See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4536/changes>
Changes:
[emerkle] Re-enable GeoGig plugin in communityRelease module
[...truncated 161346 lines...]
Running org.geoserver.security.cas.CasAuthenticationTest
Apr 11, 2017 5:07:43 AM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.82 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.342 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.906 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 18.064 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.002 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.157 s]
[INFO] Main Module ........................................ SUCCESS [02:25 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 2.273 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 53.735 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [04:29 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 5.594 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.066 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.311 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 50.363 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:40 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:35 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 37.709 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:13 min]
[INFO] REST Support Module ................................ SUCCESS [ 16.159 s]
[INFO] REST Configuration Service Module .................. FAILURE [01:16 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.089 s]
[INFO] Core UI Module ..................................... SUCCESS [01:13 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.070 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.807 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 33.494 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 40.819 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.603 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.266 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.575 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.342 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:09 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:31 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:13 min]
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 15.729 s]
[INFO] Community Space .................................... SUCCESS [ 0.480 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.044 s]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.586 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.869 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.148 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.445 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.266 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.260 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 10.336 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.590 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 1.001 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.053 s]
[INFO] OGR CORE ........................................... SUCCESS [ 3.004 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.544 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.054 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:30 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.806 s]
[INFO] Excel Output Format ................................ SUCCESS [ 18.773 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.581 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.147 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.558 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.900 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 18.330 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 29.571 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.486 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 3.177 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.088 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 16.604 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.665 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.338 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 9.367 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.090 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.591 s]
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 30.885 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.059 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 11.064 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.583 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.621 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.031 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.036 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.635 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.411 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.064 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 18.993 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.583 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.791 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.395 s]
[INFO] Importer Core Module ............................... SUCCESS [ 38.167 s]
[INFO] Importer REST Api Module ........................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.994 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.107 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.828 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.457 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 36.477 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.058 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 7.022 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:18 min (Wall Clock)
[INFO] Finished at: 2017-04-11T05:07:46+00:00
[INFO] Final Memory: 126M/545M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-restconfig
