See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4259/>
[...truncated 185819 lines...]
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-rest ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-rest ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/gs-backup-restore-rest-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-rest/2.12-SNAPSHOT/gs-backup-restore-rest-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building OpenSearch for EO web UI 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-oseo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [01:04 min]
[INFO] Authentication by unique url key ................... SUCCESS [01:25 min]
[INFO] WorldWind Format Module ............................ SUCCESS [ 8.159 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 12.246 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 7.975 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.929 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 37.327 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.328 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 6.285 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 3.994 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 26.395 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 13.328 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 12.119 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 4.963 s]
[INFO] WMS-EO ............................................. SUCCESS [ 5.323 s]
[INFO] ColorMap ........................................... SUCCESS [ 4.657 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 51.418 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.158 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 11.180 s]
[INFO] Dynamic WMS dimension value defaults ............... FAILURE [ 1.564 s]
[INFO] REST plugin community module ....................... SUCCESS [ 5.397 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 5.923 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 6.608 s]
[INFO] DownloadProcess .................................... SUCCESS [ 6.700 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.798 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.131 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.906 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 15.096 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 7.734 s]
[INFO] Solr Module ........................................ SUCCESS [ 5.738 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 4.588 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 15.157 s]
[INFO] GeoFence Server .................................... SUCCESS [ 8.256 s]
[INFO] REST SLD service ................................... SUCCESS [ 13.145 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 6.284 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 13.701 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 5.953 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 6.177 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.450 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 7.634 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.020 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.991 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 6.260 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 6.609 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 8.411 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.057 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 6.948 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 5.731 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.064 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.682 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 7.220 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [02:31 min]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 6.431 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.804 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 5.862 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 6.146 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.565 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 4.118 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 6.358 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 5.416 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.989 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.019 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 8.368 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 4.410 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 7.105 s]
[INFO] BUILD FAILURE
[INFO] Total time: 06:44 min (Wall Clock)
[INFO] Finished at: 2017-03-29T12:39:00+00:00
[INFO] Final Memory: 137M/692M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-dyndimension: Compilation failure
[ERROR] error: error reading /var/lib/jenkins/.m2/repository/org/geoserver/gs-wms/2.12-SNAPSHOT/gs-wms-2.12-SNAPSHOT.jar; zip file is empty
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-dyndimension
