[Geoserver-devel] Build failed in Jenkins: geoserver-master #4768
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4768/&gt;
[...truncated 171283 lines...]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/main/resources&gt;
[INFO]
[INFO] Compiling 2 source files to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/classes&gt;
May 26, 2017 7:31:37 PM org.geoserver.config.util.XStreamPersister log
INFO: Loaded store 'sf', enabled
INFO: Loaded feature type 'GenericEntity', enabled
INFO: Loaded feature type 'PrimitiveGeoFeature', enabled
INFO: Loaded feature type 'AggregateGeoFeature', enabled
INFO: Loaded store 'cite', enabled
INFO: Loaded feature type 'RoadSegments', enabled
INFO: Loaded feature type 'Geometryless', enabled
INFO: Loaded feature type 'Forests', enabled
INFO: Loaded feature type 'DividedRoutes', enabled
INFO: Loaded feature type 'NamedPlaces', enabled
INFO: Loaded feature type 'Lakes', enabled
INFO: Loaded feature type 'Bridges', enabled
INFO: Loaded feature type 'Buildings', enabled
INFO: Loaded feature type 'BasicPolygons', enabled
INFO: Loaded feature type 'Ponds', enabled
INFO: Loaded feature type 'Streams', enabled
INFO: Loaded feature type 'MapNeatline', enabled
INFO: Loaded store 'cgf', enabled
INFO: Loaded feature type 'Polygons', enabled
INFO: Loaded feature type 'MPolygons', enabled
INFO: Loaded feature type 'Lines', enabled
INFO: Loaded feature type 'Points', enabled
INFO: Loaded feature type 'MLines', enabled
INFO: Loaded feature type 'MPoints', enabled
INFO: Loaded store 'cdf', enabled
INFO: Loaded feature type 'Nulls', enabled
INFO: Loaded feature type 'Inserts', enabled
INFO: Loaded feature type 'Locks', enabled
INFO: Loaded feature type 'Fifteen', enabled
INFO: Loaded feature type 'Other', enabled
INFO: Loaded feature type 'Deletes', enabled
INFO: Loaded feature type 'Seven', enabled
INFO: Loaded feature type 'Updates', enabled
[INFO]
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/src/test/resources&gt;
[INFO]
[INFO] No sources to compile
[INFO]
[INFO] No tests to run.
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO]
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-web-sec-cas/2.12-SNAPSHOT/gs-web-sec-cas-2.12-SNAPSHOT-sources.jar
May 26, 2017 7:31:40 PM org.geoserver.catalog.ResourcePool getFeatureType
WARNING: Error while getting feature type, flushing cache and retrying: Failed to find the datastore factory for dummy, did you forget to install the store extension jar?
May 26, 2017 7:31:41 PM org.geoserver.catalog.ResourcePool getFeatureType
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.523 sec
Results :
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-importer-web ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-importer-web ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/importer/web/target/gs-importer-web-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/importer/gs-importer-web/2.12-SNAPSHOT/gs-importer-web-2.12-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 10.912 s]
[INFO] Core Platform Module ............................... SUCCESS [ 22.438 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 13.118 s]
[INFO] Main Module ........................................ SUCCESS [02:32 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.090 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [01:00 min]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [03:01 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.620 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 25.521 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 30.107 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 50.191 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:43 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:34 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 34.333 s]
[INFO] GeoWebCache (GWC) Module ........................... SUCCESS [01:21 min]
[INFO] gs-rest ............................................ SUCCESS [ 15.916 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:03 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.267 s]
[INFO] Core UI Module ..................................... SUCCESS [01:15 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.059 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.318 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.188 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 43.011 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.377 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.547 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.225 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.173 s]
[INFO] Security UI Core Module ............................ SUCCESS [02:05 min]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:31 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:12 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.573 s]
[INFO] Printing Module .................................... SUCCESS [ 14.005 s]
[INFO] Community Space .................................... SUCCESS [ 0.076 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.037 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:36 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.397 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.728 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 16.989 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.336 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.480 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.242 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.250 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 8.701 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.743 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.322 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.032 s]
