769 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 29.812 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.050 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [02:06 min]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.443 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.021 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.197 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.033 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.264 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.073 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.033 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.109 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.360 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 13.500 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.050 s]
[INFO] Importer Core Module ............................... SUCCESS [02:07 min]
[INFO] Importer REST Api Module ........................... SUCCESS [ 34.850 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 53.258 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.385 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 17.977 s]
[INFO] NetCDF Coverage format ............................. FAILURE [ 28.883 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.609 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 37.997 s]
[INFO] BUILD FAILURE
[INFO] Total time: 29:34 min (Wall Clock)
[INFO] Finished at: 2017-03-29T09:54:21+00:00
[INFO] Final Memory: 119M/507M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-netcdf: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4257/&gt;
