See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4543/changes>
Changes:
[tbarsballe] Spring MVC Example
[mike] Adding new api doc area
[mike] Adding operationIds to Swagger example
[andrea.aime] Upgrading to Spring 4.3.7 and updating example to shorter annotations.
[andrea.aime] Adding round trip tests for coverage stores
[tbarsballe] Consolidate wrapper classes
[mkruszewski] Added doc generation pom at doc/en/en.xml
[tbarsballe] Split rest-ng into rest-ng and restconfig-ng
[mike] Updates to styles.yaml
[mike] Changing description of styles.yaml
[jody.garnett] remove some warnings so sphinx will build without warnings
[jody.garnett] initial build.xml ant script
[jody.garnett] fix rst warnings in developers guide
[andrea.aime] Testing denial of harvest on simple coverage stores
[jody.garnett] connect pom.xml to sphinx ant build
[tbarsballe] Add RequestInfo
[ijturton] round trip test added for workspaces
[jody.garnett] Use maven target folder for API documentation generation
[nuno.oliveira] Add tests for JSON serialization / deserealization
[mike] styles.yaml now mentions multiple POST options
[jody.garnett] mv api docs to standard maven directory layout
[jody.garnett] limit swagger to process-resources stage of build
[mkruszewski] Create top-level api.yaml file
[tbarsballe] Remove rest and restconfig dependencies from ng modules
[mike] Adding new styles REST endpoint page in user manual
[jody.garnett] generate user guide with generated swagger api docs
[jody.garnett] single api doc for example
[jody.garnett] remove reference to parent pom
[mike] Adding dummy workspaces.yaml page
[andrea.aime] Partial port of coverage stores, and ability to configure xstream
[jody.garnett] multiple endpoint example for docs
[tbarsballe] Make converters pluggable, add restconfig-ng dependency to web-app
[jody.garnett] link to workspace api docs
[ksmith] Stop depending on demo.opengeo.org for WMSLayerTest
[mike] Adding fonts API reference plus examples
[tbarsballe] XStreamMessageConverter doesn't need applicationContext
[mike] Fixing syntax error in fonts.yaml
[nuno.oliveira] Testing listing non configured coverages in JSON
[andrea.aime] Post still missing, fix me
[andrea.aime] Coverage store tests done to the extent they can be done now (missing
[jody.garnett] additional build targets
[jody.garnett] documentation build instructions
[tbarsballe] Support XStreamPersisterConfiguration before read.
[tbarsballe] Consolidate CatalogController and CatalogControllerAdvice
[tbarsballe] Use constants for all mime (and mime-like) types in StyleControler
[nuno.oliveira] Testing updating coverage using JSON payload
[andrea.aime] Added API documentation for coverage stores endpoint
[andrea.aime] Return a 404 when listing a coverage store in a non existing workspace
[tbarsballe] Add IndexController
[mike] Adding layergroups API doc
[ksmith] WMSStoreController
[jody.garnett] headers and warnings
[jody.garnett] fix from kevin merge hell
[tbarsballe] Add configurePersister method to RestBaseController
[ijturton] latest Workspace controller changes including HTML template fixes
[tbarsballe] Refactor configurePersistor implementation in WMSStoreController
[mike] Adding workspace-specific layer groups API details
[ijturton] add missing test class
[ijturton] wip
[niels] AboutController and AboutStatusController
[tbarsballe] Call configurePersister from XStreamCatalogListConverter
[jody.garnett] Initial LayerController implementation
[jody.garnett] Update javadocs for settings onlineResource
[jody.garnett] StyleController
[ijturton] working workspaces
[andrea.aime] Coverage store file upload support
[qscripter] add round trip test for LayerGroupInfo
[qscripter] implementation of LayerGroupController
[tbarsballe] Consolidate redundant request methods in StyleController
[mike] Adding API page for settings
[andrea.aime] API documentation for coverage upload
[jody.garnett] initial swagger file for layers
[jody.garnett] layer controller completed
[nuno.oliveira] GEOS-7989 WMS/WCS supports only String typed custom dimensions
[nuno.oliveira] Fix an issue which prevented editing newly added remotes and configs.
[nuno.oliveira] Add coverages controller
[andrea.aime] Initial implementation of structured coverage granule index
[dvick] Completed DataStoreController
[ijturton] Namespace XMl & JSON endpoints
[tbarsballe] Add CatalogReloadController
[ijturton] add missing template
[ijturton] WIP Namespaces
[ijturton] working Namespaces
[dvick] documentation for data store controller.
