[Geoserver-devel] Build failed in Jenkins: geoserver-master #4674
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4674/changes&gt;
Changes:
[jody.garnett] Squashed commit of the following:
[jody.garnett] [GEOS-8117] Improve support for null service/version/request in
[jody.garnett] [GEOS-8040] Fixed accessing resources in subdirectories of the styles
[...truncated 179761 lines...]
T E S T S
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.071 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.184 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
     [echo] Copying data dir from ../../../data/minimal
May 02, 2017 6:17:33 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
     [copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data&gt;
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in [449 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt;
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
May 02, 2017 6:17:35 PM org.geoserver.catalog.ResourcePool getFeatureType
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.599 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 7.601 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.867 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 16.494 s]
[INFO] Main Module ........................................ SUCCESS [02:27 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 1.730 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.154 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:04 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 2.795 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.461 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.255 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 52.687 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:29 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.225 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:18 min]
[INFO] gs-rest ............................................ SUCCESS [ 15.946 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:12 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.043 s]
[INFO] Core UI Module ..................................... SUCCESS [01:14 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.034 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.549 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 36.613 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 45.883 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 12.010 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.837 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 17.364 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.068 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:20 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:35 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:12 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.410 s]
[INFO] Printing Module .................................... SUCCESS [ 14.227 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 6.169 s]
[INFO] Community Space .................................... SUCCESS [ 0.384 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.277 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:43 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.323 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.908 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 17.584 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.082 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.841 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.274 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.250 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.657 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.313 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.937 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.026 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.988 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.013 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.028 s]
[INFO] Web Processing Service Module ...................... SUCCESS [01:38 min]
[INFO] OGR WPS ............................................ SUCCESS [ 10.662 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.574 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.534 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.907 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.942 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.339 s]
[INFO] Web process status sharing with Hazelcast .......... SUCCESS [ 17.553 s]
[INFO] Web Processing Service GUI ......................... SUCCESS [ 30.049 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 17.888 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.170 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 31.401 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.849 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.831 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.363 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 27.851 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 36.925 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.610 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 11.066 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 45.527 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.487 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.923 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 15.630 s]
[INFO] DXF WPS PPIO ....................................... SUCCESS [ 10.518 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.029 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 20.801 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.557 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 12.190 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.057 s]
[INFO] Importer Core Module ............................... SUCCESS [ 41.234 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 42.257 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 17.959 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.181 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.518 s]
[INFO] NetCDF Coverage format ............................. FAILURE [ 27.964 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 9.227 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.577 s]
[INFO] BUILD FAILURE
[INFO] Total time: 22:31 min (Wall Clock)
[INFO] Finished at: 2017-05-02T18:17:38+00:00
[INFO] Final Memory: 134M/654M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-netcdf: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-netcdf
And again :wink:
<details class='elided'>
<summary title='Show trimmed content'>&#183;&#183;&#183;</summary>
On Tue, May 2, 2017 at 8:17 PM, <[monitor@anonymised.com](mailto:monitor@anonymised.com39...)> wrote:
> See <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4674/changes](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4674/changes)>
> Changes:
> T E S T S
> Results :
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar)>
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar)>
> [INFO]
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar)>
> [INFO]
> main:
> [copy] Copying 29 files to <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data)>
> [INFO]
> [INFO] Assembling webapp [gs-web-app] in [<[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver)]>
> [INFO] Copying webapp resources [<[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp)]>
> [INFO] Building war: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war)>
> [INFO]
> [INFO]
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war)> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml)> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar)> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar)> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war)> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
> [INFO]
> [INFO]
> [INFO] Deleting <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target)>
> [INFO]
> [INFO]
> [INFO]
> [INFO] skip non existing resourceDirectory <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources)>
> [INFO]
> [INFO] Compiling 2 source files to <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes)>
> Results :
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar)>
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar)>
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar)>
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar)>
> [INFO]
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar)> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.jar
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml)> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.pom
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar)> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-tests.jar
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar)> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-sources.jar
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar)> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-test-sources.jar
> [INFO]
> [INFO] skip non existing resourceDirectory <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java)>
> [INFO] skip non existing resourceDirectory <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources)>
> [INFO]
> [INFO]
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar)>
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar)>
> [INFO]
> [INFO] Building jar: <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar)>
> [INFO]
> [INFO]
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar)> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml)> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar)> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
> [INFO] Installing <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar)> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
> [INFO]
> [ERROR]
> [ERROR] Please refer to <[http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf/target/surefire-reports](http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf/target/surefire-reports)> for the individual test results.
