[Geoserver-devel] Build failed in Jenkins: geoserver-master #4929
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4929/changes&gt;
Changes:
[groldan] Update geogig version to 1.2-SNAPSHOT
[...truncated 193684 lines...]
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer Security Extension Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Web Modules
[INFO] GeoServer CAS Security Web Module
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] CSW UI Module
[INFO] DXF WFS output format and WPS PPIO
[INFO] DXF WPS PPIO
[INFO] Printing Module
[INFO] GeoServer WCS 2.0 Earth Observation Extensions
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] Importer REST Api Module-ng
[INFO] Importer Berkley DB Persistence Module
[INFO] Importer Web UI Module
[INFO] GRIB Coverage Format
[INFO] NetCDF Coverage format
[INFO] WCS NetCDF output Module
[INFO] Vector Tiles
[INFO] Ysld GeoServer Plugin
[INFO]
[INFO] Building GeoServer 2.12-SNAPSHOT
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-api/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-api/18-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-api:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-api:18-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-api:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/library/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/library/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/library/18-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:library:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/modules/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/modules/18-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:modules:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/geotools/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/geotools/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/18-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:geotools:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-referencing/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-referencing/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/18-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-referencing:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-referencing:18-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-referencing:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-metadata/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-metadata/18-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-metadata:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-metadata:18-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-metadata:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-opengis/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-opengis/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/18-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-opengis:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-opengis:18-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-opengis:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Downloading: http://maven.geo-solutions.it/org/geotools/gt-main/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: https://repo.boundlessgeo.com/main/org/geotools/gt-main/18-SNAPSHOT/maven-metadata.xml
[INFO] Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/18-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-main:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[WARNING] Failure to transfer org.geotools:gt-main:18-SNAPSHOT/maven-metadata.xml from https://repo.boundlessgeo.com/main/ was cached in the local repository, resolution will not be reattempted until the update interval of boundless has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-main:18-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/main/\): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO]
[INFO] --- git-commit-id-plugin:2.1.15:revision (default) @ geoserver ---
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ geoserver ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar-no-fork (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar-no-fork (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ geoserver ---
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/pom.xml&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.12-SNAPSHOT/geoserver-2.12-SNAPSHOT.pom
[INFO] Installing <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/ws/src/target/geoserver-2.12-SNAPSHOT-tests.jar&gt; to /var/lib/jenkins/.m2/repository/org/geoserver/geoserver/2.12-SNAPSHOT/geoserver-2.12-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver ---
[INFO] Downloading: https://repo.boundlessgeo.com/snapshot/org/geoserver/geoserver/2.12-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 12.483 s]
[INFO] Core Platform Module ............................... SKIPPED
[INFO] Open Web Service Module ............................ SKIPPED
[INFO] Main Module ........................................ SKIPPED
[INFO] GeoServer Security Modules ......................... SKIPPED
[INFO] GeoServer JDBC Security Module ..................... SKIPPED
[INFO] GeoServer LDAP Security Module ..................... SKIPPED
[INFO] Web Coverage Service Module ........................ SKIPPED
[INFO] Web Coverage Service 1.0 Module .................... SKIPPED
[INFO] Web Coverage Service 1.1 Module .................... SKIPPED
[INFO] Web Coverage Service 2.0 Module .................... SKIPPED
