[Geoserver-devel] Build failed in Jenkins: geoserver-master #493
See <http://ares.opengeo.org/jenkins/job/geoserver-master/493/changes&gt;
Changes:
[jody.garnett] Change compile target to 1.7
[...truncated 6377 lines...]
testUpdateLockedFeatureWithLockId(org.geoserver.wfs.v2_0.GetFeatureWithLockTest) Time elapsed: 626 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<[http://www.opengis.net/wfs/2.0\]> but was:<>
  at org.junit.Assert.assertEquals(Assert.java:115)
  at org.junit.Assert.assertEquals(Assert.java:144)
  at org.geoserver.wfs.v2_0.WFS20TestSupport.assertGML32(WFS20TestSupport.java:40)
  at org.geoserver.wfs.v2_0.GetFeatureWithLockTest.testUpdateLockedFeatureWithLockId(GetFeatureWithLockTest.java:66)
  at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
  at java.lang.reflect.Method.invoke(Method.java:606)
Running org.geoserver.wfs.v2_0.GetPropertyValueTest
Running org.geoserver.security.jdbc.DB2RoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 2.292 sec
Running org.geoserver.security.jdbc.DB2UserDetailsServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 3, Time elapsed: 0.019 sec
Running org.geoserver.security.jdbc.DB2UserGroupServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 8, Time elapsed: 0.056 sec
Running org.geoserver.security.jdbc.H2JNDIRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.629 sec
Running org.geoserver.wfs.v2_0.LockFeatureTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.699 sec
Running org.geoserver.wfs.v2_0.SrsNameRequestTest
# A fatal error has been detected by the Java Runtime Environment:
# SIGBUS (0x7) at pc=0x00007f2ee0948982, pid=26246, tid=139839352620800
# JRE version: Java(TM) SE Runtime Environment (7.0_51-b13) (build 1.7.0_51-b13)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.51-b03 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libzip.so+0x4982] newEntry+0x62
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/security/jdbc/hs_err_pid26246.log&gt;
Compiled method (nm) 15037 48 n java.util.zip.ZipFile::getEntry (native)
total in heap [0x00007f2ed9073dd0,0x00007f2ed9074168] = 920
relocation [0x00007f2ed9073ef0,0x00007f2ed9073f50] = 96
main code [0x00007f2ed9073f60,0x00007f2ed9074168] = 520
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Aborted
Results :
Tests run: 16, Failures: 0, Errors: 0, Skipped: 16
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
[INFO]
[INFO] Skipping Security UI Modules
[INFO]
[INFO] Skipping HTTP Proxy Extension
[INFO]
[INFO] Skipping Printing Module
[INFO]
[INFO] Skipping ArcSDE DataStore Extension
[INFO]
[INFO] Skipping H2 DataStore Extension
[INFO]
[INFO] Skipping Teradata DataStore Extension
[INFO]
[INFO] Skipping GeoServer CSS Styling
[INFO]
[INFO] Skipping Catalog Services for the Web interfaces
Tests run: 25, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.258 sec
Running org.geoserver.wfs.v2_0.SrsNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.778 sec
Running org.geoserver.wfs.v2_0.StoredQueryTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.504s]
[INFO] Core Platform Module .............................. SUCCESS [14.483s]
[INFO] Open Web Service Module ........................... SUCCESS [15.897s]
[INFO] Main Module ....................................... SUCCESS [2:56.248s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.917s]
[INFO] GeoServer JDBC Security Module .................... FAILURE [33.775s]
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SUCCESS [7.198s]
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Coverage Service 2.0 Module ................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [52.723s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.431s]
[INFO] Core UI Module .................................... SUCCESS [3:38.107s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Security UI Modules ............................... SKIPPED
[INFO] Security UI Core Module ........................... SKIPPED
[INFO] Security UI JDBC Module ........................... SKIPPED
[INFO] Security UI LDAP Module ........................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.269s]
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.167s]
[INFO] Printing Module ................................... SKIPPED
[INFO] Application Schema Support ........................ SUCCESS [0.226s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.521s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.626s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.470s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.511s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [0.949s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.631s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [3.651s]
[INFO] Chart external graphics support ................... SUCCESS [1.826s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.390s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.781s]
[INFO] OWS request flow controller ....................... SUCCESS [43.943s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.330s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer Security Extension Web Modules .......... SKIPPED
[INFO] GeoServer CAS Security Web Module ................. SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.563s]
[INFO] Catalog Services for the Web interfaces ........... SKIPPED
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.305s]
[INFO] DXF output format ................................. SKIPPED
[INFO] DXF WPS PPIO ...................................... SKIPPED
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.274s]
[INFO] GeoServer libjpeg-turbo Module .................... SKIPPED
[INFO] GeoServer Data Importer ........................... SKIPPED
[INFO] Importer Core Module .............................. SKIPPED
[INFO] Importer REST Api Module .......................... SKIPPED
[INFO] Importer Berkley DB Persistence Module ............ SKIPPED
[INFO] Importer Web UI Module ............................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 9:52.274s (Wall Clock)
[INFO] Finished at: Mon May 12 23:58:18 UTC 2014
[INFO] Final Memory: 43M/384M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-sec-jdbc: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :gs-sec-jdbc
See <http://ares.opengeo.org/jenkins/job/geoserver-master/494/&gt;
[...truncated 5693 lines...]