> [ERROR] -> [Help 1]
> [ERROR]
> [ERROR]
> [ERROR] [Help 1] [http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException](http://cwiki.apache.org/confluence/display/MAVEN/MojoFailureException)
> [ERROR]
> Check out the vibrant tech community on one of the world's most
> engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
> Geoserver-devel mailing list
> [Geoserver-devel@anonymised.com.366...sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
> [https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
[http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
**AVVERTENZE AI SENSI DEL D.Lgs. 196/2003**
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
</details>
restart?
On 2 May 2017 at 11:37, Andrea Aime <andrea.aime@anonymised.com> wrote:
And again :wink:
Test set: org.geoserver.netcdf.NetCDFGetFeatureInfoTest
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 7.975 sec <<< FAILURE!
org.geoserver.netcdf.NetCDFGetFeatureInfoTest  Time elapsed: 7972 sec  <<< ERROR!
java.io.IOException: Unable to delete directory ./target/default8989027234526976461data.
	at [org.apache.commons.io](http://org.apache.commons.io).FileUtils.deleteDirectory(FileUtils.java:1337)
	at org.geoserver.data.test.SystemTestData.tearDown(SystemTestData.java:1026)
	at org.geoserver.test.GeoServerBaseTestSupport.doTearDownClass(GeoServerBaseTestSupport.java:206)
Jody Garnett
On Tue, May 2, 2017 at 8:17 PM, <monitor@anonymised.com> wrote:
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4674/changes>
Changes:
[…truncated 179761 lines…]
T E S T S
Results :
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-app —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app —
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app —
main:
[echo] Copying data dir from …/…/…/data/minimal
[copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data>
[INFO]
[INFO] — maven-war-plugin:2.3:war (default) @ gs-web-app —
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver]>
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp]>
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] — build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-app —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
[INFO]
[INFO]
[INFO] — maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec-cas —
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO]
[INFO] — cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas —
[INFO]
[INFO] — git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-resources-plugin:2.6:resources (default-resources) @ gs-web-sec-cas —
[INFO] Using ‘UTF-8’ encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-web-sec-cas —
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
Results :
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-importer-web —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] — maven-resources-plugin:2.6:testResources (default-testResources) @ gs-web-sec-cas —
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] — maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-surefire-plugin:2.12.3:test (default-test) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-jar-plugin:2.4:jar (default-jar) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar>
[INFO]
[INFO] — maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec-cas —
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] — maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec-cas —
[INFO]
[INFO] — maven-install-plugin:2.4:install (default-install) @ gs-web-sec-cas —
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO]
[INFO] GeoServer … SUCCESS [ 7.601 s]
[INFO] Core Platform Module … SUCCESS [ 15.867 s]
[INFO] Open Web Service Module … SUCCESS [ 16.494 s]
[INFO] Main Module … SUCCESS [02:27 min]
[INFO] GeoServer Security Modules … SUCCESS [ 1.730 s]
[INFO] GeoServer JDBC Security Module … SUCCESS [ 57.154 s]
[INFO] GeoServer LDAP Security Module … SUCCESS [03:04 min]
[INFO] Web Coverage Service Module … SUCCESS [ 2.795 s]
[INFO] Web Coverage Service 1.0 Module … SUCCESS [ 24.461 s]
[INFO] Web Coverage Service 1.1 Module … SUCCESS [ 29.255 s]
[INFO] Web Coverage Service 2.0 Module … SUCCESS [ 52.687 s]
[INFO] Web Feature Service Module … SUCCESS [01:43 min]
