[Geoserver-devel] Build failed in Jenkins: geoserver-master #4296
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4296/&gt;
[...truncated 187476 lines...]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer notification event system 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-notification ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-notification ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-notification ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-notification ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-notification ---
[INFO] Compiling 11 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar
[INFO]
[INFO] Building OpenSearch for EO web UI 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-notification ---
[INFO] Copying 0 resource
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-notification ---
[INFO] Compiling 9 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/test-classes&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-oseo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-notification ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-notification ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-notification ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/target/gs-notification-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-notification/2.12-SNAPSHOT/gs-notification-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [04:02 min]
[INFO] Authentication by unique url key ................... SUCCESS [ 9.928 s]
[INFO] WorldWind Format Module ............................ FAILURE [ 8.864 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 7.694 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 11.764 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 4.457 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 4.218 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 10.137 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 8.026 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 5.092 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 48.645 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 25.177 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 9.904 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 6.060 s]
[INFO] WMS-EO ............................................. SUCCESS [ 7.952 s]
[INFO] ColorMap ........................................... SUCCESS [ 9.342 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 22.253 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 7.633 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 3.487 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 8.677 s]
[INFO] REST plugin community module ....................... SUCCESS [ 7.727 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 7.387 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 8.132 s]
[INFO] DownloadProcess .................................... SUCCESS [ 9.648 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 1.442 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 6.038 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 2.445 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 20.536 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 12.634 s]
[INFO] Solr Module ........................................ SUCCESS [ 12.636 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 6.332 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 12.213 s]
[INFO] GeoFence Server .................................... SUCCESS [ 21.963 s]
[INFO] REST SLD service ................................... SUCCESS [ 8.435 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 8.621 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 12.815 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 7.610 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 10.480 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 7.588 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 12.310 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.092 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 11.842 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.508 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 9.102 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 8.621 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.152 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 10.573 s]
[INFO] GeoServer Config Backup And Restore REST Module .... SUCCESS [ 8.471 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 3.465 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 5.301 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 8.165 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 45.340 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.523 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 11.053 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 6.499 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 8.446 s]
[INFO] gs-notification-common ............................. SUCCESS [ 2.589 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.709 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 8.775 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 6.644 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 3.771 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.098 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 11.634 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 6.491 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 8.069 s]
[INFO] BUILD FAILURE
[INFO] Total time: 09:00 min (Wall Clock)
[INFO] Finished at: 2017-03-31T11:39:01+00:00
[INFO] Final Memory: 140M/572M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-dds: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/dds/src/test/java/org/geoserver/wms/worldwind/BilTest.java&gt;:\[260,26\] error: cannot access GeoServerResourceLoader
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-dds
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4297/&gt;
[...truncated 181387 lines...]
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
  at java.lang.reflect.Method.invoke(Method.java:497)
Tests run: 4, Failures: 0, Errors: 0, Skipped: 4, Time elapsed: 69.369 sec
Results :
Tests run: 13, Failures: 0, Errors: 0, Skipped: 13
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-sec-ldap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec-ldap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec-ldap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec-ldap ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec-ldap ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/ldap/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/security/ldap/target/gs-web-sec-ldap-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Web Application 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-app ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-app ---
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configClean) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
   [delete] Deleting directory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-app ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-app ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/resources&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/java&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-app ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-app ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.085 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.339 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [14076 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.066 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.744 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 23.898 s]
[INFO] Main Module ........................................ SUCCESS [02:33 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.117 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:01 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [07:46 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.342 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 28.758 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 33.245 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 56.561 s]
[INFO] Web Feature Service Module ......................... SUCCESS [02:04 min]
[INFO] Web Map Service Module ............................. SUCCESS [03:13 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 45.844 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:35 min]
[INFO] REST Support Module ................................ SUCCESS [ 20.736 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:34 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.080 s]
[INFO] Core UI Module ..................................... SUCCESS [01:26 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.057 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 12.668 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 41.284 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 48.755 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 13.253 s]
[INFO] Demos Module ....................................... SUCCESS [ 24.613 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 17.288 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.070 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:27 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:38 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [04:01 min]
[INFO] REST UI Module ..................................... SUCCESS [ 19.789 s]
[INFO] Printing Module .................................... SUCCESS [ 18.146 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 25.155 s]
[INFO] Community Space .................................... SUCCESS [ 0.042 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.061 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:06 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 14.173 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.151 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 14.694 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.172 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 3.480 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 3.968 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.525 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 12.287 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 5.350 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.482 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.067 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.474 s]
[INFO] OGR WFS ............................................ SUCCESS [ 11.531 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.095 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:43 min]
[INFO] Excel Output Format ................................ SUCCESS [ 23.515 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.610 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.037 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.626 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 10.595 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 19.088 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.703 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.180 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 21.052 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 13.939 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.909 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 9.709 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.151 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 3.605 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 22.389 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 42.931 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.340 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 13.526 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.554 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 52.356 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.425 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.063 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 20.367 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.082 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 24.479 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 18.090 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 13.593 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.432 s]
[INFO] Importer Core Module ............................... SUCCESS [ 56.526 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 53.139 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 25.326 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 20.615 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 27.276 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 22.713 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 43.639 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.731 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 10.730 s]
[INFO] Total time: 28:23 min (Wall Clock)
[INFO] Finished at: 2017-03-31T12:09:20+00:00
[INFO] Final Memory: 122M/529M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4298/&gt;