[INFO] Web Feature Service Module ......................... SKIPPED
[INFO] Web Map Service Module ............................. SKIPPED
[INFO] KML support for GeoServer .......................... SKIPPED
[INFO] GeoWebCache (GWC) Module ........................... SKIPPED
[INFO] gs-rest ............................................ SKIPPED
[INFO] gs-restconfig ...................................... SKIPPED
[INFO] GeoServer Web Modules .............................. SKIPPED
[INFO] Core UI Module ..................................... SKIPPED
[INFO] GeoServer Extensions ............................... SKIPPED
[INFO] GeoServer CSS Styling .............................. SKIPPED
[INFO] WMS UI Module ...................................... SKIPPED
[INFO] GWC UI Module ...................................... SKIPPED
[INFO] WFS UI Module ...................................... SKIPPED
[INFO] Demos Module ....................................... SKIPPED
[INFO] WCS UI Module ...................................... SKIPPED
[INFO] Security UI Modules ................................ SKIPPED
[INFO] Security UI Core Module ............................ SKIPPED
[INFO] Security UI JDBC Module ............................ SKIPPED
[INFO] Security UI LDAP Module ............................ SKIPPED
[INFO] REST UI Module ..................................... SKIPPED
[INFO] Community Space .................................... SKIPPED
[INFO] Authentication by unique url key ................... SKIPPED
[INFO] WorldWind Format Module ............................ SKIPPED
[INFO] SpatiaLite Extension ............................... SKIPPED
[INFO] GeoServer JDBC KV Catalog .......................... SKIPPED
[INFO] Aggregating Data Store ............................. SKIPPED
[INFO] WMS-EO ............................................. SKIPPED
[INFO] ColorMap ........................................... SKIPPED
[INFO] Web Processing Service parent ...................... SKIPPED
[INFO] Web Processing Service Module ...................... SKIPPED
[INFO] GeoServer mbtiles Extension ........................ SKIPPED
[INFO] GeoServer GeoPackage Extension ..................... SKIPPED
[INFO] PGRaster DataStore Extension for automatic configuration SKIPPED
[INFO] Dynamic WMS dimension value defaults ............... SKIPPED
[INFO] GPX PPIO for WPS ................................... SKIPPED
[INFO] KML PPIO for WPS ................................... SKIPPED
[INFO] DownloadProcess .................................... SKIPPED
[INFO] GeoServer JMS based clustering modules ............. SKIPPED
[INFO] ActiveMQ ........................................... SKIPPED
[INFO] GeoServer JMS clustering Commons module ............ SKIPPED
[INFO] GeoServer JMS clustering module .................... SKIPPED
[INFO] GeoServer Hazelcast Clustering Module .............. SKIPPED
[INFO] Solr Module ........................................ SKIPPED
[INFO] GeoFence security integration ...................... SKIPPED
[INFO] GeoFence Server .................................... SKIPPED
[INFO] Parameters Extractor ............................... SKIPPED
[INFO] GeoServer Data Importer ............................ SKIPPED
[INFO] Importer Core Module ............................... SKIPPED
[INFO] Web Processing Service - Remote processes invocation SKIPPED
[INFO] WPS cluster on jdbc datastores ..................... SKIPPED
[INFO] ncWMS compatibility extension ...................... SKIPPED
[INFO] GWC Distributed Caching Plugin ..................... SKIPPED
[INFO] GeoWebCache S3 ..................................... SKIPPED
[INFO] OGR parent ......................................... SKIPPED
[INFO] OGR CORE ........................................... SKIPPED
[INFO] GDAL translate parent .............................. SKIPPED
[INFO] GDAL translate WCS ................................. SKIPPED
[INFO] GDAL translate WPS ................................. SKIPPED
[INFO] GeoServer JDBC Configuration Resource Store ........ SKIPPED
[INFO] GeoWebCache SQLite ................................. SKIPPED
[INFO] WMTS Multi Dimensional ............................. SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module ........... SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - Google Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GitHub Token Service SKIPPED
[INFO] GeoServer OAuth2 Connect Security Module - GeoNode Token Service SKIPPED
[INFO] GeoServer OneLogin Module .......................... SKIPPED
[INFO] gs-notification-common ............................. SKIPPED
[INFO] GeoServer notification event system extension for GeoNode SKIPPED
[INFO] OWS Dispatcher Simulate Plugin ..................... SKIPPED
[INFO] JDBC Metrics Plugin ................................ SKIPPED
[INFO] OpenSearch EO parent ............................... SKIPPED
[INFO] OpenSearch for EO .................................. SKIPPED
[INFO] OpenSearch for EO web UI ........................... SKIPPED
[INFO] OpenSearch for EO REST configuration API ........... SKIPPED
[INFO] GeoServer Community Release Module ................. SKIPPED
[INFO] GeoServer Resource Browser ......................... SKIPPED
[INFO] GeoServer notification event system ................ SKIPPED
[INFO] Application Schema Support ......................... SKIPPED
[INFO] Sample DataAccess Integration Test ................. SKIPPED