[tbarsballe] IndexController: Sorted index + test improvements
[tbarsballe] Rename templates to ftl-templates to avoid collissions with old
[tbarsballe] IndexController: Only list GET endpoints
[nuno.oliveira] Coverages REST controller
[jody.garnett] layers update for single layer
[jody.garnett] prototype of using @class attibute property on an array
[mike] Adding workspace-specific settings
[tbarsballe] Revert unintentional changes to restconfig
[tbarsballe] API docs for CatalogReloadController
[jody.garnett] Change how arrays are documented to allow for class linked-hash-map
[tbarsballe] Disable GeoServerAboutPageTest. REVERT THIS AFTER THE SPRINT
[mkruszewski] Add FeatureTypeController + templates
[andrea.aime] Structured grid coverage controller implementation
[jody.garnett] Completed documentation for Layer
[ijturton] documentation and tidy up for workspace and namespace
[tbarsballe] Add SettingsController for global and local settings
[jody.garnett] restruture rst
[jody.garnett] restructure rest rst
[andrea.aime] Futher JSON representation fixes for structured coverages
[mkruszewski] Initial work on featureTypeInfo.yaml
[mkruszewski] Additions to featureTypes.yaml api definition
[mike] Adding security API docs
[tbarsballe] Improvements to ObjectToMapWrapper to support nested object maps; fix
[tbarsballe] Simplify anonymous extends of ObjectToMapWrapper
[andrea.aime] Structured coverages documentation
[andrea.aime] Partial work on master password, and porting over map xml and json data
[andrea.aime] Master password controller
[ijturton] Rest controller for fonts
[ksmith] Activate WMSLayerTest
[ksmith] WMSLayerController
[mkruszewski] Fixes for featureTypes.yaml
[ijturton] User password controller
[mkruszewski] Consildate shared FeatureTypeFinder code in FeatureTypeController
[ijturton] new package for rest-ng in importer
[nuno.oliveira] Coverages REST controller documentation
[qscripter] add round trip tests for WMSSettings
[qscripter] implement WMSSettingsController
[ijturton] added status code support for JSON requests
[mike] Updating styles API endpoint docs to include workspace- layer-specific
[mkruszewski] Add api docs for /about/ endpoints
[jody.garnett] This is an exceptional commit message
[nuno.oliveira] Add converters for lists of strings
[jody.garnett] TemplateController
[jody.garnett] m2 eclipse plugin breaks things
[ksmith] WMSLayerController POST
[andrea.aime] ACL controllers
[mkruszewski] Set default content type to text/html
[dvick] 13 passing tests
[dvick] completed DataStoreFileUploadController. All tests passing.
[mike] First pass of wmsstores API endpoint docs
[qscripter] adding additional tests and updating delete mapping for
[qscripter] implementation of WFS and WCS settings controllers, move service
[ksmith] WMSLayerController and WMSStoreController
[ksmith] Use RestBaseController.ROOT_PATH in WMSStore/WMSLayer tests
[jody.garnett] templates testing
[jody.garnett] Default FTL type for TemplateController
[ijturton] WIP importer
[ijturton] Add query string handling to RequestInfo
[mkruszewski] Disable default HTML content type
[mkruszewski] Add FeatureTypeTests; Set FTController to produce HTML first.
[mkruszewski] AboutController(+Test), AboutStatusController(+Test), + templates
[ijturton] add missing JSONRep
[tbarsballe] Document local settings POST
[tbarsballe] Resource GET WIP
[tbarsballe] Resource GET improvements
[andrea.aime] Rest dispatcher callbacks work in progress
[andrea.aime] Making sure to check for workspace existance and full admin rights to
[ksmith] WMSStore HTML
[ksmith] WMLLayer HTML
[jody.garnett] Use produces order to supply correct default
[jody.garnett] ResourceController javadocs
[jody.garnett] Refactor after desk code review
[jody.garnett] Test class naming consistency
[tbarsballe] Disable restconfig-ng in gs-web-app to avoid package conflicts
[tbarsballe] Fix collection handling for ObjectToMapWrapper
[tbarsballe] Fixup resource refactoring
[jody.garnett] Initial implementation of resourcePut
[jody.garnett] Resource delete
[qscripter] re-enable rest-ng and comment out rest from webapp pom
[mkruszewski] Doc updates
[tbarsballe] Handle resource content GET
[mike] Adding API docs for wmslayers endpoint
[jody.garnett] Put implementation migrated from ResourceResource to support move and
[dvick] beging of importer data resource controller and tests, as well as
[dvick] adding importer data work.