[INFO] Web Map Service Module … SUCCESS [02:29 min]
[INFO] KML support for GeoServer … SUCCESS [ 33.225 s]
[INFO] GeoWebCache (GWC) Module … SUCCESS [01:18 min]
[INFO] gs-rest … SUCCESS [ 15.946 s]
[INFO] gs-restconfig … SUCCESS [02:12 min]
[INFO] GeoServer Web Modules … SUCCESS [ 0.043 s]
[INFO] Core UI Module … SUCCESS [01:14 min]
[INFO] GeoServer Extensions … SUCCESS [ 0.034 s]
[INFO] GeoServer CSS Styling … SUCCESS [ 16.549 s]
[INFO] WMS UI Module … SUCCESS [ 36.613 s]
[INFO] GWC UI Module … SUCCESS [ 45.883 s]
[INFO] WFS UI Module … SUCCESS [ 12.010 s]
[INFO] Demos Module … SUCCESS [ 20.837 s]
[INFO] WCS UI Module … SUCCESS [ 17.364 s]
[INFO] Security UI Modules … SUCCESS [ 0.068 s]
[INFO] Security UI Core Module … SUCCESS [02:20 min]
[INFO] Security UI JDBC Module … SUCCESS [01:35 min]
[INFO] Security UI LDAP Module … SUCCESS [01:12 min]
[INFO] REST UI Module … SUCCESS [ 15.410 s]
[INFO] Printing Module … SUCCESS [ 14.227 s]
[INFO] GeoServer Web Application … SUCCESS [ 6.169 s]
[INFO] Community Space … SUCCESS [ 0.384 s]
[INFO] Application Schema Support … SUCCESS [ 0.277 s]
[INFO] Application Schema Integration Test … SUCCESS [02:43 min]
[INFO] Sample DataAccess Integration Test … SUCCESS [ 12.323 s]
[INFO] ArcSDE DataStore Extension … SUCCESS [ 12.908 s]
[INFO] H2 DataStore Extension … SUCCESS [ 17.584 s]
[INFO] SQL Server DataStore Extension … SUCCESS [ 1.082 s]
[INFO] Oracle DataStore Extension … SUCCESS [ 0.841 s]
[INFO] MySQL DataStore Extension … SUCCESS [ 0.274 s]
[INFO] DB2 DataStore Extension … SUCCESS [ 0.250 s]
[INFO] ImageMap Output Format … SUCCESS [ 8.657 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension … SUCCESS [ 4.313 s]
[INFO] JP2K Coverage Extension … SUCCESS [ 0.937 s]
[INFO] OGR parent … SUCCESS [ 0.026 s]
[INFO] OGR CORE … SUCCESS [ 1.988 s]
[INFO] OGR WFS … SUCCESS [ 10.013 s]
[INFO] Web Processing Service parent … SUCCESS [ 0.028 s]
[INFO] Web Processing Service Module … SUCCESS [01:38 min]
[INFO] OGR WPS … SUCCESS [ 10.662 s]
[INFO] Excel Output Format … SUCCESS [ 15.574 s]
[INFO] Chart external graphics support … SUCCESS [ 0.534 s]
[INFO] Feature Generalization Extension … SUCCESS [ 1.907 s]
[INFO] Image Mosaic JDBC Extension … SUCCESS [ 0.942 s]
[INFO] OWS request flow controller … SUCCESS [ 9.339 s]
[INFO] Web process status sharing with Hazelcast … SUCCESS [ 17.553 s]
[INFO] Web Processing Service GUI … SUCCESS [ 30.049 s]
[INFO] GeoServer Layer Querying filter functions … SUCCESS [ 17.888 s]
[INFO] Teradata DataStore Extension … SUCCESS [ 2.170 s]
[INFO] GeoServer Monitor Extensions … SUCCESS [ 0.040 s]
[INFO] Core Monitor Extension … SUCCESS [ 31.401 s]
[INFO] Monitor Hibernate Extension … SUCCESS [ 8.849 s]
[INFO] GeoServer Security Extension Modules … SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Module … SUCCESS [ 6.831 s]
[INFO] GeoServer Security Extension Web Modules … SUCCESS [ 0.043 s]
[INFO] GeoServer CAS Security Web Module … SUCCESS [ 2.363 s]
[INFO] XLST based WFS output format … SUCCESS [ 27.851 s]
[INFO] GeoServer INSPIRE Extensions … SUCCESS [ 36.925 s]
[INFO] Catalog Services for the Web parent … SUCCESS [ 0.039 s]
[INFO] Catalog Services for the Web interfaces … SUCCESS [ 10.610 s]
[INFO] Catalog Services for the Web core module … SUCCESS [ 45.527 s]
[INFO] CSW UI Module … SUCCESS [ 11.487 s]
[INFO] DXF WFS output format and WPS PPIO … SUCCESS [ 0.923 s]
[INFO] DXF WFS output format … SUCCESS [ 15.630 s]
[INFO] DXF WPS PPIO … SUCCESS [ 10.518 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions … SUCCESS [ 0.029 s]
[INFO] GeoServer libjpeg-turbo Module … SUCCESS [ 12.190 s]
[INFO] GeoServer Data Importer … SUCCESS [ 0.057 s]
[INFO] Importer Core Module … SUCCESS [ 41.234 s]
[INFO] Importer REST Api Module-ng … SUCCESS [ 42.257 s]
[INFO] Importer Berkley DB Persistence Module … SUCCESS [ 17.959 s]
[INFO] Importer Web UI Module … SUCCESS [ 16.181 s]
[INFO] GRIB Coverage Format … SUCCESS [ 18.518 s]
[INFO] NetCDF Coverage format … FAILURE [ 27.964 s]
[INFO] WCS NetCDF output Module … SKIPPED
[INFO] Vector Tiles … SUCCESS [ 9.227 s]
[INFO] Ysld GeoServer Plugin … SUCCESS [ 16.577 s]
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/netcdf/target/surefire-reports> for the individual test results.