[INFO] ArcSDE DataStore Extension ......................... SKIPPED
[INFO] H2 DataStore Extension ............................. SKIPPED
[INFO] SQL Server DataStore Extension ..................... SKIPPED
[INFO] Oracle DataStore Extension ......................... SKIPPED
[INFO] MySQL DataStore Extension .......................... SKIPPED
[INFO] DB2 DataStore Extension ............................ SKIPPED
[INFO] ImageMap Output Format ............................. SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension ............... SKIPPED
[INFO] JP2K Coverage Extension ............................ SKIPPED
[INFO] OGR WFS ............................................ SKIPPED
[INFO] Excel Output Format ................................ SKIPPED
[INFO] Chart external graphics support .................... SKIPPED
[INFO] Feature Generalization Extension ................... SKIPPED
[INFO] Image Mosaic JDBC Extension ........................ SKIPPED
[INFO] OWS request flow controller ........................ SKIPPED
[INFO] GeoServer Layer Querying filter functions .......... SKIPPED
[INFO] Teradata DataStore Extension ....................... SKIPPED
[INFO] GeoServer Monitor Extensions ....................... SKIPPED
[INFO] Core Monitor Extension ............................. SKIPPED
[INFO] Monitor Hibernate Extension ........................ SKIPPED
[INFO] GeoServer Security Extension Modules ............... SKIPPED
[INFO] GeoServer CAS Security Module ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules ........... SKIPPED
[INFO] GeoServer CAS Security Web Module .................. SKIPPED
[INFO] XLST based WFS output format ....................... SKIPPED
[INFO] Catalog Services for the Web parent ................ SKIPPED
[INFO] Catalog Services for the Web interfaces ............ SKIPPED
[INFO] Catalog Services for the Web core module ........... SKIPPED
[INFO] CSW UI Module ...................................... SKIPPED
[INFO] DXF WFS output format and WPS PPIO ................. SKIPPED
[INFO] DXF WFS output format .............................. SKIPPED
[INFO] Printing Module .................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions ..... SKIPPED
[INFO] GeoServer libjpeg-turbo Module ..................... SKIPPED
[INFO] Importer REST Api Module-ng ........................ SKIPPED
[INFO] Importer Berkley DB Persistence Module ............. SKIPPED
[INFO] Importer Web UI Module ............................. SKIPPED
[INFO] GRIB Coverage Format ............................... SKIPPED
[INFO] NetCDF Coverage format ............................. SKIPPED
[INFO] Vector Tiles ....................................... SKIPPED
[INFO] Ysld GeoServer Plugin .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 15.956 s
[INFO] Finished at: 2017-07-18T19:21:30+00:00
[INFO] Final Memory: 129M/630M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
Jody and Nick,
there appears to be an SSL certificate problem between the Boundless Jenkins worker that builds geoserver-master and the Boundless Maven repo.
The Maven repo has a new SSL certificate with validity starting on 17 July 2017:
The Jenkins geoserver-master deploy step fails with what looks like a failure to establish and SSL trust chain (see below).
Is someone from Boundless able to investigate?
The Jenkins geoserver-master build uses java-8-oracle-amd64 in /usr/lib/jvm/java-8-oracle on the worker. If this is old, the fix might be as simple as a upgrade of java-8-oracle-amd64 to pick up more recent certificates. Another possible solution is to upgrade system CA certificates (on Debian ca-certificates-java). I do not know which CA certificate store is used by the Oracle JDK. Does it bundle its own or use the system certificates?
Kind regards,
Ben.
[ERROR]
[ERROR]
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Humm ... I'm using the latest Oracle JDK version (141) and my system
Java certificates package is updated but I'm having the same issue.
I will give another try to this tomorrow if I have time ...
On 07/18/2017 11:00 PM, Ben Caradoc-Davies wrote:
Jody and Nick,
Kind regards,
Ben.
[ERROR]
[ERROR]
Nuno Oliveira
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
  The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Hmm. Is OpenJDK also affected?
It might be a problem with the SSL certificate on the server. The page works fine in Firefox.
Kind regards,
Ben.
Jody and Nick,
Kind regards,
Ben.
[ERROR]
[ERROR]
Director
New Zealand
Hello Ben,
Nick is currently away, and Jody is at FOSS4G Europe, so I’m not sure either of them will be likely to respond anytime soon.
I’ll try an get in touch with someone at Boundless who can help.
Torben
On Tue, Jul 18, 2017 at 3:36 PM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
Humm … I’m using the latest Oracle JDK version (141) and my system
Java certificates package is updated but I’m having the same issue.
I will give another try to this tomorrow if I have time …
Jody and Nick,
Kind regards,
Ben.
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4929/changes>
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.12-SNAPSHOT/maven-metadata.xml from/to boundless (https://repo.boundlessgeo.com/snapshot/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target → [Help 1]
[ERROR]
[ERROR]
Nuno Oliveira
@nmcoliveira
Software Engineer
Geoserver-devel mailing list
Geoserver-devel@anonymised.comrge.net
Thanks, Torben. Much appreciated.
