See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4358/>
[...truncated 159489 lines...]
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-sec-cas ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-sec-cas ---
[INFO] Compiling 4 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/test-classes>
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports>
T E S T S
Running org.geoserver.security.cas.CasAuthenticationTest
Apr 02, 2017 6:23:05 PM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 1.201 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.354 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 18.742 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.031 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.819 s]
[INFO] Main Module ........................................ SUCCESS [02:24 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.059 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 50.980 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:54 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.388 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.985 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.001 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 45.524 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:36 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:19 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.658 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:10 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.836 s]
[INFO] REST Configuration Service Module .................. FAILURE [01:14 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.040 s]
[INFO] Core UI Module ..................................... SUCCESS [01:10 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.036 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.015 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 33.429 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 40.691 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.548 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.151 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.974 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.050 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:07 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:34 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:14 min]
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 13.240 s]
[INFO] Community Space .................................... SUCCESS [ 0.030 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.664 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.601 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.078 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.441 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.273 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.238 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.376 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.061 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.325 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.021 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.116 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.169 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.020 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:30 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.983 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.666 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.507 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.058 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.516 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.694 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 22.688 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.107 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.844 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.050 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.595 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.512 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.930 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.324 s]
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.753 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.228 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.494 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.644 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.553 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.038 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.058 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.018 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.072 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.304 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 12.875 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.334 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.697 s]
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.616 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.308 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.110 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.442 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 38.983 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.536 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.248 s]
[INFO] BUILD FAILURE
[INFO] Total time: 19:00 min (Wall Clock)
[INFO] Finished at: 2017-04-02T18:23:08+00:00
[INFO] Final Memory: 126M/649M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