[tbarsballe] Support character encoding for ResourceController paths
[ijturton] Working ImportContext/resource end point
[tbarsballe] Improve response codes for Resource DELETE
[tbarsballe] Fix NPE in ObjectToMapWrapper
[qscripter] initial docs for OWS service endpoints
[mike] Cleaning up wmsstores.yaml
[tbarsballe] Move zip/upload handling to IOUtils
[mike] Removing duplicate workspaces.yaml
[mike] Reorganizing pom for API endpoints
[ijturton] adding reader
[mike] Adding missing YAML files to pom
[jody.garnett] Complete Resource MOVE and COPY
[tbarsballe] Refactor importController, moving general logic to ImportBaseController
[ijturton] fixed DataImporter
[andrea.aime] Callback to configure extra media types
[tbarsballe] Add ImportTaskController, support task GET
[ijturton] fixed issue with .shp ending
[mike] Updated owsServices.yaml
[andrea.aime] Monitor module migrated
[jody.garnett] correct layers documentation
[jody.garnett] Layers is now warning free
[jody.garnett] template draft
[nuno.oliveira] XSLT REST controller
[mike] Making operationIDs unique on styles.yaml
[mike] Fixing errors with styles.yaml
[mike] Compacting Style body code in styles.yaml
[mkruszewski] ImportTransformController and supporting tests & converters
[tbarsballe] Import Task GET
[tbarsballe] Add Import Data DELETE
[tbarsballe] Fixup importer reader/writer
[qscripter] all remaining instances of /restng updated to use
[jody.garnett] Hanlde StyleController raw=true uploads
[nuno.oliveira] Add XSLT module REST documentation
[andrea.aime] Monitor documentation and fixes to wmsLayer
[andrea.aime] Make delete work when store and workspace do not have the same name
[andrea.aime] Restore previous behavior, create corresponding namespace along with
[andrea.aime] Do not assume restng in test
[andrea.aime] Fix template lookup for resources
[andrea.aime] Relax mediatype matching
[andrea.aime] Re-instante backwards compatibility, creating a namespace triggers
[andrea.aime] Re-instating backwards compatibility, it is possible to remove all
[andrea.aime] Re-instate backwards compatibility vs path variable decoding
[andrea.aime] Make structured coverage work when the coverage does not share the name
[andrea.aime] Datastore xml representation was not pointing to underlying feature
[andrea.aime] Make sure supports is implemented when configureXStreamPersiter is (as
[andrea.aime] Fix test expectation
[jody.garnett] Testing rest api with YSLD
[jody.garnett] Confirm StyleController raw can be used with YSLD
[andrea.aime] LayerGroupController does not encode links to contained layers and
[andrea.aime] Feature type controller returns all workspace feature types when asked
[andrea.aime] Re-instante backwards compatibility, workspace managed during store
[andrea.aime] Support gsConfig weird /granules/granule.id/.json path in deletes
[andrea.aime] Get the right mime type for xml atom backlinks
[andrea.aime] Re-instante automatic workspace assignment on store creation
[andrea.aime] Setting the default workspace is not the same as changing an existing
[andrea.aime] Setting the default namespace is not the same as modifying an existing
[tbarsballe] Import Task Layer GET, improve Import rest-n tests
[tbarsballe] Update javadocs on RestBaseController
[jody.garnett] StyleController now hanldes raw true/false for YSLD
[tbarsballe] Import PUT/POST/DELETE
[tbarsballe] Import REST ng - Clean up license, docs, and imports
[tbarsballe] Remove JSONRepresentation from importer rest-ng
[tbarsballe] Remove extranous import
[tbarsballe] Fixup compile failures in importer rest-ng
[tbarsballe] Fixup ImportTransformController
[tbarsballe] FIx weird Importer PUT task as file content type issues
[tbarsballe] Fix importer test failures cause by request context inconsistencies
[tbarsballe] Fix response codes for DataStore file PUT
[tbarsballe] Fixup FeatureTypeController behavior to pass gsconfig tests
[tbarsballe] Add custom content negotiation for certain paths
[tbarsballe] Fixup ysld compile failures (missing dependnecies)
[tbarsballe] Refactor org.geoserver.catalog.rest to org.geoserver.rest.catalog
[tbarsballe] Remove old gs-rest modules
[tbarsballe] Fixup import PUT by id, add support for import DELETE
[tbarsballe] Importer rest - fix up response codes, support POST to id when import
[tbarsballe] Revert "Disable GeoServerAboutPageTest. REVERT THIS AFTER THE SPRINT"
[tbarsballe] Consolidate PathMappings
[tbarsballe] Make RequestMapping path syntax and PathVariable names consistent
[tbarsballe] Consistent RequestMapping formatting
[tbarsballe] Consistent method names for controllers
[tbarsballe] Add @Qualifier(geoServer) to children of GeoServerController
[jody.garnett] Extending AbstractMonitorRequestConverter
[jody.garnett] Initial change to AbstractHttpMessageConverter for consistent mimeType
[jody.garnett] Directrly extrend AbstractHttpMessageConverter
[jody.garnett] Rename to BaseMonitorCoverter
[jody.garnett] AvailableResources appears to be a duplicate of StringsList
[jody.garnett] Logger against rest, not restng
[jody.garnett] Catch up with refactor to org.geoserver.rest.catalog
[jody.garnett] Refactory to ImportJSONReader and ImportJSONWriter utility classes
[jody.garnett] Convert json field to a parameter
[jody.garnett] complete converters
[jody.garnett] fun with lamdas changing signature
[jody.garnett] Fix test cases, mostly arguing over mime types
[jody.garnett] fix up remaining errors
[tbarsballe] Fixup method signatures in importer rest controllers
[tbarsballe] Move custom media types to dedicated class
[tbarsballe] Refactor abstract classes
[tbarsballe] Make rest-ng package names consistent
[tbarsballe] Move rest-ng et al to rest
[tbarsballe] Rename references to rest-ng et al to rest
[tbarsballe] Add missing headers
[tbarsballe] Clean up compiler warnings
[tbarsballe] Fixup extensions after refactor
[ben] Fix app-schema compilation failure caused by CatalogRESTTestSupport
[ben] Fix REST H2 file upload
[jody.garnett] fix typo
[...truncated 187791 lines...]
[ERROR] class BackupResource
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[46,49\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[49,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[49,46\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[54,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[54,44\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[61,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[66,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[71,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[76,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[78,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[78,31\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[83,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[85,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[89,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[101,30\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[103,30\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[111,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[115,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[117,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[117,31\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[122,