[Geoserver-devel] Build failed in Jenkins: geoserver-master #4365
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4365/&gt;
[...truncated 181529 lines...]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.084 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.186 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [496 msecs]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
Running org.geoserver.security.cas.CasAuthenticationTest
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
Apr 03, 2017 12:16:51 AM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.888 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.345 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.677 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.851 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.961 s]
[INFO] Main Module ........................................ SUCCESS [02:24 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.057 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 53.928 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:55 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.527 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.517 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.153 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.628 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:16 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.589 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:09 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.476 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:14 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.690 s]
[INFO] Core UI Module ..................................... SUCCESS [01:09 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.052 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.215 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.224 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 41.173 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.368 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.185 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 14.743 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.044 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:09 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:34 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:13 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.180 s]
[INFO] Printing Module .................................... SUCCESS [ 13.159 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.509 s]
[INFO] Community Space .................................... SUCCESS [ 0.030 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.025 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:48 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.405 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.286 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 13.373 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.193 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.477 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.250 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.258 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.428 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.659 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.270 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.026 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.860 s]
[INFO] OGR WFS ............................................ SUCCESS [ 9.987 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.022 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:32 min]
[INFO] Excel Output Format ................................ SUCCESS [ 15.577 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.455 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 3.841 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.465 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.588 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.588 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.056 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.589 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.102 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.269 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.385 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 20.890 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.926 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.043 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.484 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.529 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.696 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.073 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.023 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.631 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.387 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.629 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.495 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 39.983 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.330 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 17.781 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.002 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.414 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.310 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 37.856 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.423 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.678 s]
[INFO] BUILD FAILURE
[INFO] Total time: 19:59 min (Wall Clock)
[INFO] Finished at: 2017-04-03T00:16:54+00:00
[INFO] Final Memory: 132M/568M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4366/&gt;
[...truncated 181428 lines...]
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-app ---
[INFO] Compiling 6 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/test-classes&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.028 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-app ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/surefire-reports&gt;
T E S T S
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.076 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.184 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
main:
[INFO]
[INFO] Webapp assembled in [424 msecs]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 15.512 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.308 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.908 s]
[INFO] Main Module ........................................ SUCCESS [02:33 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.052 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.710 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [04:34 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.453 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.595 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.661 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 46.526 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:40 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:31 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 39.477 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:16 min]
[INFO] REST Support Module ................................ SUCCESS [ 15.677 s]
[INFO] REST Configuration Service Module .................. SUCCESS [01:19 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.041 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.044 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 9.918 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 33.590 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 41.514 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.284 s]
[INFO] Demos Module ....................................... SUCCESS [ 22.425 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.736 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.043 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:35 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:16 min]
[INFO] REST UI Module ..................................... SUCCESS [ 13.184 s]
[INFO] Printing Module .................................... SUCCESS [ 13.914 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.935 s]
[INFO] Community Space .................................... SUCCESS [ 0.033 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [01:46 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 13.205 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.417 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 12.867 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.161 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.461 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.242 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.300 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.038 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.673 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.264 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.033 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.218 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.146 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:28 min]
[INFO] Excel Output Format ................................ SUCCESS [ 15.415 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.507 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.598 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.494 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.976 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.631 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.979 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.038 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 15.410 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.579 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.407 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.913 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 21.642 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.666 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.057 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.559 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.581 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.083 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.395 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.024 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.780 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.328 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.637 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.455 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.207 s]
[INFO] Importer REST Api Module ........................... SUCCESS [ 36.512 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.597 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.784 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.519 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.467 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 37.596 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.417 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 6.948 s]
[INFO] Total time: 21:22 min (Wall Clock)
[INFO] Finished at: 2017-04-03T00:38:38+00:00
[INFO] Final Memory: 131M/493M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4367/&gt;