[INFO] OGR CORE ........................................... SUCCESS [ 2.005 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.382 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.036 s]
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] Excel Output Format ................................ SUCCESS [ 15.536 s]
[INFO] Chart external graphics support .................... SUCCESS [ 1.144 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.108 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 1.020 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 9.253 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 18.320 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.258 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.062 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 27.402 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.777 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.171 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 7.577 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.052 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.486 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 25.171 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.091 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.539 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.682 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 42.390 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.500 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.035 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.662 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.030 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 11.223 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.074 s]
[INFO] Importer Core Module ............................... SUCCESS [ 40.881 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.365 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 19.386 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 16.160 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 19.683 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.202 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.963 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.947 s]
[INFO] BUILD FAILURE
[INFO] Total time: 20:16 min (Wall Clock)
[INFO] Finished at: 2017-05-26T19:31:42+00:00
[INFO] Final Memory: 123M/519M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-wcs2_0: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/wcs2_0/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-wcs2_0
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4769/&gt;
[...truncated 171496 lines...]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 5
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-sec-cas ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-sec-cas ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-tests.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-sources.jar
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/cas/target/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/security/gs-sec-cas/2.12-SNAPSHOT/gs-sec-cas-2.12-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building GeoServer Security Extension Web Modules 2.12-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ gs-web-sec ---
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec ---
[INFO] Skipping cobertura mojo for project with packaging type 'pom'
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ gs-web-sec ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ gs-web-sec ---
[INFO] Building jar: <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ gs-web-sec ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ gs-web-sec ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/target/gs-web-sec-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/extension/gs-web-sec/2.12-SNAPSHOT/gs-web-sec-2.12-SNAPSHOT-tests.jar
[INFO]
[INFO] Skipping GeoServer Web Application
[INFO]
[INFO] Building GeoServer CAS Security Web Module 2.12-SNAPSHOT
[INFO]
[INFO] Deleting <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/extension/security/web/web-cas/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.6:clean (default) @ gs-web-sec-cas ---
[INFO]
[INFO]
[INFO] Copying 2 resources
[INFO]
May 26, 2017 9:09:44 PM org.geoserver.catalog.ResourcePool getFeatureType
May 26, 2017 9:09:46 PM org.geoserver.catalog.ResourcePool getFeatureType
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.746 sec
Results :
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... SUCCESS [ 9.657 s]
[INFO] Core Platform Module ............................... SUCCESS [ 15.125 s]
[INFO] Open Web Service Module ............................ SUCCESS [ 11.647 s]
[INFO] Main Module ........................................ SUCCESS [02:35 min]
[INFO] GeoServer Security Modules ......................... SUCCESS [ 0.060 s]
[INFO] GeoServer JDBC Security Module ..................... SUCCESS [ 55.192 s]
[INFO] GeoServer LDAP Security Module ..................... SUCCESS [02:55 min]
[INFO] Web Coverage Service Module ........................ SUCCESS [ 3.267 s]
[INFO] Web Coverage Service 1.0 Module .................... SUCCESS [ 23.652 s]
[INFO] Web Coverage Service 1.1 Module .................... SUCCESS [ 29.359 s]
[INFO] Web Coverage Service 2.0 Module .................... FAILURE [ 53.301 s]
