See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4280/>
[...truncated 181461 lines...]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports>
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Mar 30, 2017 4:40:32 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.192 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.771 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar>
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO] Webapp assembled in [380 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.824 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.115 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.973 s]
[INFO] Main Module ........................................ SUCCESS [02:32 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.073 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 52.258 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:54 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.378 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.365 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.299 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 50.624 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:37 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:20 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 37.555 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.939 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:14 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.106 s]
[INFO] Core UI Module ..................................... SUCCESS [01:10 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.042 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 9.758 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.784 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 41.100 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.353 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.576 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.607 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.045 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:08 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [02:35 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [02:32 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.515 s]
[INFO] Printing Module .................................... SUCCESS [ 13.927 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.956 s]
[INFO] Community Space .................................... SUCCESS [ 0.028 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.033 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:46 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.592 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.333 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 16.451 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.080 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.472 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.306 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.240 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.470 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.643 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.282 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.023 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.917 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.105 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:35 min]
[INFO] Excel Output Format ................................ SUCCESS [ 15.771 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.478 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.061 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.492 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.528 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.547 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.003 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.844 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.763 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.298 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.041 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.532 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.179 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 34.631 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.041 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.279 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.959 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.081 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.898 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.837 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.029 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.031 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.406 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.276 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.087 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.244 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 35.839 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.433 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.259 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.867 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.832 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.419 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.283 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.002 s]
[INFO] BUILD FAILURE
[INFO] Total time: 21:26 min (Wall Clock)
[INFO] Finished at: 2017-03-30T16:40:36+00:00
[INFO] Final Memory: 130M/539M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
