[Geoserver-devel] Build failed in Jenkins: geoserver-master #4638
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4638/&gt;
[...truncated 70075 lines...]
Apr 27, 2017 4:10:25 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
Apr 27, 2017 4:10:25 AM org.geotools.image.ImageWorker <clinit>
INFO: Warp/affine reduction enabled: true
WARNING: Extension lookup 'XStreamPersisterInitializer', but ApplicationContext is unset.
Apr 27, 2017 4:10:26 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
Apr 27, 2017 4:10:27 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
Apr 27, 2017 4:10:28 AM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'sf', enabled
INFO: Loaded feature type 'GenericEntity', enabled
INFO: Loaded feature type 'AggregateGeoFeature', enabled
INFO: Loaded feature type 'PrimitiveGeoFeature', enabled
INFO: Loaded store 'cite', enabled
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'Lakes', enabled
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Inserts', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded feature type 'Updates', enabled
INFO: Loaded feature type 'Deletes', enabled
INFO: Loaded feature type 'Seven', enabled
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.33 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-csw ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-csw ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/csw/web-csw/target/gs-web-csw-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/csw/gs-web-csw/2.12-SNAPSHOT/gs-web-csw-2.12-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.558 s]
[INFO] Core Platform Module ............................... SUCCESS [ 16.159 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.304 s]
[INFO] Main Module ........................................ SUCCESS [02:36 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.060 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 50.917 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [04:44 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.399 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.504 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.546 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [01:04 min]
[INFO] Web Feature Service Module ......................... FAILURE [01:43 min]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 16.391 s]
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.064 s]
[INFO] Core UI Module ..................................... SUCCESS [01:16 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.037 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 10.868 s]
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.052 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 13.741 s]
[INFO] Community Space .................................... SUCCESS [ 0.030 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.028 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 13.119 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.515 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.582 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.311 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.248 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.745 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.279 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.049 s]
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.024 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.450 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.069 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.466 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.745 s]
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.026 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.048 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.307 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.129 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 43.136 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 10.890 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.021 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.024 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 22.507 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.546 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.708 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 10:22 min (Wall Clock)
[INFO] Finished at: 2017-04-27T04:10:30+00:00
[INFO] Final Memory: 111M/627M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4639/&gt;
