[Geoserver-devel] Build failed in Jenkins: geoserver-master #4654
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4654/&gt;
[...truncated 166069 lines...]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/rest/target/gs-importer-rest-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-rest/2.12-SNAPSHOT/gs-importer-rest-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT.pom
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-sec-cas ---
[INFO] Surefire report directory: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/surefire-reports&gt;
T E S T S
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
Running org.geoserver.security.cas.CasAuthenticationTest
Apr 28, 2017 11:38:28 AM org.geoserver.security.cas.LiveCasData disableTest
WARNING: Disabling test based on fixture cas since the file /var/lib/jenkins/.geoserver/cas.properties could not be found
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.823 sec
Running org.geoserver.security.cas.CasFilterConfigValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.323 sec
Results :
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 14.316 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.458 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 14.719 s]
[INFO] Main Module ........................................ SUCCESS [02:43 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.145 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.142 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:05 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 4.294 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 55.556 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.869 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 55.825 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:35 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.896 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:27 min]
[INFO] gs-rest ............................................ SUCCESS [ 16.242 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:06 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.190 s]
[INFO] Core UI Module ..................................... SUCCESS [01:15 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.128 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 11.592 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 34.834 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.789 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 15.095 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.196 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.383 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.215 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:08 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:34 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:17 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.553 s]
[INFO] Printing Module .................................... SUCCESS [ 16.617 s]
[INFO] Community Space .................................... SUCCESS [ 0.074 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.067 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:38 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 17.290 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 14.474 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 17.775 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 2.186 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.556 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.370 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.400 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.050 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.974 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.423 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.089 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.876 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.966 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.084 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 16.648 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.576 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.183 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.635 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.882 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.818 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.241 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.080 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 28.344 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 10.110 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.120 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.379 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.147 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.483 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 24.878 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.071 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 15.757 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.516 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.272 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.974 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.060 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.485 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.047 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.105 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.371 s]
[INFO] Importer Core Module ............................... SUCCESS [ 42.528 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.584 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.832 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.369 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 22.022 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.566 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.380 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 17.729 s]
[INFO] BUILD FAILURE
[INFO] Total time: 21:09 min (Wall Clock)
[INFO] Finished at: 2017-04-28T11:38:31+00:00
[INFO] Final Memory: 122M/481M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4655/&gt;
[...truncated 166060 lines...]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.121 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Apr 28, 2017 12:06:35 PM org.geoserver.security.cas.LiveCasData disableTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.795 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.333 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 20.824 s]
[INFO] Core Platform Module ............................... SUCCESS [ 12.481 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 17.844 s]
[INFO] Main Module ........................................ SUCCESS [02:26 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.052 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.171 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:56 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.308 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.076 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 28.837 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 51.194 s]
[INFO] Web Map Service Module ............................. SUCCESS [02:30 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.338 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:55 min]
[INFO] gs-rest ............................................ SUCCESS [ 15.551 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:25 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.049 s]
[INFO] Core UI Module ..................................... SUCCESS [01:12 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.048 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 9.905 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 33.038 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 41.927 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.575 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.710 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.819 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.051 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:09 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:35 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:14 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.845 s]
[INFO] Printing Module .................................... SUCCESS [ 13.862 s]
[INFO] Community Space .................................... SUCCESS [ 0.078 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.033 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:42 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 24.250 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.522 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 16.786 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 5.585 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.429 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.241 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.229 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.440 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.295 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.256 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.048 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.867 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.025 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.168 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.459 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.221 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.473 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.926 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.902 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 1.976 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.053 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 24.740 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.082 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.071 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.611 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.042 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.343 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 23.451 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.040 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.775 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.834 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.754 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 12.236 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.035 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.228 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.033 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.427 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [01:04 min]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 45.854 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 17.927 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.554 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.587 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 20.288 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.406 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 33.397 s]
[INFO] Total time: 21:00 min (Wall Clock)
[INFO] Finished at: 2017-04-28T12:06:38+00:00
[INFO] Final Memory: 124M/643M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4656/changes&gt;