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.117 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.635 sec
Running org.vfny.geoserver.global.GeoserverDataDirectoryTest
Tests run: 3, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.031 sec <<< FAILURE!
testFindDataFileForAbsolutePath(org.vfny.geoserver.global.GeoserverDataDirectoryTest) Time elapsed: 1013 sec <<< ERROR!
java.util.ServiceConfigurationError: org.geotools.coverage.grid.io.GridFormatFactorySpi: Error reading configuration file
  at java.util.ServiceLoader.fail(ServiceLoader.java:224)
  at java.util.ServiceLoader.parse(ServiceLoader.java:301)
  at java.util.ServiceLoader.access$200(ServiceLoader.java:181)
  at java.util.ServiceLoader$LazyIterator.hasNext(ServiceLoader.java:349)
  at java.util.ServiceLoader$1.hasNext(ServiceLoader.java:439)
  at org.geotools.factory.FactoryRegistry.register(FactoryRegistry.java:823)
  at org.geotools.factory.FactoryRegistry.scanForPlugins(FactoryRegistry.java:772)
  at org.geotools.factory.FactoryRegistry.scanForPlugins(FactoryRegistry.java:750)
  at org.geotools.coverage.grid.io.GridFormatFinder.scanForPlugins(GridFormatFinder.java:122)
  at org.geotools.coverage.grid.io.GridFormatFinder.getAvailableFormats(GridFormatFinder.java:85)
  at org.geotools.coverage.grid.io.GridFormatFinder.findFormats(GridFormatFinder.java:178)
  at org.geotools.coverage.grid.io.GridFormatFinder.findFormat(GridFormatFinder.java:241)
  at org.geotools.coverage.grid.io.GridFormatFinder.findFormat(GridFormatFinder.java:216)
  at org.geoserver.data.test.SystemTestData.addRasterLayer(SystemTestData.java:732)
  at org.geoserver.data.test.SystemTestData.addRasterLayer(SystemTestData.java:656)
  at org.geoserver.data.test.SystemTestData.addRasterLayer(SystemTestData.java:643)
  at org.vfny.geoserver.global.GeoserverDataDirectoryTest.onSetUp(GeoserverDataDirectoryTest.java:46)
  at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:222)
  at org.geoserver.test.GeoServerSystemTestSupport.setUp(GeoServerSystemTestSupport.java:158)
  at org.geoserver.test.GeoServerBaseTestSupport.doSetup(GeoServerBaseTestSupport.java:150)
  at sun.reflect.GeneratedMethodAccessor101.invoke(Unknown Source)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
Caused by: java.util.zip.ZipException: invalid block type
  at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:164)
  at java.io.FilterInputStream.read(FilterInputStream.java:133)
  at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:283)
  at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:325)
  at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:177)
  at java.io.InputStreamReader.read(InputStreamReader.java:184)
  at java.io.BufferedReader.fill(BufferedReader.java:154)
  at java.io.BufferedReader.readLine(BufferedReader.java:317)
  at java.io.BufferedReader.readLine(BufferedReader.java:382)
  at java.util.ServiceLoader.parseLine(ServiceLoader.java:247)
  at java.util.ServiceLoader.parse(ServiceLoader.java:299)
  ... 50 more
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.146 sec
Results :
Tests in error:
  modificationProxySerializeTest(org.geoserver.catalog.CatalogIntegrationTest): Trying to get a reader from an unknown format.
