[Geoserver-devel] Build failed in Jenkins: geoserver-master #4291
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4291/&gt;
[...truncated 183349 lines...]
Mar 31, 2017 4:02:13 AM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.982 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.504 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.102 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.546 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [6296 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 12.859 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.265 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 15.525 s]
[INFO] Main Module ........................................ SUCCESS [02:46 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.587 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 52.661 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [06:33 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.693 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 27.014 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 31.774 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 56.405 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:44 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:52 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 38.439 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:25 min]
[INFO] REST Support Module ................................ SUCCESS [ 17.400 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:23 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.580 s]
[INFO] Core UI Module ..................................... SUCCESS [01:24 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.071 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 15.406 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 40.343 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 46.741 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.004 s]
[INFO] Demos Module ....................................... SUCCESS [ 23.564 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 17.017 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.213 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:23 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:37 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [02:55 min]
[INFO] REST UI Module ..................................... SUCCESS [ 17.708 s]
[INFO] Printing Module .................................... SUCCESS [ 17.489 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 42.986 s]
[INFO] Community Space .................................... SUCCESS [ 0.077 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.049 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:03 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.802 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.499 s]
[INFO] H2 DataStore Extension ............................. FAILURE [ 14.404 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.410 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.719 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.429 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.383 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 14.319 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.050 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.361 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.068 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.137 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.850 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.064 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:51 min]
[INFO] OGR WPS ............................................ SUCCESS [ 12.539 s]
[INFO] Excel Output Format ................................ SUCCESS [ 19.516 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.677 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.724 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.593 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.738 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.239 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 34.160 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.841 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.299 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.228 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 20.575 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 17.128 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.323 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 15.232 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.394 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.967 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.530 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 38.204 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.237 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 12.447 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 15.212 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 49.471 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.287 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.047 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.406 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 11.060 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.080 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 22.969 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 16.290 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 12.247 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.612 s]
[INFO] Importer Core Module ............................... SUCCESS [ 52.078 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 40.080 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 23.222 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 18.112 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 23.165 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 22.320 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 43.238 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 10.718 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 15.279 s]
[INFO] BUILD FAILURE
[INFO] Total time: 26:50 min (Wall Clock)
[INFO] Finished at: 2017-03-31T04:02:44+00:00
[INFO] Final Memory: 121M/462M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-h2: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/h2/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-h2
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4292/&gt;