[INFO] Web Feature Service Module ......................... SUCCESS [01:39 min]
[INFO] Web Map Service Module ............................. SUCCESS [02:33 min]
[INFO] KML support for GeoServer .......................... SUCCESS [ 33.876 s]
[INFO] gs-rest ............................................ SUCCESS [ 16.421 s]
[INFO] gs-restconfig ...................................... SUCCESS [02:05 min]
[INFO] GeoServer Web Modules .............................. SUCCESS [ 0.043 s]
[INFO] Core UI Module ..................................... SUCCESS [01:12 min]
[INFO] GeoServer Extensions ............................... SUCCESS [ 0.042 s]
[INFO] GeoServer CSS Styling .............................. SUCCESS [ 16.247 s]
[INFO] WMS UI Module ...................................... SUCCESS [ 35.884 s]
[INFO] GWC UI Module ...................................... SUCCESS [ 42.778 s]
[INFO] WFS UI Module ...................................... SUCCESS [ 11.992 s]
[INFO] Demos Module ....................................... SUCCESS [ 20.989 s]
[INFO] WCS UI Module ...................................... SUCCESS [ 15.350 s]
[INFO] Security UI Modules ................................ SUCCESS [ 0.047 s]
[INFO] Security UI JDBC Module ............................ SUCCESS [01:34 min]
[INFO] Security UI LDAP Module ............................ SUCCESS [01:11 min]
[INFO] REST UI Module ..................................... SUCCESS [ 15.647 s]
[INFO] Printing Module .................................... SUCCESS [ 14.347 s]
[INFO] Community Space .................................... SUCCESS [ 0.027 s]
[INFO] Application Schema Support ......................... SUCCESS [ 0.027 s]
[INFO] Application Schema Integration Test ................ SUCCESS [02:37 min]
[INFO] Sample DataAccess Integration Test ................. SUCCESS [ 12.584 s]
[INFO] ArcSDE DataStore Extension ......................... SUCCESS [ 12.390 s]
[INFO] H2 DataStore Extension ............................. SUCCESS [ 17.294 s]
[INFO] SQL Server DataStore Extension ..................... SUCCESS [ 1.016 s]
[INFO] Oracle DataStore Extension ......................... SUCCESS [ 0.429 s]
[INFO] MySQL DataStore Extension .......................... SUCCESS [ 0.294 s]
[INFO] DB2 DataStore Extension ............................ SUCCESS [ 0.227 s]
[INFO] ImageMap Output Format ............................. SUCCESS [ 9.090 s]
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SUCCESS [ 3.557 s]
[INFO] JP2K Coverage Extension ............................ SUCCESS [ 0.280 s]
[INFO] OGR parent ......................................... SUCCESS [ 0.022 s]
[INFO] OGR CORE ........................................... SUCCESS [ 1.889 s]
[INFO] OGR WFS ............................................ SUCCESS [ 10.154 s]
[INFO] Web Processing Service parent ...................... SUCCESS [ 0.023 s]
[INFO] Excel Output Format ................................ SUCCESS [ 15.276 s]
[INFO] Chart external graphics support .................... SUCCESS [ 0.437 s]
[INFO] Feature Generalization Extension ................... SUCCESS [ 2.068 s]
[INFO] Image Mosaic JDBC Extension ........................ SUCCESS [ 0.481 s]
[INFO] OWS request flow controller ........................ SUCCESS [ 8.863 s]
[INFO] GeoServer Layer Querying filter functions .......... SUCCESS [ 16.992 s]
[INFO] Teradata DataStore Extension ....................... SUCCESS [ 2.086 s]
[INFO] GeoServer Monitor Extensions ....................... SUCCESS [ 0.039 s]
[INFO] Core Monitor Extension ............................. SUCCESS [ 26.675 s]
[INFO] Monitor Hibernate Extension ........................ SUCCESS [ 8.468 s]
[INFO] GeoServer Security Extension Modules ............... SUCCESS [ 0.046 s]
[INFO] GeoServer CAS Security Module ...................... SUCCESS [ 6.660 s]
[INFO] GeoServer Security Extension Web Modules ........... SUCCESS [ 0.045 s]
[INFO] GeoServer CAS Security Web Module .................. SUCCESS [ 2.586 s]
[INFO] XLST based WFS output format ....................... SUCCESS [ 25.167 s]
[INFO] Catalog Services for the Web parent ................ SUCCESS [ 0.051 s]
[INFO] Catalog Services for the Web interfaces ............ SUCCESS [ 10.457 s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [ 10.237 s]
[INFO] Catalog Services for the Web core module ........... SUCCESS [ 41.367 s]
[INFO] CSW UI Module ...................................... SUCCESS [ 11.523 s]
[INFO] DXF WFS output format and WPS PPIO ................. SUCCESS [ 0.030 s]
[INFO] DXF WFS output format .............................. SUCCESS [ 14.632 s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SUCCESS [ 0.025 s]
[INFO] GeoServer libjpeg-turbo Module ..................... SUCCESS [ 10.438 s]
[INFO] GeoServer Data Importer ............................ SUCCESS [ 0.053 s]
[INFO] Importer Core Module ............................... SUCCESS [ 39.291 s]
[INFO] Importer REST Api Module-ng ........................ SUCCESS [ 43.573 s]
[INFO] Importer Berkley DB Persistence Module ............. SUCCESS [ 18.989 s]
[INFO] Importer Web UI Module ............................. SUCCESS [ 15.934 s]
[INFO] GRIB Coverage Format ............................... SUCCESS [ 18.785 s]
[INFO] NetCDF Coverage format ............................. SUCCESS [ 21.552 s]
[INFO] Vector Tiles ....................................... SUCCESS [ 8.472 s]
[INFO] Ysld GeoServer Plugin .............................. SUCCESS [ 16.946 s]
[INFO] Total time: 19:58 min (Wall Clock)
[INFO] Finished at: 2017-05-26T21:09:47+00:00
[INFO] Final Memory: 124M/487M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4770/&gt;
