See <http://ares.opengeo.org/jenkins/job/geoserver-master/487/>
[...truncated 2905 lines...]
Downloaded: http://repo.opengeo.org/org/geotools/gt-imagemosaic/12-SNAPSHOT/maven-metadata.xml (315 B at 38.5 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-transform/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-transform/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-transform/12-SNAPSHOT/maven-metadata.xml
313/313 B
Downloading: http://maven.geo-solutions.it/org/geotools/gt-transform/12-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-transform/12-SNAPSHOT/maven-metadata.xml (313 B at 34.0 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-wfs/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-wfs/12-SNAPSHOT/maven-metadata.xml
307/307 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-wfs/12-SNAPSHOT/maven-metadata.xml (307 B at 33.3 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/unsupported/12-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/unsupported/12-SNAPSHOT/maven-metadata.xml
312/312 B
Downloaded: http://repo.opengeo.org/org/geotools/unsupported/12-SNAPSHOT/maven-metadata.xml (312 B at 33.9 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-wfs/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wfs/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-wfs/12-SNAPSHOT/maven-metadata.xml
315/315 B
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-wfs/12-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-wfs/12-SNAPSHOT/maven-metadata.xml (315 B at 30.8 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/ogc/net.opengis.wfs/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/ogc/net.opengis.wfs/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wfs/12-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/ogc/net.opengis.wfs/12-SNAPSHOT/maven-metadata.xml
320/320 B
Downloaded: http://repo.opengeo.org/org/geotools/ogc/net.opengis.wfs/12-SNAPSHOT/maven-metadata.xml (320 B at 24.0 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.fes/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/ogc/net.opengis.fes/12-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/ogc/net.opengis.fes/12-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/ogc/net.opengis.fes/12-SNAPSHOT/maven-metadata.xml
320/320 B
Downloaded: http://repo.opengeo.org/org/geotools/ogc/net.opengis.fes/12-SNAPSHOT/maven-metadata.xml (320 B at 39.1 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-fes/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-fes/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-fes/12-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-fes/12-SNAPSHOT/maven-metadata.xml
315/315 B
Downloaded: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-fes/12-SNAPSHOT/maven-metadata.xml (315 B at 34.2 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/jdbc/gt-jdbc-postgis/12-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc-postgis/12-SNAPSHOT/maven-metadata.xml
321/321 B
Downloaded: http://repo.opengeo.org/org/geotools/jdbc/gt-jdbc-postgis/12-SNAPSHOT/maven-metadata.xml (321 B at 34.8 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gs-main ---
[INFO] Deleting <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gs-main ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gs-main ---
[INFO] [GitCommitIdMojo] Running on '<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding the dynamic dimension defaults module to the nightly build
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 07.05.2014 @ 11:09:34 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 09-May-2014 09:53
[INFO] [GitCommitIdMojo] build.build.time = 09.05.2014 @ 09:54:50 UTC
[INFO] [GitCommitIdMojo] build.branch = a96556d6ea8a44d3f5ca78ec676ea1391cedd0ad
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = a96556d
[INFO] [GitCommitIdMojo] build.commit.id = a96556d6ea8a44d3f5ca78ec676ea1391cedd0ad
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding the dynamic dimension defaults module to the nightly build
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ gs-main ---
[INFO] Copying 32 resources
[INFO] Copying 163 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gs-main ---
[INFO] Compiling 579 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ gs-main ---
[INFO] Copying 101 resources
[INFO] Copying 36 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ gs-main ---
[INFO] Compiling 178 source files to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/test-classes>
[INFO] -------------------------------------------------------------
[ERROR] COMPILATION ERROR :
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[236,75\] error: cannot find symbol
[ERROR] class GeoServerImplTest
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[236,103\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[237,78\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[237,104\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[238,78\] error: cannot find symbol
<http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[238,104\] error: cannot find symbol
[INFO] 6 errors
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.536s]
[INFO] Core Platform Module .............................. SUCCESS [17.716s]
[INFO] Open Web Service Module ........................... SUCCESS [16.566s]
[INFO] Main Module ....................................... FAILURE [29.603s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [1.401s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.324s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.227s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.255s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.249s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.010s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.576s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.484s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.059s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.676s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.162s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.797s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.173s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.360s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.190s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:18.115s (Wall Clock)
[INFO] Finished at: Fri May 09 09:55:15 UTC 2014
[INFO] Final Memory: 38M/378M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:testCompile (default-testCompile) on project gs-main: Compilation failure: Compilation failure:
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[236,103\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[237,78\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[237,104\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[238,78\] error: cannot find symbol
[ERROR] <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/src/test/java/org/geoserver/config/GeoServerImplTest.java>:\[238,104\] error: cannot find symbol
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