[ERROR] → [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn -rf :gs-netcdf
Build step ‘Invoke top-level Maven targets’ marked build as failure
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4675/&gt;
[...truncated 69797 lines...]
May 02, 2017 9:00:10 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'ExtensionFilter', but ApplicationContext is unset.
WARNING: Extension lookup 'GeoServerResourceLoader', but ApplicationContext is unset.
WARNING: Extension lookup 'ExtensionProvider', but ApplicationContext is unset.
May 02, 2017 9:00:12 PM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup 'GeoServerSecurityProvider', but ApplicationContext is unset.
May 02, 2017 9:00:13 PM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'sf', enabled
INFO: Loaded feature type 'AggregateGeoFeature', enabled
INFO: Loaded feature type 'GenericEntity', enabled
INFO: Loaded feature type 'PrimitiveGeoFeature', enabled
INFO: Loaded store 'cite', enabled
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
INFO: Loaded feature type 'Lakes', enabled
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Inserts', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded feature type 'Deletes', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Updates', enabled
INFO: Loaded feature type 'Seven', enabled
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.352 sec
Running org.geoserver.wcs2_0.eo.web.WCSEOLayerConfigTest
May 02, 2017 9:00:15 PM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'World', enabled
INFO: Loaded coverage 'World', enabled
INFO: Loaded store 'RotatedCad', enabled
INFO: Loaded coverage 'RotatedCad', enabled
INFO: Loaded store 'multiband', enabled
INFO: Loaded coverage 'multiband', enabled
INFO: Loaded store 'BlueMarble', enabled
INFO: Loaded coverage 'BlueMarble', enabled
INFO: Loaded store 'DEM', enabled
INFO: Loaded coverage 'DEM', enabled
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.078 sec
Results :
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-wcs2_0-eo ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-wcs2_0-eo ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wcs2_0-eo/web/target/gs-web-wcs2_0-eo-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-wcs2_0-eo/2.12-SNAPSHOT/gs-web-wcs2_0-eo-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.376 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.233 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.987 s]
[INFO] Main Module ........................................ SUCCESS [02:39 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.192 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 59.241 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:57 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.949 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 26.021 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.853 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 52.661 s]
[INFO] Web Feature Service Module ......................... FAILURE [01:46 min]
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-rest ............................................ SUCCESS [ 15.414 s]
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.085 s]
[INFO] Core UI Module ..................................... SUCCESS [01:11 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.030 s]
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SUCCESS [ 0.045 s]
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Printing Module .................................... SUCCESS [ 14.780 s]
[INFO] Community Space .................................... SUCCESS [ 0.710 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.113 s]
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.190 s]
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.871 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.450 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.237 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.283 s]
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 4.204 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.317 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.024 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.364 s]
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.045 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SUCCESS [ 0.532 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.062 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.492 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.886 s]
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.032 s]
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.044 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.395 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.976 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.147 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.439 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.026 s]
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.026 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 19.004 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 13.815 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.729 s]
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] Total time: 09:25 min (Wall Clock)
[INFO] Finished at: 2017-05-02T21:00:18+00:00
[INFO] Final Memory: 112M/670M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wfs
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4676/changes&gt;