  testNamespaceWorkspaceListenerAttached(org.geoserver.catalog.CatalogIntegrationTest): Trying to get a reader from an unknown format.
  testWorkspaceRemoveAndReadd(org.geoserver.catalog.CatalogIntegrationTest): Trying to get a reader from an unknown format.
  testSimpleLoop(org.geoserver.catalog.LayerGroupHelperTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testAllStylesForRendering(org.geoserver.catalog.LayerGroupHelperTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testSimpleLoopWithNotEqualGroups(org.geoserver.catalog.LayerGroupHelperTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testBoundsCRS(org.geoserver.catalog.LayerGroupHelperTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testAllLayers(org.geoserver.catalog.LayerGroupHelperTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testAllStyles(org.geoserver.catalog.LayerGroupHelperTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testBounds(org.geoserver.catalog.LayerGroupHelperTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testAllLayersForRendering(org.geoserver.catalog.LayerGroupHelperTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testDropCoverageStore(org.geoserver.catalog.ResourcePoolTest): Could not find the raster plugin for format GeoTIFF
  testSEStyleWithRelativePath(org.geoserver.catalog.ResourcePoolTest): org/geotools/gml2/GMLConfiguration
  testXmlMapping(org.geoserver.catalog.SchemaMappingTest): org/geotools/gml2/GML
  testXsdMapping(org.geoserver.catalog.SchemaMappingTest): org/geotools/gml2/GML
  testMosaicParameters(org.geoserver.catalog.impl.CatalogBuilderIntTest): Trying to get a reader from an unknown format.
  testLargeNDMosaic(org.geoserver.catalog.impl.CatalogBuilderIntTest): org/geotools/gce/geotiff/GeoTiffWriter
  testFeatureTypeNoSRS(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testEmptyLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testFeatureType(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testLatLonBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testGeometryless(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testSingleBandedCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testLookupSRSDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testSetupBoundsDetached(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testMetadataFromFeatueSource(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testEmptyBounds(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testWMSLayer130crs84(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testMultiBandCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testWMSLayer111(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testWMSLayer130(org.geoserver.catalog.impl.CatalogBuilderTest): java.lang.UnsupportedOperationException: Trying to get a reader from an unknown format.
  testAccessToLayerGroup(org.geoserver.ows.LocalWorkspaceSecureCatalogTest): Could not initialize class org.geotools.gml3.GMLConfiguration
  testAccessToLayer(org.geoserver.ows.LocalWorkspaceSecureCatalogTest): org.geoserver.security.DataAccessLimits
  testLockedMixed(org.geoserver.security.impl.SecureCatalogImplTest): org.geoserver.security.DataAccessLimits
  testEoLayerGroupMustBeHiddenIfItsRootLayerIsHidden(org.geoserver.security.impl.SecureCatalogImplTest): org.geoserver.security.DataAccessLimits
  testComplex(org.geoserver.security.impl.SecureCatalogImplTest): org.geoserver.security.DataAccessLimits
  testLockedDown(org.geoserver.security.impl.SecureCatalogImplTest): org.geoserver.security.DataAccessLimits
  testLockedChallenge(org.geoserver.security.impl.SecureCatalogImplTest): org.geoserver.security.DataAccessLimits
  testLockedLayerInGroupMustNotHideGroup(org.geoserver.security.impl.SecureCatalogImplTest): org.geoserver.security.DataAccessLimits
  testPublicRead(org.geoserver.security.impl.SecureCatalogImplTest): org.geoserver.security.DataAccessLimits
  testCatalogFilteredGetLayers(org.geoserver.security.impl.SecureCatalogImplTest): org.geoserver.security.DataAccessLimits
  testCannotRead(org.geoserver.security.impl.SecureCatalogIntegrationTest): org.geoserver.security.DataAccessLimits
  testCannotWrite(org.geoserver.security.impl.SecureCatalogIntegrationTest): org.geoserver.security.DataAccessLimits
  testLeaveNative(org.vfny.geoserver.ProjectionPolicyTest): org.geotools.coverage.grid.io.GridFormatFactorySpi: Error reading configuration file
  testForce(org.vfny.geoserver.ProjectionPolicyTest)
  testForceCoverage(org.vfny.geoserver.ProjectionPolicyTest)
  testReproject(org.vfny.geoserver.ProjectionPolicyTest)
  testWithRename(org.vfny.geoserver.ProjectionPolicyTest)
  testFindDataFileForAbsolutePath(org.vfny.geoserver.global.GeoserverDataDirectoryTest): org.geotools.coverage.grid.io.GridFormatFactorySpi: Error reading configuration file
Tests run: 567, Failures: 0, Errors: 50, Skipped: 1
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.580s]
[INFO] Core Platform Module .............................. SUCCESS [20.658s]
[INFO] Open Web Service Module ........................... SUCCESS [30.358s]
[INFO] Main Module ....................................... FAILURE [5:02.590s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.722s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.564s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.574s]
