See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4308/>
[...truncated 187631 lines...]
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-rest ---
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-rest ---
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-extension ---
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-rest ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/classes>
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-extension ---
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-extension ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-extension ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-extension ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-extension ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/extension/target/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-extension/2.12-SNAPSHOT/gs-backup-restore-extension-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Config Backup And Restore Web UI Module 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-backup-restore-web ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-backup-restore-web ---
[INFO] Copying 4 resources
[INFO] Copying 5 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-backup-restore-web ---
[INFO] Compiling 7 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreStreamResource.java>:\[104,44\] error: cannot find symbol
[INFO] 1 error
[INFO]
[INFO] Building OpenSearch for EO web UI 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-oseo ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-oseo ---
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-oseo ---
[INFO] Copying 3 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-oseo ---
[INFO] Compiling 3 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-oseo ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-oseo ---
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/test-classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-backup-restore-web ---
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-backup-restore-web ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-backup-restore-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/web/target/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/backuprestore/gs-backup-restore-web/2.12-SNAPSHOT/gs-backup-restore-web-2.12-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-oseo ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-oseo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-oseo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/oseo/web-oseo/target/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/community/gs-web-oseo/2.12-SNAPSHOT/gs-web-oseo-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Skipping GeoServer Community Release Module
[INFO] Reactor Summary:
[INFO]
[INFO] Community Space .................................... SUCCESS [ 10.783 s]
[INFO] Authentication by unique url key ................... FAILURE [ 19.494 s]
[INFO] WorldWind Format Module ............................ SUCCESS [ 8.100 s]
[INFO] SpatiaLite Extension ............................... SUCCESS [ 7.617 s]
[INFO] GeoServer JDBC KV Catalog .......................... SUCCESS [ 10.813 s]
[INFO] Aggregating Data Store ............................. SUCCESS [ 3.933 s]
[INFO] GeoServer Scripting Extensions ..................... SUCCESS [ 2.607 s]
[INFO] Core Scripting Extension ........................... SUCCESS [ 7.742 s]
[INFO] Web UI Scripting Extension ......................... SUCCESS [ 5.674 s]
[INFO] BeanShell Scripting Extension ...................... SUCCESS [ 4.296 s]
[INFO] Groovy Scripting Extension ......................... SUCCESS [ 23.002 s]
[INFO] Python Scripting Extension ......................... SUCCESS [ 9.024 s]
[INFO] JavaScript Scripting Extension ..................... SUCCESS [ 7.555 s]
[INFO] Ruby Scripting Extension ........................... SUCCESS [ 7.038 s]
[INFO] WMS-EO ............................................. SUCCESS [ 9.003 s]
[INFO] ColorMap ........................................... SUCCESS [ 7.242 s]
[INFO] GeoServer mbtiles Extension ........................ SUCCESS [ 12.940 s]
[INFO] GeoServer GeoPackage Extension ..................... SUCCESS [ 6.307 s]
[INFO] PGRaster DataStore Extension for automatic configuration SUCCESS [ 2.517 s]
[INFO] Dynamic WMS dimension value defaults ............... SUCCESS [ 7.076 s]
[INFO] REST plugin community module ....................... SUCCESS [ 6.836 s]
[INFO] GPX PPIO for WPS ................................... SUCCESS [ 6.026 s]
[INFO] KML PPIO for WPS ................................... SUCCESS [ 7.398 s]
[INFO] DownloadProcess .................................... SUCCESS [ 8.962 s]
[INFO] GeoServer JMS based clustering modules ............. SUCCESS [ 0.810 s]
[INFO] ActiveMQ ........................................... SUCCESS [ 4.129 s]
[INFO] GeoServer JMS clustering Commons module ............ SUCCESS [ 1.700 s]
[INFO] GeoServer JMS clustering module .................... SUCCESS [ 15.104 s]
[INFO] GeoServer Hazelcast Clustering Module .............. SUCCESS [ 10.318 s]
[INFO] Solr Module ........................................ SUCCESS [ 7.243 s]
[INFO] Resumable REST Upload module ....................... SUCCESS [ 6.111 s]
[INFO] GeoFence security integration ...................... SUCCESS [ 9.535 s]
[INFO] GeoFence Server .................................... SUCCESS [ 8.264 s]
[INFO] REST SLD service ................................... SUCCESS [ 9.028 s]
[INFO] Parameters Extractor ............................... SUCCESS [ 8.047 s]
[INFO] Web Processing Service - Remote processes invocation SUCCESS [ 10.605 s]
[INFO] WPS cluster on jdbc datastores ..................... SUCCESS [ 7.087 s]
[INFO] ncWMS compatibility extension ...................... SUCCESS [ 5.491 s]
[INFO] GWC Distributed Caching Plugin ..................... SUCCESS [ 3.276 s]
[INFO] GeoWebCache S3 ..................................... SUCCESS [ 7.441 s]
[INFO] GDAL translate parent .............................. SUCCESS [ 0.028 s]
[INFO] GDAL translate WCS ................................. SUCCESS [ 5.822 s]
[INFO] GDAL translate WPS ................................. SUCCESS [ 5.316 s]
[INFO] GeoServer JDBC Configuration Resource Store ........ SUCCESS [ 5.662 s]
[INFO] GeoWebCache SQLite ................................. SUCCESS [ 7.693 s]
[INFO] GeoServer Config Backup And Restore ................ SUCCESS [ 0.062 s]
[INFO] GeoServer Config Backup And Restore Core Module .... SUCCESS [ 7.233 s]
[INFO] GeoServer Config Backup And Restore REST Module .... FAILURE [ 3.194 s]
[INFO] GeoServer Config Backup And Restore Extensions ..... SUCCESS [ 2.673 s]
[INFO] GeoServer Config Backup And Restore Web UI Module .. SUCCESS [ 3.752 s]
[INFO] WMTS Multi Dimensional ............................. SUCCESS [ 8.210 s]
[INFO] GeoServer OAuth2 Connect Security Module ........... SUCCESS [ 27.460 s]
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SUCCESS [ 5.861 s]
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SUCCESS [ 5.273 s]
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SUCCESS [ 7.022 s]
[INFO] GeoServer OneLogin Module .......................... SUCCESS [ 6.814 s]
[INFO] gs-notification-common ............................. SUCCESS [ 1.745 s]
[INFO] GeoServer notification event system extension for GeoNode SUCCESS [ 2.392 s]
[INFO] GeoServer notification event system ................ SUCCESS [ 5.574 s]
[INFO] OWS Dispatcher Simulate Plugin ..................... SUCCESS [ 5.755 s]
[INFO] JDBC Metrics Plugin ................................ SUCCESS [ 2.944 s]
[INFO] OpenSearch EO parent ............................... SUCCESS [ 0.014 s]
[INFO] OpenSearch for EO .................................. SUCCESS [ 7.673 s]
[INFO] OpenSearch for EO web UI ........................... SUCCESS [ 4.992 s]
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SUCCESS [ 5.734 s]
[INFO] BUILD FAILURE
[INFO] Total time: 03:54 min (Wall Clock)
[INFO] Finished at: 2017-03-31T21:35:42+00:00
[INFO] Final Memory: 141M/706M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-authkey: Compilation failure
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/authkey/src/main/java/org/geoserver/security/web/AuthenticationKeyFilterPanel.java>:\[34,29\] error: cannot access MapModel
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gs-backup-restore-rest: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-authkey
