See <http://ares.opengeo.org/jenkins/job/geoserver-master/445/>
[...truncated 3791 lines...]
at org.geoserver.ows.util.OwsUtils.get(OwsUtils.java:153)
at org.geoserver.ows.util.OwsUtilsTest.testExtended(OwsUtilsTest.java:31)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at junit.framework.TestCase.runTest(TestCase.java:176)
at junit.framework.TestCase.runBare(TestCase.java:141)
at junit.framework.TestResult$1.protect(TestResult.java:122)
at junit.framework.TestResult.runProtected(TestResult.java:142)
at junit.framework.TestResult.run(TestResult.java:125)
at junit.framework.TestCase.run(TestCase.java:129)
at junit.framework.TestSuite.runTest(TestSuite.java:255)
at junit.framework.TestSuite.run(TestSuite.java:250)
at org.junit.internal.runners.JUnit38ClassRunner.run(JUnit38ClassRunner.java:84)
testSimple(org.geoserver.ows.util.OwsUtilsTest) Time elapsed: 3 sec <<< ERROR!
java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
at org.geotools.util.SoftValueHashMap.isValid(SoftValueHashMap.java:152)
at org.geotools.util.SoftValueHashMap.retainStrongly(SoftValueHashMap.java:267)
at org.geotools.util.SoftValueHashMap.put(SoftValueHashMap.java:300)
at org.geoserver.ows.util.OwsUtils.classProperties(OwsUtils.java:90)
at org.geoserver.ows.util.OwsUtils.getter(OwsUtils.java:203)
at org.geoserver.ows.util.OwsUtilsTest.testSimple(OwsUtilsTest.java:18)
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.034 sec <<< FAILURE!
testParseServiceException(org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest) Time elapsed: 31 sec <<< ERROR!
at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:183)
at org.geotools.xml.impl.BindingWalker.walk(BindingWalker.java:190)
at org.geotools.xml.impl.ElementHandlerImpl.startElement(ElementHandlerImpl.java:186)
at org.geotools.xml.impl.ParserHandler.startElement(ParserHandler.java:694)
at org.apache.xalan.transformer.TransformerIdentityImpl.startElement(TransformerIdentityImpl.java:1072)
at org.apache.xml.serializer.TreeWalker.startNode(TreeWalker.java:357)
at org.apache.xml.serializer.TreeWalker.traverse(TreeWalker.java:143)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:389)
at org.geotools.xml.DOMParser.parse(DOMParser.java:89)
at org.geotools.xml.test.XMLTestSupport.parse(XMLTestSupport.java:297)
at org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest.testParseServiceException(ExceptionReportBindingTest.java:46)
Results :
Tests in error:
testHandleServiceExceptionEncoding(org.geoserver.ows.DefaultServiceExceptionHandlerTest): org/geotools/util/SoftValueHashMap$Reference
testHandleServiceExceptionCauses(org.geoserver.ows.DefaultServiceExceptionHandlerTest): org/geotools/util/SoftValueHashMap$Reference
testHandleServiceExceptionEncodingMore(org.geoserver.ows.DefaultServiceExceptionHandlerTest): org/geotools/util/SoftValueHashMap$Reference
testHandleServiceException(org.geoserver.ows.DefaultServiceExceptionHandlerTest): org/geotools/util/SoftValueHashMap$Reference
testErrorSavedOnRequestOnGenericException(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
testDirectInvocationService(org.geoserver.ows.DispatcherTest): Error creating bean with name 'dispatcher' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
testHelloOperationGet(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
testReadContextAndPath(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
testErrorSavedOnRequestOnNon304ErrorCodeException(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
testHelloOperationMixed(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
testHttpErrorCodeException(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
testDispatchWithNamespace(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
testNoErrorOn304ErrorCodeException(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
testReadOpContext(org.geoserver.ows.DispatcherTest): org/geotools/util/SoftValueHashMap$Reference
testParseKVP(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
testParseXML(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
testHelloOperationPost(org.geoserver.ows.DispatcherTest): Error creating bean with name 'extensions' defined in URL [<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: org/geotools/util/SoftValueHashMap$Reference
testEncode(org.geoserver.ows.XmlObjectEncodingResponseTest): org/geotools/util/SoftValueHashMap$Reference
testOutOfOrderSequence(org.geoserver.ows.kvp.ElevationKvpParserTest): org/geotools/util/Range
testMixed(org.geoserver.ows.kvp.ElevationKvpParserTest): org/geotools/util/Range
testPeriod(org.geoserver.ows.kvp.ElevationKvpParserTest): org/geotools/util/Range
initializationError(org.geoserver.ows.kvp.TimeKvpParserTest): org/geotools/util/DateRange
testPut(org.geoserver.ows.util.OwsUtilsTest): org/geotools/util/SoftValueHashMap$Reference
testExtended(org.geoserver.ows.util.OwsUtilsTest): org/geotools/util/SoftValueHashMap$Reference
testSimple(org.geoserver.ows.util.OwsUtilsTest): org/geotools/util/SoftValueHashMap$Reference
testParseServiceException(org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest): org/geotools/util/SoftValueHashMap$Reference
Tests run: 46, Failures: 0, Errors: 26, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.519s]
[INFO] Core Platform Module .............................. SUCCESS [27.617s]
[INFO] Open Web Service Module ........................... FAILURE [21.730s]
[INFO] Main Module ....................................... SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [1.960s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.599s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.459s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.408s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.555s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.649s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.375s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.469s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.345s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.781s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.021s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.217s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.468s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.407s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.456s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:07.346s (Wall Clock)
[INFO] Finished at: Sat Apr 19 17:32:25 UTC 2014
[INFO] Final Memory: 36M/385M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-ows: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/ows/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-ows