[INFO] Application Schema Support ........................ SUCCESS [0.378s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.586s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.761s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.869s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.851s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.633s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.700s]
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.927s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.363s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.490s]
[INFO] Catalog Services for the Web parent ............... SKIPPED
[INFO] DXF output format ................................. SUCCESS [0.529s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.372s]
[INFO] Total time: 6:09.071s (Wall Clock)
[INFO] Finished at: Tue May 13 00:09:37 UTC 2014
[INFO] Final Memory: 38M/292M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project gs-main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://ares.opengeo.org/jenkins/job/geoserver-master/ws/src/main/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gs-main
See <http://ares.opengeo.org/jenkins/job/geoserver-master/495/changes&gt;
Changes:
[andrea.aime] [GEOS-6458] Allow plugins to customize XStreamPersister (register custom converters, aliases and the like)
[andrea.aime] Extract a reusable reorderable panel base class
[andrea.aime] A reusable enum choice renderer for wicket dropdowns
[andrea.aime] [GEOS-6478] Dynamic dimensions value module
[andrea.aime] Follow up on [GEOS-6383], the code NPE's against old configurations that have no strategy set
[andrea.aime] Fix colormap module after Jody's refactor, the location of the ramp was missing the . before the extension
[andrea.aime] Adding the dynamic dimension defaults module to the nightly build
[andrea.aime] [GEOS-6414] WMS-T time range query incorrect, patch by Chris Van Orman
[ksmith] Change compile target to 1.7
[...truncated 5105 lines...]
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.018 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerAuthTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.114 sec
Running org.geoserver.security.impl.DefaultDataAccessManagerTreeTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.security.impl.GeoServerJ2eeRoleServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.991 sec
Running org.geoserver.security.impl.GeoServerRoleConverterImplTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.security.impl.GeoServerUserDaoTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.security.impl.MemoryRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.135 sec
Running org.geoserver.security.impl.MemoryUserDetailsServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 15.237 sec
Running org.geoserver.security.impl.MemoryUserGroupServiceTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.057 sec
Running org.geoserver.security.impl.RoleHierarchyHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.security.impl.SecureCatalogImplTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.185 sec
Running org.geoserver.security.impl.SecureCatalogIntegrationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.435 sec
Running org.geoserver.security.impl.SecureTreeNodeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.security.password.GeoserverPasswordEncoderTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.877 sec
Running org.geoserver.security.password.MasterPasswordChangeTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.235 sec
Running org.geoserver.security.password.URLMasterPasswordProviderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.423 sec
Running org.geoserver.security.rememberme.RememberMeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.314 sec
Running org.geoserver.security.validation.FilterConfigValidatorTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.119 sec
Running org.geoserver.security.validation.MasterPasswordChangeValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.06 sec
Running org.geoserver.security.validation.PasswordValidatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Running org.geoserver.security.validation.RoleStoreValidationWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.166 sec
Running org.geoserver.security.validation.SecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.169 sec
Running org.geoserver.security.validation.UserGroupStoreValidationWrapperTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.877 sec
Running org.geoserver.security.xml.XMLRoleServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.112 sec
Running org.geoserver.security.xml.XMLSecurityConfigValidatorTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.915 sec
Running org.geoserver.security.xml.XMLUserDetailsServiceTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.571 sec
Running org.geoserver.security.xml.XMLUserGroupServiceTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 23.546 sec
Running org.geoserver.template.DirectFeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.816 sec
Running org.geoserver.template.FeatureWrapperTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.087 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.11 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.025 sec
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.021 sec
