See <http://ares.opengeo.org/jenkins/job/geoserver-master/43/changes>
Changes:
[maurobartolomeoli] GEOS-6080: added standard RoleSource support (Header, RoleService, UserGroupService) to J2EEAuthenticationFilter
[maurobartolomeoli] GEOS-6080: added more docs to MigrationHelper
[...truncated 37221 lines...]
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #366 from mbarto/geos6080_j2eefilter_roleservice_2
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 23.10.2013 @ 07:16:48 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 23-Oct-2013 09:55
[INFO] [GitCommitIdMojo] build.build.time = 23.10.2013 @ 10:23:47 UTC
[INFO] [GitCommitIdMojo] build.branch = 9753da6c9346e685ca6d3409530eff575dc4a48e
[INFO] [GitCommitIdMojo] build.commit.user.email = maurobartolomeoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = mbarto
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 9753da6
[INFO] [GitCommitIdMojo] build.commit.id = 9753da6c9346e685ca6d3409530eff575dc4a48e
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #366 from mbarto/geos6080_j2eefilter_roleservice_2
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ app-schema-test <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ app-schema-test ---
[INFO] Building jar: <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/app-schema-test-2.5-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ app-schema-test ---
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/app-schema-test-2.5-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/app-schema-test/2.5-SNAPSHOT/app-schema-test-2.5-SNAPSHOT.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/app-schema-test/2.5-SNAPSHOT/app-schema-test-2.5-SNAPSHOT.pom
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/app-schema-test-2.5-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/app-schema-test/2.5-SNAPSHOT/app-schema-test-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/app-schema-test-2.5-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/app-schema-test/2.5-SNAPSHOT/app-schema-test-2.5-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Module 2.5-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer CAS Security Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ sec-cas ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ sec-cas ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ sec-cas ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ sec-cas ---
[INFO] Copying 1 resource
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ sec-cas ---
[INFO] Compiling 11 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/classes>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.848 sec
Running org.geoserver.security.web.jdbc.user.JDBCEditUserPageTest
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ sec-cas ---
[INFO] Compiling 4 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[33,73\] cannot find symbol
symbol : class RoleSource
location: class org.geoserver.security.config.PreAuthenticatedUserNameFilterConfig
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[60,68\] cannot find symbol
symbol : variable RoleSource
location: class org.geoserver.security.config.RequestHeaderAuthenticationFilterConfig
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[88,68\] cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasFilterConfigValidatorTest.java>:\[104,68\] cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[253,29\] cannot find symbol
location: class org.geoserver.security.cas.CasAuthenticationTest
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[472,29\] cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[603,31\] cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/java/org/geoserver/security/cas/CasAuthenticationTest.java>:\[773,31\] cannot find symbol
[INFO] 8 errors
[INFO]
[INFO] Skipping GeoServer Security Extension Web Modules
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [5.789s]
[INFO] Core Platform Module .............................. SUCCESS [4.326s]
[INFO] Open Web Service Module ........................... SUCCESS [12.986s]
[INFO] Main Module ....................................... SUCCESS [2:35.494s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:54.583s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.146s]
[INFO] Web Map Service Module ............................ SUCCESS [4:21.459s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.662s]
[INFO] Core UI Module .................................... SUCCESS [2:04.276s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.491s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [1:25.492s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [19.589s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [56.742s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:07.995s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:12.390s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:33.984s]
[INFO] REST Support Module ............................... SUCCESS [34.974s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:53.536s]
[INFO] WMS UI Module ..................................... SUCCESS [59.945s]
[INFO] GWC UI Module ..................................... SUCCESS [1:08.935s]
[INFO] WFS UI Module ..................................... SUCCESS [37.502s]
[INFO] Demoes Module ..................................... SUCCESS [53.962s]
[INFO] WCS UI Module ..................................... SUCCESS [45.978s]
[INFO] Security UI Modules ............................... SUCCESS [0.383s]
[INFO] Security UI Core Module ........................... SUCCESS [3:34.733s]
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SUCCESS [37.015s]
[INFO] Community Space ................................... SUCCESS [0.285s]
[INFO] Printing Module ................................... SUCCESS [25.990s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.157s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.201s]
[INFO] Application Schema Support ........................ SUCCESS [0.206s]
[INFO] Application Schema Integration Test ............... SUCCESS [4:41.615s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [32.734s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [27.778s]
[INFO] GeoSearch Index Module ............................ SUCCESS [33.557s]
[INFO] H2 DataStore Extension ............................ SUCCESS [17.137s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.930s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.384s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.473s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.496s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.407s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.243s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.669s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [31.850s]
[INFO] Excel Output Format ............................... SUCCESS [34.197s]
[INFO] Validation Module ................................. SUCCESS [2.863s]
[INFO] Chart external graphics support ................... SUCCESS [1.152s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.011s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.200s]
[INFO] OWS request flow controller ....................... SUCCESS [21.561s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.334s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:56.007s]
[INFO] Web Processing Service GUI ........................ SUCCESS [58.494s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [44.983s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.282s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.641s]
[INFO] Core Monitor Extension ............................ SUCCESS [22.848s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [9.854s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.271s]
[INFO] GeoServer CAS Security Module ..................... FAILURE [4.474s]
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] XLST based WFS output format ...................... SUCCESS [48.860s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [49.736s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [32.888s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.323s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [21.584s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [22.600s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:31.782s]
[INFO] CSW UI Module ..................................... SUCCESS [26.910s]
[INFO] BUILD FAILURE
[INFO] Total time: 28:41.545s (Wall Clock)
[INFO] Finished at: Wed Oct 23 10:23:57 UTC 2013
[INFO] Final Memory: 63M/215M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project sec-cas: Compilation failure: Compilation failure:
[ERROR] symbol : class RoleSource
[ERROR] location: class org.geoserver.security.config.PreAuthenticatedUserNameFilterConfig
[ERROR] symbol : variable RoleSource
[ERROR] location: class org.geoserver.security.config.RequestHeaderAuthenticationFilterConfig
[ERROR] location: class org.geoserver.security.cas.CasAuthenticationTest
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :sec-cas