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[129,30\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[131,30\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[134,43\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[134,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[135,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[136,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[149,25\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[151,50\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[152,53\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[153,109\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[153,79\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[163,47\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[163,16\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[164,40\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[164,16\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[165,16\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[167,78\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[170,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[172,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[185,19\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[193,26\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/BackupResource.java>:\[201,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[43,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[46,13\] error: cannot find symbol
[ERROR] class RestoreResource
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[46,49\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[49,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[49,46\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[54,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[54,44\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[61,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[66,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[72,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[77,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[79,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[79,31\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[84,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[86,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[90,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[101,30\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[103,30\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[111,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[115,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[117,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[117,31\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[122,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[129,30\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[131,30\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[134,43\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[134,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[135,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[136,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[149,25\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[151,50\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[152,53\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[153,111\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/backup-restore/rest/src/main/java/org/geoserver/backuprestore/rest/RestoreResource.java>:\[153,81\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-notification: Compilation failure: Compilation failure:
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[31,33\] error: package org.geoserver.catalog.rest does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[56,37\] error: cannot find symbol
[ERROR] class CatalogRESTTestSupport
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousIntegrationTest.java>:\[13,33\] error: package org.geoserver.catalog.rest does not exist
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousIntegrationTest.java>:\[26,46\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[82,27\] error: cannot find symbol
[ERROR] class IntegrationTest
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[84,18\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[87,25\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[88,27\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[89,29\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[96,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[100,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[102,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[105,16\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[121,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[138,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[140,39\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[146,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[163,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[167,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[182,47\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[183,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[186,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[188,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[189,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[206,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[216,47\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[217,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[221,12\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[225,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[226,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[246,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[256,27\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[259,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[261,26\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[264,20\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[265,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[284,28\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[286,22\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[288,27\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[290,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[325,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[347,29\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[349,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[354,31\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[356,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/IntegrationTest.java>:\[357,8\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousIntegrationTest.java>:\[51,4\] error: method does not override or implement a method from a supertype
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousIntegrationTest.java>:\[53,8\] error: cannot find symbol
[ERROR] class AnonymousIntegrationTest
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousIntegrationTest.java>:\[55,24\] error: cannot find symbol
[ERROR] <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/community/notification/src/test/java/org/geoserver/notification/AnonymousIntegrationTest.java>:\[64,8\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-rest-ext