I do not know if this problem will impact anyone trying to build GeoServer. I am testing with an empty local repo.
Kind regards,
Ben.
On 19/07/17 11:08, Torben Barsballe wrote:
Hello Ben,
Nick is currently away, and Jody is at FOSS4G Europe, so I'm not sure
I'll try an get in touch with someone at Boundless who can help.
Torben
Jody and Nick,
July 2017:
Kind regards,
Ben.
929/changes>
[ERROR]
-e switch.
[ERROR]
Nuno Oliveira
@nmcoliveira
Software Engineer
Check out the vibrant tech community on one of the world's most
Director
New Zealand
The GeoServer build on master ("mvn clean install") fails with an empty local repo:
[ERROR] Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.12-SNAPSHOT: Failed to collect dependencies at org.geotools:gt-api:jar:18-SNAPSHOT: Failed to read artifact descriptor for org.geotools:gt-api:jar:18-SNAPSHOT: Could not transfer artifact org.geotools:gt-api:pom:18-SNAPSHOT from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target -> [Help 1]
Kind regards,
Ben.
Kind regards,
Ben.
Hello Ben,
Torben
Jody and Nick,
July 2017:
Kind regards,
Ben.
929/changes>
[ERROR]
-e switch.
[ERROR]
Nuno Oliveira
@nmcoliveira
Software Engineer
Director
New Zealand
The GeoTools master build also fails with and empty local repo. Both of these tests with OpenJDK 8u131:
[ERROR] Failed to execute goal on project gt-coverage: Could not resolve dependencies for project org.geotools:gt-coverage:jar:18-SNAPSHOT: Failed to collect dependencies at it.geosolutions.imageio-ext:imageio-ext-tiff:jar:1.1.17: Failed to read artifact descriptor for it.geosolutions.imageio-ext:imageio-ext-tiff:jar:1.1.17: Could not transfer artifact it.geosolutions.imageio-ext:imageio-ext-tiff:pom:1.1.17 from/to boundless (https://repo.boundlessgeo.com/main/): sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target -> [Help 1]
Kind regards,
Ben.
Kind regards,
Ben.
Director
New Zealand
Torben,
the DigiCert SSL certificate checker confirms that repo.boundlessgeo.com is misconfigured: it is not sending their intermediate certificate:
https://www.digicert.com/help/
The server is not sending the required intermediate certificate.
This server needs to be configured to include DigiCert's intermediate certificate to avoid trust errors in web browsers.
Firefox (54.0) is happy, likely because the DigiCert SHA2 Secure Server intermediate certificate is bundled with Firefox:
OpenSSL is not, because of the missing intermediate certificate:
$ openssl s_client -connect repo.boundlessgeo.com:443
CONNECTED(00000003)
depth=0 C = US, ST = New York, L = New York, O = "Boundless Spatial, Inc.", OU = NA, CN = repo.boundlessgeo.com
verify error:num=20:unable to get local issuer certificate
verify return:1
verify error:num=21:unable to verify the first certificate
verify return:1
Certificate chain
  0 s:/C=US/ST=New York/L=New York/O=Boundless Spatial, Inc./OU=NA/CN=repo.boundlessgeo.com
    i:/C=US/O=DigiCert Inc/CN=DigiCert SHA2 Secure Server CA
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=/C=US/ST=New York/L=New York/O=Boundless Spatial, Inc./OU=NA/CN=repo.boundlessgeo.com
issuer=/C=US/O=DigiCert Inc/CN=DigiCert SHA2 Secure Server CA
No client certificate CA names sent
Peer signing digest: SHA512
Server Temp Key: ECDH, P-256, 256 bits
SSL handshake has read 2010 bytes and written 302 bytes
Verification error: unable to verify the first certificate
New, TLSv1.2, Cipher is ECDHE-RSA-AES256-GCM-SHA384
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
     Protocol : TLSv1.2
     Cipher : ECDHE-RSA-AES256-GCM-SHA384
     Session-ID: 7663F86026BB65FC8D86D401C154638338D6FFFBDA18E0760310DFF200CF7D51
     Session-ID-ctx:
     Master-Key: 1E98B5D40AB4798A1D9587D360D0E333E23EBFF0E661D952704919E70FD747A377469C762AB3E50CB50C9A7F192C837D
     PSK identity: None
     PSK identity hint: None
     SRP username: None
     TLS session ticket lifetime hint: 300 (seconds)
     TLS session ticket:
     0000 - e8 4c 36 38 7b a0 04 31-4e ad 88 9a 1a d3 8a 37 .L68{..1N......7
     0010 - fc 9b 34 a4 e7 70 43 14-b5 06 6a f3 3d 44 4d 59 ..4..pC...j.=DMY
     0020 - 68 00 f6 eb b5 c6 78 b3-d4 c6 87 f5 99 ee 73 31 h.....x.......s1
     0030 - 7f 52 96 c1 57 b2 c7 80-5f cf 8e 3c 5f 21 87 4b .R..W..._..<_!.K
     0040 - b6 bb 8b 1a cc 57 ca b7-16 1b a4 e7 bb c2 c3 8b .....W..........
