See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4671/changes>
Changes:
[jody.garnett] [GEOS-8119] REST API migration broke ability to extract non SLD style
[jody.garnett] [GEOS-8118] REST API switch broke non SLD to SLD format
[jody.garnett] revise based on feedback
[...truncated 192857 lines...]
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/maven-metadata.xml (2 KB at 22.6 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525.jar (26 KB at 184.8 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525.pom (3 KB at 22.7 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/maven-metadata.xml (565 B at 9.0 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/maven-metadata.xml (2 KB at 15.7 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/maven-metadata.xml (518 B at 5.0 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525-tests.jar (18 KB at 143.3 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/maven-metadata.xml (2 KB at 15.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525-sources.jar (13 KB at 118.6 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525-test-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-sec-ldap/2.12-SNAPSHOT/gs-web-sec-ldap-2.12-20170502.051606-525-test-sources.jar (7 KB at 65.4 KB/sec)
[INFO]
[INFO] Building REST UI Module 2.12-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-rest ---
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-web-rest ---
[INFO] Copying 2 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-rest ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-rest ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/rest/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-rest ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-rest ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-rest ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-rest ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-rest ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-rest ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/rest/target/gs-web-rest-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-rest ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/rest/target/gs-web-rest-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/rest/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/rest/target/gs-web-rest-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/rest/target/gs-web-rest-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/rest/target/gs-web-rest-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ gs-web-rest ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/maven-metadata.xml (2 KB at 4.3 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-20170502.051607-525.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-20170502.051607-525.jar (5 KB at 0.9 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-20170502.051607-525.pom
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-20170502.051607-525.pom (2 KB at 2.1 KB/sec)
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/maven-metadata.xml
[INFO] Downloaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/maven-metadata.xml (561 B at 1.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/maven-metadata.xml (2 KB at 4.7 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/maven-metadata.xml
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/maven-metadata.xml (514 B at 0.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-20170502.051607-525-tests.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-20170502.051607-525-tests.jar (5 KB at 1.6 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/maven-metadata.xml (2 KB at 0.1 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-20170502.051607-525-sources.jar
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-20170502.051607-525-sources.jar (3 KB at 0.9 KB/sec)
[INFO] Uploaded: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/maven-metadata.xml (2 KB at 0.4 KB/sec)
[INFO] Uploading: https://repo.boundlessgeo.com/snapshot/org/geoserver/web/gs-web-rest/2.12-SNAPSHOT/gs-web-rest-2.12-20170502.051607-525-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.803 s]
[INFO] Core Platform Module ............................... SUCCESS [ 1.779 s]
[INFO] Open Web Service Module ............................ SUCCESS [15:49 min]
[INFO] Main Module ........................................ SUCCESS [ 16.207 s]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.757 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 1.282 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [ 1.253 s]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 1.156 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 1.874 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 1.747 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 1.868 s]
[INFO] Web Feature Service Module ......................... SUCCESS [ 2.227 s]
[INFO] Web Map Service Module ............................. SUCCESS [ 5.686 s]
[INFO] KML support for GeoServer .......................... SUCCESS [ 1.765 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [ 7.097 s]
[INFO] gs-rest ............................................ SUCCESS [ 1.382 s]
[INFO] gs-restconfig ...................................... SUCCESS [ 4.147 s]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.587 s]
[INFO] Core UI Module ..................................... SUCCESS [ 4.096 s]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.965 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 1.634 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 1.712 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 1.769 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 1.100 s]
[INFO] Demos Module ....................................... SUCCESS [ 1.979 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 1.703 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.628 s]
[INFO] Security UI Core Module ............................ SUCCESS [ 2.237 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [ 2.338 s]
[INFO] Security UI LDAP Module ............................ SUCCESS [ 1.704 s]
[INFO] REST UI Module ..................................... FAILURE [01:40 min]
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] Aggregating Data Store ............................. SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 18:54 min
[INFO] Finished at: 2017-05-02T05:17:48+00:00
[INFO] Final Memory: 146M/596M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project gs-web-rest: Failed to deploy artifacts: Could not transfer artifact org.geoserver.web:gs-web-rest:jar:test-sources:2.12-20170502.051607-525 from/to boundless (https://repo.boundlessgeo.com/snapshot/): repo.boundlessgeo.com:443 failed to respond -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-web-rest
