See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4700/changes>
Changes:
[afabiani] Fix for GEOS-8128 - SLD static legend dimensions not respected
[...truncated 185119 lines...]
T E S T S
May 09, 2017 11:04:56 AM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
Running org.geoserver.filters.GZIPResponseStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.072 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.19 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-app ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-app ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-antrun-plugin:1.7:run (configPackage) @ gs-web-app ---
[WARNING] Parameter tasks is deprecated, use target instead
[INFO] Executing tasks
main:
[echo] Copying data dir from ../../../data/minimal
[copy] Copying 29 files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp/data>
[INFO] Executed tasks
[INFO]
[INFO] --- maven-war-plugin:2.3:war (default) @ gs-web-app ---
[INFO] Packaging webapp
[INFO] Assembling webapp [gs-web-app] in [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources [<http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/src/main/webapp\]>
May 09, 2017 11:04:57 AM org.geoserver.catalog.ResourcePool getFeatureType
[INFO] Webapp assembled in [361 msecs]
[INFO] Building war: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war>
[INFO]
[INFO] --- build-helper-maven-plugin:1.8:attach-artifact (attach-war) @ gs-web-app ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-app ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/gs-web-app-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT-test-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/web/app/target/geoserver.war> to /var/lib/jenkins/.m2/repository/org/geoserver/web/gs-web-app/2.12-SNAPSHOT/gs-web-app-2.12-SNAPSHOT.war
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.732 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-sources.jar
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target>
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources>
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes>
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java>
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources>
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar>
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar>
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar> to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 8.420 s]
[INFO] Core Platform Module ............................... SUCCESS [ 13.316 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 12.193 s]
[INFO] Main Module ........................................ SUCCESS [02:32 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.065 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 57.233 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:10 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.918 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 24.844 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.173 s]
[INFO] Web Coverage Service 2.0 Module .................... SUCCESS [ 54.908 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:42 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:27 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 35.509 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:18 min]
[INFO] gs-rest ............................................ SUCCESS [ 16.532 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:07 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.922 s]
[INFO] Core UI Module ..................................... SUCCESS [01:16 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.081 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.783 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 36.514 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.307 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.732 s]
[INFO] Demos Module ....................................... SUCCESS [ 21.490 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.238 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.085 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:10 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:34 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:15 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.512 s]
[INFO] Printing Module .................................... SUCCESS [ 14.097 s]
[INFO] GeoServer Web Application .......................... SUCCESS [ 5.629 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:36 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.275 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.064 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 18.074 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.293 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.576 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.234 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.255 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.664 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.652 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.253 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.025 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.946 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.270 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.034 s]
[INFO] Web Processing Service Module ...................... FAILURE [01:33 min]
[INFO] Excel Output Format ................................ SUCCESS [ 15.565 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.493 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 1.961 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.474 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.485 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.168 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.050 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.042 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 25.668 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 9.430 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.044 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.148 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.059 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 5.541 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 25.110 s]
[INFO] GeoServer INSPIRE Extensions ....................... SUCCESS [ 31.285 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.051 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.163 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.578 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.427 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.256 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.033 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.674 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.047 s]
[INFO] Web Coverage Service 2.0 Earth Observation extensions SUCCESS [ 21.022 s]
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension SUCCESS [ 14.156 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.518 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.054 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.992 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 42.410 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.924 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.219 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.299 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.886 s]
[INFO] WCS NetCDF output Module ........................... SUCCESS [ 41.284 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.293 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.423 s]
[INFO] BUILD FAILURE
[INFO] Total time: 21:55 min (Wall Clock)
[INFO] Finished at: 2017-05-09T11:05:04+00:00
[INFO] Final Memory: 133M/491M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wps-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wps-core