     0050 - 29 84 72 b4 16 d5 43 be-6a f2 ef 50 7f 0b 82 92 ).r...C.j..P....
     0060 - 63 b8 8f 30 1b dc 66 fc-8b 0b 6d 14 c9 b6 31 05 c..0..f...m...1.
     0070 - 06 55 96 6e 6f 8b 17 3a-1e 7f d3 68 b9 bb 54 ee .U.no..:...h..T.
     0080 - 99 9f 5f ad db e4 01 51-06 56 97 0b a8 d8 ce 3f .._....Q.V.....?
     0090 - 4f 3b 9e aa 86 a2 f0 ac-bb 48 dd 18 61 9e fb a1 O;.......H..a...
     00a0 - 00 1f 67 49 8c ae af 12-7d cc 2b ce 6d ba 07 8c ..gI....}.+.m...
     Start Time: 1500420480
     Timeout : 7200 (sec)
     Verify return code: 21 (unable to verify the first certificate)
     Extended master secret: no
DONE
Kind regards,
Director
New Zealand
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4930/changes&gt;
Changes:
[andrea.aime] Fixes to get granules insert work properly on creation with POST zip
[...truncated 193969 lines...]
[INFO] DXF WPS PPIO
[INFO] Vector Tiles
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer .......................................... FAILURE [ 11.187 s]
[INFO] Total time: 14.369 s
[INFO] Finished at: 2017-07-19T10:39:18+00:00
[INFO] Final Memory: 129M/629M
[ERROR]
[ERROR]
I have had issues with local building the last few days for the same reason.
Niels
Kind regards,
Ben.
Hello Ben,
Torben
Jody and Nick,
July 2017:
Kind regards,
Ben.
929/changes>
[ERROR]
-e switch.
[ERROR]
Nuno Oliveira
@nmcoliveira
Software Engineer
See <http://ares.boundlessgeo.com/jenkins/job/geoserver-master/4931/&gt;
Issues should now be resolved, sorry for the interruption.
Niels
Kind regards,
Ben.
Hello Ben,
Torben
Jody and Nick,
July 2017:
Kind regards,
Ben.
929/changes>
[ERROR]
-e switch.
[ERROR]
Nuno Oliveira
@nmcoliveira
Software Engineer
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
I have confirmed that geoserver-master passes again.
Torben
On Wed, Jul 19, 2017 at 9:55 AM, Quinn Scripter <qscripter@anonymised.com> wrote:
Geoserver-devel@anonymised.com.366…sourceforge.net
Niels
Kind regards,
Ben.
Hello Ben,
Torben
Jody and Nick,
July 2017:
Kind regards,
Ben.
929/changes>
[ERROR]
-e switch.
[ERROR]
Nuno Oliveira
@nmcoliveira
Software Engineer
Good news thanks !
Niels
Kind regards,
Ben.
Hello Ben,
Torben
Jody and Nick,
July 2017:
Kind regards,
Ben.
929/changes>
[ERROR]
-e switch.
[ERROR]
Nuno Oliveira
@nmcoliveira
Software Engineer
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
@nmcoliveira
Software Engineer
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
Thanks very much, Quinn. I tested the build and can confirm that the Maven repo certificate problem is fixed.
Kind regards,
Ben.
reason.
Niels
Kind regards,
Ben.
Hello Ben,
Torben
Jody and Nick,
repo.
July 2017:
might be
use
Kind regards,
Ben.
929/changes>
metadata
[ERROR]
the
-e switch.
[ERROR]
Nuno Oliveira
@nmcoliveira
Software Engineer
stesso,
confidential
reproduction,
partial, is
or
Director
New Zealand
