[Geoserver-devel] Build failed in Jenkins: geoserver-master #432
See <http://ares.opengeo.org/jenkins/job/geoserver-master/432/changes&gt;
Changes:
[Ben.Caradoc-Davies] Update release guide to fix broken links and add maintenance release instructions
[...truncated 3816 lines...]
testWithRename(org.vfny.geoserver.ProjectionPolicyTest) Time elapsed: 0 sec <<< ERROR!
java.lang.NullPointerException
  at org.geoserver.test.GeoServerSystemTestSupport.getCatalog(GeoServerSystemTestSupport.java:351)
  at org.vfny.geoserver.ProjectionPolicyTest.testWithRename(ProjectionPolicyTest.java:113)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.801 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.052 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 2.482 sec <<< FAILURE!
testFindDataFileForAbsolutePath(org.vfny.geoserver.global.GeoserverDataDirectoryTest) Time elapsed: 2352 sec <<< ERROR!
java.util.ServiceConfigurationError: org.geotools.coverage.grid.io.GridFormatFactorySpi: Error reading configuration file
  at java.util.ServiceLoader.fail(ServiceLoader.java:224)
  at java.util.ServiceLoader.parse(ServiceLoader.java:301)
  at java.util.ServiceLoader.access$200(ServiceLoader.java:181)
  at java.util.ServiceLoader$LazyIterator.hasNext(ServiceLoader.java:349)
  at java.util.ServiceLoader$1.hasNext(ServiceLoader.java:439)
  at org.geotools.factory.FactoryRegistry.register(FactoryRegistry.java:823)
  at org.geotools.factory.FactoryRegistry.scanForPlugins(FactoryRegistry.java:772)
  at org.geotools.factory.FactoryRegistry.scanForPlugins(FactoryRegistry.java:750)
  at org.geotools.coverage.grid.io.GridFormatFinder.scanForPlugins(GridFormatFinder.java:122)
  at org.geotools.coverage.grid.io.GridFormatFinder.getAvailableFormats(GridFormatFinder.java:85)
  at org.geotools.coverage.grid.io.GridFormatFinder.findFormats(GridFormatFinder.java:178)
  at org.geotools.coverage.grid.io.GridFormatFinder.findFormat(GridFormatFinder.java:241)
  at org.geotools.coverage.grid.io.GridFormatFinder.findFormat(GridFormatFinder.java:216)
  at org.geoserver.data.test.SystemTestData.addRasterLayer(SystemTestData.java:732)
  at org.geoserver.data.test.SystemTestData.addRasterLayer(SystemTestData.java:656)
  at org.geoserver.data.test.SystemTestData.addRasterLayer(SystemTestData.java:643)
  at org.vfny.geoserver.global.GeoserverDataDirectoryTest.onSetUp(GeoserverDataDirectoryTest.java:42)
  at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:222)
  at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:158)
  at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:150)
  at sun.reflect.GeneratedMethodAccessor165.invoke(Unknown Source)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
Caused by: java.util.zip.ZipException: invalid block type
  at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:164)
  at java.io.FilterInputStream.read(FilterInputStream.java:133)
  at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:283)
  at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:325)
  at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:177)
  at java.io.InputStreamReader.read(InputStreamReader.java:184)
  at java.io.BufferedReader.fill(BufferedReader.java:154)
  at java.io.BufferedReader.readLine(BufferedReader.java:317)
  at java.io.BufferedReader.readLine(BufferedReader.java:382)
  at java.util.ServiceLoader.parseLine(ServiceLoader.java:247)
  at java.util.ServiceLoader.parse(ServiceLoader.java:299)
  ... 50 more
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.043 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.429 sec
Results :
Tests in error:
  testFeatureTypeCacheInstance(org.geoserver.catalog.ResourcePoolTest): Trying to get a reader from an unknown format.
  testGeoServerReload(org.geoserver.catalog.ResourcePoolTest): Trying to get a reader from an unknown format.
  testPreserveStructuredReader(org.geoserver.catalog.ResourcePoolTest)
  testMosaicParameters(org.geoserver.catalog.impl.CatalogBuilderIntTest): Could not initialize class org.geotools.gce.imagemosaic.Utils
  testLargeNDMosaic(org.geoserver.catalog.impl.CatalogBuilderIntTest): Could not initialize class org.geotools.gce.imagemosaic.Utils
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): org.geotools.coverage.grid.io.GridFormatFactorySpi: Error reading configuration file
  testForce(org.vfny.geoserver.ProjectionPolicyTest)
  testForceCoverage(org.vfny.geoserver.ProjectionPolicyTest)
  testReproject(org.vfny.geoserver.ProjectionPolicyTest)
  testFindDataFileForAbsolutePath(org.vfny.geoserver.global.GeoserverDataDirectoryTest): org.geotools.coverage.grid.io.GridFormatFactorySpi: Error reading configuration file
Tests run: 563, Failures: 0, Errors: 11, Skipped: 1
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.251s]
[INFO] Core Platform Module .............................. SUCCESS [29.161s]
[INFO] Open Web Service Module ........................... SUCCESS [33.552s]
[INFO] Main Module ....................................... FAILURE [5:13.071s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [1.058s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.590s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.554s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.555s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.826s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.459s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.019s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.978s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.852s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.730s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.521s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.094s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.404s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.604s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.597s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 6:34.583s (Wall Clock)
[INFO] Finished at: Tue Apr 15 03:55:02 UTC 2014
[INFO] Final Memory: 37M/282M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-master/433/&gt;