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.385 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.098 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.731 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.479 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.903 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.839 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.084 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.164 sec
Results :
Failed tests: testModifyStyleChangeWorkspace2(org.geoserver.config.GeoServerPersisterTest)
  testModifyLayer(org.geoserver.config.GeoServerPersisterTest)
  testModifyStyle(org.geoserver.config.GeoServerPersisterTest)
  testModifyLayerGroup(org.geoserver.config.GeoServerPersisterTest)
  testRemoveLayer(org.geoserver.config.GeoServerPersisterTest)
  testRemoveStyle(org.geoserver.config.GeoServerPersisterTest)
  testModifyStyleWithResourceChangeWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testAddLayer(org.geoserver.config.GeoServerPersisterTest)
  testRemoveLayerGroupWithWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testRemoveLayerGroup(org.geoserver.config.GeoServerPersisterTest)
  testAddLayerGroupWithWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testModifyLayerGroupChangeWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testModifyStyleChangeWorkspace(org.geoserver.config.GeoServerPersisterTest)
  testAddLayerGroup(org.geoserver.config.GeoServerPersisterTest)
Tests in error:
  testSimpleLoop(org.geoserver.catalog.LayerGroupHelperTest): org/geotools/sld/v1_1/SLDConfiguration
  testAllStylesForRendering(org.geoserver.catalog.LayerGroupHelperTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testSimpleLoopWithNotEqualGroups(org.geoserver.catalog.LayerGroupHelperTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testBoundsCRS(org.geoserver.catalog.LayerGroupHelperTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testAllLayers(org.geoserver.catalog.LayerGroupHelperTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testAllStyles(org.geoserver.catalog.LayerGroupHelperTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testBounds(org.geoserver.catalog.LayerGroupHelperTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testAllLayersForRendering(org.geoserver.catalog.LayerGroupHelperTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testSEStyleWithRelativePath(org.geoserver.catalog.ResourcePoolTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testCascadeWorkspace(org.geoserver.catalog.impl.CascadeRemovalReporterTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testCascadeLayer(org.geoserver.catalog.impl.CascadeRemovalReporterTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testCascadeStore(org.geoserver.catalog.impl.CascadeRemovalReporterTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testFeatureTypeNoSRS(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testEmptyLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testLayerGroupBounds(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testFeatureType(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testLatLonBounds(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testGeometryless(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testSingleBandedCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testLookupSRSDetached(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testSetupBoundsDetached(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testMetadataFromFeatueSource(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testEmptyBounds(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testWMSLayer130crs84(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testMultiBandCoverage(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testWMSLayer111(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
  testWMSLayer130(org.geoserver.catalog.impl.CatalogBuilderTest): Could not initialize class org.geoserver.catalog.Styles$Handler
Tests run: 568, Failures: 14, Errors: 27, Skipped: 1
[INFO]
[INFO] GeoServer ......................................... SUCCESS [10.448s]
[INFO] Core Platform Module .............................. SUCCESS [25.254s]
[INFO] Open Web Service Module ........................... SUCCESS [29.834s]
[INFO] Main Module ....................................... FAILURE [6:18.302s]
[INFO] GeoServer Web Modules ............................. SUCCESS [3.186s]
[INFO] Community Space ................................... SUCCESS [0.470s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.474s]
[INFO] Application Schema Support ........................ SUCCESS [0.440s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.385s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.001s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.800s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.028s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.257s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.680s]
[INFO] Chart external graphics support ................... SUCCESS [1.410s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.014s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.542s]
[INFO] DXF output format ................................. SUCCESS [0.631s]
[INFO] GeoServer WCS 2.0 Earth Observation Extensions .... SUCCESS [0.566s]
[INFO] Total time: 7:30.408s (Wall Clock)
[INFO] Finished at: Tue May 13 00:17:24 UTC 2014
[INFO] Final Memory: 38M/360M
[ERROR]
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://ares.opengeo.org/jenkins/job/geoserver-master/496/&gt;
